pyrorobert
Members-
Posts
224 -
Joined
Last visited
Everything posted by pyrorobert
Instead directly connecting to each camera and opening ports for access, I'd rather go through Blue Iris. Sent from my SM-F946U1 using Tapatalk
Has anyone used UD Mobile to connect to your cameras through Blue Iris? I would prefer this route as all of my cameras are isolated from being reached through an exterior connection.
Okay sounds good. Thank you for the info. Sent from my SM-F926U using Tapatalk
Thank you for the response. So my plan was to add these around the kitchen countertops to replace my regular white LEDs. I was able to include it in my Eisy, but when I turn it on, it does not do anything. I will try to mess with it more to see why it is not working correctly. Sent from my SM-F926U using Tapatalk
Just wondering if anyone has used one of these controllers? How do you control the different colors? Thanks Sent from my SM-F926U using Tapatalk
I just submitted the ticket. Thanks Sent from my SM-F926U using Tapatalk
It's on Android. I tried a fresh install and it continues to crash. Sent from my SM-F926U using Tapatalk
So I am not sure why UD Mobile keeps crashing. It was working fine up until I began changing statuses, colors, and icons in my favorites about two weeks ago. Now it will not stop crashing when I open the app. I tried removing the app and to start it new, but it is still crashing every time I try to open it. Any suggestions, please? Sent from my SM-F926U using Tapatalk
Okay thank you. What a bummer!
When the first version of the Polyglot came out, I was able to connect my Nest thermostats to my ISY. Is there another way to connect them to the Eisy that others are using? Thanks
So I just found the serial to rj45 cable that came with one of the PLMs that I had as an extra and used that to connect to the Eisy. It is now up and running. I used a usb A to serial db9 adapter to the Serial cable to rj45 to a RJ45 coupler to the Ethernet cable to the PLM. Kind of a mess but it worked.
PLM was plugged in and connected to the Eisy before I turned it on. Still having comm issues. I am making my own cable as I found out that the db9 to rj45 adapter was wired different as this was typically used to connect to other fire alarm panels. Now just trying to make my own at least until UD has them in stock again. I did try to factory reset the PLM but i still have the 0.0.0 v0/ not connected for my PLM status.
So I just received the Eisy this afternoon. I am trying to set it up as it is replacing my Isy-994i. I was able to restore the backup, migrate everything. But it will not see my PLM. When I check the PLM info/status, it shows not connected. I am using a usb to Serial / Serial to DB9 adapter. I also tried to factory reset the PLM, but it did not help. Any other ideas? PLM Status 0.0.0 v0 / not connected
I will give that a shot. Thank you
Hello io_guy, I recently had my Raspberry Pi that was running Nodelink totally crash, so I decided to install Nodelink on my PC that runs my cameras. I read through your instructions but I have run into a few issues. You mentioned in some of your instructions that I need to download a zip file. I have only been able to download the JSON and DLL files. I do have NET core 3.1 installed. It seems like I am missing a few steps. Any other information you can provide would greatly be appreciated. Thank you Regards, Robert Sent from my SM-N986U using Tapatalk
Okay, thank you. Totally forgot about that. I will look at using a smaller size micro SD card. Sent from my SM-N986U using Tapatalk
I read that also but I have a 64gb card in it. Not sure why that would be. I will reflash that card and then reinstall.
