Everything posted by pyrorobert
		Light turns on with command of Lamplinc.
		Sounds good, i will try that. Thank you
		Hello everyone, I have a Lamplinc that turns on everyday in my living room when it is sunset. Recently, the Fanlinc light portion turns on at the same time. They are not linked in any way. The program I have for the Lamp does not have it in there. There are no routines or scenes that they are integrated with other than one. I disabled that routine and it still turns on. In the log, I can see it turn on but it doesn't say what turns it on. I was going to take apart the fan to get to the fanlinc and just factory reset it if needed. It is just a pain to get to because of the height and disassembly. Would anyone know how else to see what is causing this?
		Blue Iris
		Instead directly connecting to each camera and opening ports for access, I'd rather go through Blue Iris. Sent from my SM-F946U1 using Tapatalk
		Blue Iris
		Has anyone used UD Mobile to connect to your cameras through Blue Iris? I would prefer this route as all of my cameras are isolated from being reached through an exterior connection.
		ZOOZ ZEN31 RGBW Controller
		Okay sounds good. Thank you for the info. Sent from my SM-F926U using Tapatalk
		Thank you for the response. So my plan was to add these around the kitchen countertops to replace my regular white LEDs. I was able to include it in my Eisy, but when I turn it on, it does not do anything. I will try to mess with it more to see why it is not working correctly. Sent from my SM-F926U using Tapatalk
		Just wondering if anyone has used one of these controllers? How do you control the different colors? Thanks Sent from my SM-F926U using Tapatalk
		UD Mobile keeps crashing
		I just submitted the ticket. Thanks Sent from my SM-F926U using Tapatalk
		It's on Android. I tried a fresh install and it continues to crash. Sent from my SM-F926U using Tapatalk
		So I am not sure why UD Mobile keeps crashing. It was working fine up until I began changing statuses, colors, and icons in my favorites about two weeks ago. Now it will not stop crashing when I open the app. I tried removing the app and to start it new, but it is still crashing every time I try to open it. Any suggestions, please? Sent from my SM-F926U using Tapatalk
		Does pg3 connect to the Nest thermostats anymore?`
		Okay thank you. What a bummer!
		When the first version of the Polyglot came out, I was able to connect my Nest thermostats to my ISY. Is there another way to connect them to the Eisy that others are using? Thanks
		Eisy not connecting to my 2413S PLM
		So I just found the serial to rj45 cable that came with one of the PLMs that I had as an extra and used that to connect to the Eisy. It is now up and running. I used a usb A to serial db9 adapter to the Serial cable to rj45 to a RJ45 coupler to the Ethernet cable to the PLM. Kind of a mess but it worked.
		PLM was plugged in and connected to the Eisy before I turned it on. Still having comm issues. I am making my own cable as I found out that the db9 to rj45 adapter was wired different as this was typically used to connect to other fire alarm panels. Now just trying to make my own at least until UD has them in stock again. I did try to factory reset the PLM but i still have the 0.0.0 v0/ not connected for my PLM status.
		So I just received the Eisy this afternoon. I am trying to set it up as it is replacing my Isy-994i. I was able to restore the backup, migrate everything. But it will not see my PLM. When I check the PLM info/status, it shows not connected. I am using a usb to Serial / Serial to DB9 adapter. I also tried to factory reset the PLM, but it did not help. Any other ideas? PLM Status 0.0.0 v0 / not connected
		Nodelink install on PC assistance
		I will give that a shot. Thank you
		Hello io_guy, I recently had my Raspberry Pi that was running Nodelink totally crash, so I decided to install Nodelink on my PC that runs my cameras. I read through your instructions but I have run into a few issues. You mentioned in some of your instructions that I need to download a zip file. I have only been able to download the JSON and DLL files. I do have NET core 3.1 installed. It seems like I am missing a few steps. Any other information you can provide would greatly be appreciated. Thank you Regards, Robert Sent from my SM-N986U using Tapatalk
		Nodelink crashed and won't restart.
		Okay, thank you. Totally forgot about that. I will look at using a smaller size micro SD card. Sent from my SM-N986U using Tapatalk
		I read that also but I have a 64gb card in it. Not sure why that would be. I will reflash that card and then reinstall.
		A couple weeks ago my Raspberry Pi with Nodelink stopped communicating with my ISY. It has been running fine for the last year or two. So as I tried to log into it, it said the page was unable to be reached. I tried to reboot the Pi, but that did not work. I was still able to log in to the Pi with putty, so I tried reinstalling Nodelink. So see below the errors that I am getting. Thanks ### Updating System - this may take several minutes E: The repository 'http://download.mono-project.com/repo/debian raspbianstretch Release' does no longer have a Release file. E: The repository 'http://raspbian.raspberrypi.org/raspbian stretch Release' does no longer have a Release file. E: The repository 'http://archive.raspberrypi.org/debian stretch Release' does no longer have a Release file. E: The repository 'https://download.docker.com/linux/raspbian stretch Release' does no longer have a Release file. E: Write error - write (28: No space left on device) E: IO Error saving source cache E: The package lists or status file could not be parsed or opened. ### Cleaning/Creating directories mkdir: cannot create directory ‘/home/pi/dotnet’: No space left on device bash: line 25: cd: /home/pi/dotnet: No such file or directory ### Installing .NET 5 tar (child): dotnet-runtime-5.0.2-linux-arm.tar.gz: Cannot open: No such file or directory tar (child): Error is not recoverable: exiting now tar: Child returned status 2 tar: Error is not recoverable: exiting now ### Downloading NodeLink ### Modifying startup script sed: couldn't flush /etc/sedxYCnIv: No space left on device sed: couldn't flush /etc/sedFQAcsQ: No space left on device ### Starting NodeLink bash: line 45: dotnet: command not found ### Install complete. Login to NodeLink at http://1xx.xxx.xxx.xx:8090
		ISY994iZ integration with SmartThings Hub
		So when you set up the ISY in receive mode and Smartthings is your main controller, does this also see all of the Insteon devices in the Smartthings app? Sent from my SM-N975U using Tapatalk
		IOLinc not responding but I can control it ?
		Try deleting the device and reinstall it. I have had that with a few of them.
		Swimming pool water level control
		So my pool was built without an autofill and I was only able to fill it by manually turning on the water. I understand you need a wireless solution, but this is how I wired mine. I installed an I/Olinc and wired it to Sprinkler valve with a Waterflow sensor. The sensor only advises me when the water is running with a text message and an email every 30 minutes. If it runs over an hour then the valve is controlled to shut off. Unfortunately the only 1" Waterflow sensor that I found is not spring loaded, so I had to create a loop on the pipes to keep it in the right position. It works quite well and I automatically run it once a week for 30 minutes. See the photo attached
		Updates, backups and upgrades
		It sounds like you may have a network issue. Maybe you keep losing your connection while backing it up and that is also why you cannot see the internet. Regards, Robert
		Scene not turning on micro on/off module within program
		Oh I see what I did wrong. Thank you for the assistance. Make sense now.
