glarsen
Everything posted by glarsen
  1. I believe that the only elements affected were the sunset/sunrise node drivers.
  2. I have just posted a new version of the DysonPureCool plugin to the beta store, version 5.0.0. It has many changes will should improve interoperability with eisy-ui and UDM. I would suggest installing it in a separated slot from your Production version (you probably will not be able to run them both at once) since there significant profile changes which will require most IoX programs to be rewritten. Since the plugin is now names "DysonFan", it will not try to install over the same slot anyway, without deleting the old one first. Once again, I only own a Dyson TP07 series PureCool so the plugin is only thoroughly tested with that fan. There are some minor code changes affecting all models, but the PH02 and TP02 should still operate as previously. Please test these and if you have any issues, PM your logs (in "DEBUG" mode) and I will do my best to accommodate.
  3. @aca2b2 , I sent you a PM with a zipfile with an old PG2 version (2.2.10). Good luck. Please note there is no longer any support for this version. YMMV
  4. @macjeff I think 3.4.0 fixes the issues on both UDM and eisy-ui. Remember to re-sync UDM after installing the latest update. Please let me know.
  5. I too am using the latest beta UDM with eisy-ui 7.1 and everything looks good here. Unfortunately, I do see the same display as you in eisy-ui so will have to look into it. Everything else seems to look ok, including the regular admin console.
  6. Benoit has released an update, 0.7.1 of eisy-ui. Did that make any difference? I have not had time yet to upgrade either of my machines since I'm away from home for a bit. I will look into it if necessary as soon as I can.
  7. Sunrise hour today is sys.node.nxxx_sundata.GV7 Sunset hour today is sys.node.nxxx_sundata.GV1 Sunrise hour tomorrow is sys.node.nxxx_sundata.GV3 Sunset hour tomorrow is sys.node.nxxx_sundata.GV5
  8. It's been a while since I worked on this plugin, but I think that simply restarting it should run discovery again and add the new zone.
  9. Open/close now do what they say they will! Thanks.
  10. @sjenkins I've discovered that the "Open" and "Close" buttons in the nodes for the individual shades are inverted - "Open" closes the shades, and conversely "Close" opens them. The "Activate" function in each of the Open and Close nodes works as expected though. This is the same whether using the AC or UD Mobile, or in programs. I don't know if this has been a long term or recent thing. My HD system is a G3 running version 3.2.46 on the Gateway. Iox 5.9.1, PG3x 3.3.21, HD 1.12.5 (exhibited same behaviour on .4, don't know about previous versions). It's not a big issue as my programming uses the Open/Close nodes and functions correctly.
  11. Can you PM me the debug log please, and a screenshot of your config?
  12. 10.0.55 is not a valid IP address. You're missing one octet, a fourth digit.
  13. PM sent
  14. @firstone, up until now i've had good success with my Onkyo TX-NR737 and AVRemote. Sadly, the 737 died a quiet death recently and it wasn't worth repairing. I've 'upgraded' to a TX-NR6100 which, operationally, is very similar. It offers a few more streaming features but otherwise isn't much different, with one exception. Volume control is 0-100 in steps of .5, so AVRemote doesn't control it or read it properly as the old 737 only used 0-80 and whole integer steps. The latest eiscp definitions do seem to show this addtion, so I wonder if it would be possible to modify AVRemote to adapt to the newer Receiver? Thanks for this!
  15. Looks good @bmercier. Thanks. Tinkering continues....
  16. @bmercier done.
  17. @bmercier I also have the same results as @sjenkins after upgrading to 5.9.1_21 and rebooting. The rest command gives this, which seems normal: {"timestamp":"2025-06-07T08:26:11.581210-07:00","families":[{"id":"1","name":"","instances":[{"id":"1","name":"","nodedefs":[{"id":"RelayLampSwitch_ADV","nls":"147","properties":[{"id":"ST","editor":"I_OL_RELAY","name":"Status"},{"id":"ERR","editor":"I_ERR","hide":true,"name":"Responding"}],"cmds":{"sends":[{"id":"DON","name":"On"},{"id":"DOF","name":"Off"},{"id":"DFOF","name":"Fast Off"},{"id":"DFON","name":"Fast On"},{"id":"FDUP","name":"Fade Up"},{"id":"FDDOWN","name":"Fade Down"},{"id":"FDSTOP","name":"Fade Stop"}],"accepts":[{"id":"DON","name":"On","parameters":[{"id":"","editor":"I_0_100_PERCENT","optional":true}]},{"id":"DOF","name":"Off"},{"id":"DFOF","name":"Fast Off"},{"id":"DFON","name":"Fast On"},{"id":"QUERY","name":"Query"},{"id":"BEEP","name":"Beep","format":"/level/${c}/${c} ${v}/","parameters":[{"id":"","editor":"I_BEEP_255","optional":true}]},{"id":"BL","name":"Backlight","parameters":[{"id":"","editor":"I_BL"}]},{"id":"WDU","name":"Write Changes"}]},"links":{"ctl":["I_CTL_DIMMER_ADV"],"rsp":["I_RELAY","I_RELAY_ADV"]}}]}]}]} Still receiving "Error loading node 2A 43 78 1: Profiles loaded but nodedefs missing", same on all Insteon nodes
  18. @bmercier IoX is at 5.9.1 and PG3x at 3.3.19 with eisyui 0.4.1 installed. For kicks I restarted the eisy anyway after clicking "Upgrade Packages", but same versions before and after, and no change in results.
  19. Error loading node 4F E5 E4 1: Profiles loaded but nodedefs missing I'm getting this error on all Insteon nodes. Thus, no commands appear in widgets. Also, can't seem to get widgets to display on ZWave Thermostats, only properties.
  20. @kzboray, I did notice at the time that I updated to 5.8.3 that none of my Python plugins started initially either, but after a second reboot they all came up properly. And under 5.8.4 they all seem ok too.
  21. @tmorse305, the issue for some seems to have arisen after updating to IoX 5.8.4.
  22. And yet all of mine are fine...including RainMachine. Which hardware are you on - Polisy or eisy? Not that it should matter, but....
  23. @chadm, Meteobridge 3.2.0 is available which incorporates indoor temperature, humidity, and dew point. Let me know if you have any issues.
  24. There's a new version of Meteobridge that I just uploaded incorporating some changes requested by another user. The file for both Polisy and eisy is identical and runs fine on both of my Polisy and eisy, so I'm not sure why you're seeing that. In any case, try 3.2.0 and see if it works.
  25. Don't see why not. Give me a couple of weeks and I'll get it done. Just finishing up a move into a new location and still finding things.