A couple weeks ago my Raspberry Pi with Nodelink stopped communicating with my ISY. It has been running fine for the last year or two. So as I tried to log into it, it said the page was unable to be reached. I tried to reboot the Pi, but that did not work. I was still able to log in to the Pi with putty, so I tried reinstalling Nodelink. So see below the errors that I am getting. Thanks ### Updating System - this may take several minutes E: The repository 'http://download.mono-project.com/repo/debian raspbianstretch Release' does no longer have a Release file. E: The repository 'http://raspbian.raspberrypi.org/raspbian stretch Release' does no longer have a Release file. E: The repository 'http://archive.raspberrypi.org/debian stretch Release' does no longer have a Release file. E: The repository 'https://download.docker.com/linux/raspbian stretch Release' does no longer have a Release file. E: Write error - write (28: No space left on device) E: IO Error saving source cache E: The package lists or status file could not be parsed or opened. ### Cleaning/Creating directories mkdir: cannot create directory ‘/home/pi/dotnet’: No space left on device bash: line 25: cd: /home/pi/dotnet: No such file or directory ### Installing .NET 5 tar (child): dotnet-runtime-5.0.2-linux-arm.tar.gz: Cannot open: No such file or directory tar (child): Error is not recoverable: exiting now tar: Child returned status 2 tar: Error is not recoverable: exiting now ### Downloading NodeLink ### Modifying startup script sed: couldn't flush /etc/sedxYCnIv: No space left on device sed: couldn't flush /etc/sedFQAcsQ: No space left on device ### Starting NodeLink bash: line 45: dotnet: command not found ### Install complete. Login to NodeLink at http://1xx.xxx.xxx.xx:8090
So when you set up the ISY in receive mode and Smartthings is your main controller, does this also see all of the Insteon devices in the Smartthings app? Sent from my SM-N975U using Tapatalk
Try deleting the device and reinstall it. I have had that with a few of them.
So my pool was built without an autofill and I was only able to fill it by manually turning on the water. I understand you need a wireless solution, but this is how I wired mine. I installed an I/Olinc and wired it to Sprinkler valve with a Waterflow sensor. The sensor only advises me when the water is running with a text message and an email every 30 minutes. If it runs over an hour then the valve is controlled to shut off. Unfortunately the only 1" Waterflow sensor that I found is not spring loaded, so I had to create a loop on the pipes to keep it in the right position. It works quite well and I automatically run it once a week for 30 minutes. See the photo attached
It sounds like you may have a network issue. Maybe you keep losing your connection while backing it up and that is also why you cannot see the internet. Regards, Robert
- 6 replies
- Mac OSX Sierra
- ISY994i
(and 1 more)
Tagged with:
Scene not turning on micro on/off module within program
pyrorobert replied to pyrorobert's topic in ISY994
Oh I see what I did wrong. Thank you for the assistance. Make sense now. -
Yes, I am. I have a Micro module in each one of the scenes. -
So I set up 2 Micro on/off modules for controlling my Pool's Variable Speed pump. With this set up, it allows me to adjust the pump speed according to the timers or if we are swimming and I don't want the heater to shut off according to the speed of the pump. Micro 1 controls Pump 1 Speed and this is in the morning to the afternoon and is set at a higher speed for running the vacuum in the pool. Pool Timer 1 - [iD 007C][Parent 0021] If From 10:00:00AM To 3:00:00PM (same day) Then In Scene 'Pool Timer 1' Set 'Pool / Pool Pump 1' 100% (On Level) Else In Scene 'Pool Timer 1' Set 'Pool / Pool Pump 1' 0% (On Level) Micro 2 controls Pump 2 Speed which runs at a lower speed just for cycling the water for the rest of the night, but because of the slower speed the heater thinks there isn't enough flow to stay on. Pool Timer 2 - [iD 007D][Parent 0021] If From 3:00:00PM To 10:00:00PM (same day) Then In Scene 'Pool Timer 2' Set 'Pool / Pool Pump 2' 100% (On Level) Else In Scene 'Pool Timer 2' Set 'Pool / Pool Pump 2' 0% (On Level) I then set up a button on a 8 button switch that activates another program to override both programs and disables the scenes that controls the pump. This way the pump works at a faster speed for the heater. Pool Swim Mode - [iD 007E][Parent 0021] If Control 'Backyard Light / Pool Swimming - E' is switched On And Control 'Backyard Light / Pool Swimming - E' is not switched Off Then Set 'Pool / Pool Pump 1' On Set 'Pool / Pool Pump 2' On Disable Program 'Pool Timer 1' Disable Program 'Pool Timer 2' Else Set 'Pool / Pool Pump 1' Off Set 'Pool / Pool Pump 2' Off Enable Program 'Pool Timer 1' Enable Program 'Pool Timer 2' The issue I am having is that the scene for Pump 1 and 2 show that they are on, but it does not turn on the actual Micro module for either scene. Is there something wrong with my program that you may see? If I go directly to the pump micro module, and remove the scene, the Micro modules turn on when scheduled but then there is no way to override or disable the scheduled programs. Any assistance is great appreciated Regards, Robert
