someguy
Everything posted by someguy
  1. this post forum thread says to read and review the release, but doesn't mention what to read and which release it is talking about. this forum post "BEFORE YOU START" BUT THEN CUTS OFF so it isn't helpful. is it this one? forum thread
  2. someguy replied to someguy's topic in Ecobee
    I have bought the homekithub and the ecobee plug ins for PG3x. I currently have the Ecobees connected to my Home Assistant but am happy to change this if necessary. I've tried to work through the process of connecting the three thermostats to PG3x and I can't make it work. I do not have the developer API. suggestions?
  3. someguy posted a topic in Ecobee
    I’m about 5 hours in and still cannot get my 3 ecobee thermostats connected to my Eisy. I need a tutorial that is straightforward. Can someone help please?
  4. someguy replied to balli's topic in Amazon Echo
    I am having major trouble with the Alexa+. I like the function of this alexa+ but it is still causing me to get the error message "I am not quite sure what when wrong with the (xxx)" even though the (xxx) went on or off just fine. I tried setting up some voice controls inside of Home Assistant and they do the same thing!!! some of you have alexa+ working, it appears by this thread. any suggestions? (I've asked Claude AI and it wasn't helpful.)
  5. someguy replied to balli's topic in Amazon Echo
    I tried enabling Alex Plus and now all of my devices get this reply from Alexa: "I can't control the device because its skill is disabled. you can find the skill and enable it again in the alexa app". I tried diabling and re-enabling the v3 universal devices skill and it still doesn't work. suggestions?
  6. someguy replied to balli's topic in Amazon Echo
    are we saying it is "safe" to upgrade to alexa plus? by safe, I mean that it no longer causes all of the problems that it used to cause as noted here: https://forum.universal-devices.com/topic/45665-don%E2%80%99t-upgrade-to-alexa/
  7. I just got confirmation from Benoit who said that the problem is the PiHole is giving such slow DNS resolution. How could I speed up my SNS resolution from the pi hole?
  8. @maxnorth : I have a pi-hole so this may be my problem. I have my eisy set as exempt from any of the filtering that the pi-hole does, so I don't know how it could be the problem though. I do have a question: if I power down my pi-hole, which is running on a raspberry pi by the way, my network doesn't work because I am using it for DNS and filtering. to truly temporarily remove my pi-hole I'd had to reset the settings in my router but I don't want to do that because I want all three: pi-hole, IPv6, and Portal!! 😁
  9. @maxnorth here is my problem: my Eisy connects to the portal with IPv6 on and won’t contect with it off. I believe you may have to reboot your Eisy after you change the IPv6 settings for it to try again If you have the same situation then let me know and we can message each other to try to figure out what else we have in common that could be the cause The solution has not yet come to fruition. After about a dozen messages back and forth with support, they’ve moved to doing an online session to try to work it out. I was told that I am the only person (yet) having this problem.
  10. I was on 6.0.3. I tried the power cycle and it didn't solve the problem. I tried upgrading package (again) and rebooting and it still hasn't come up. (when I login to my.isy.io it shows that my Eisy hasn't connected since just before I upgraded to 6.0.3) I'll open a ticket but I'd appreciate any other suggestions that anyone might have.
  11. I used "upgrade packages" inside of the Admin Console and then when it later said to "reboot", I did so. after a long time I rebooted again, but I still cannot get the portal connect. when I go to: https://eisy.local/settings/portal my browser switches that to http://eisy.local/settings/plugins so I cannot even get to the portal part of eisy. I'd appreciate any help.
  12. @Athlon I am using alexa (not alexa plus). Also, many of the devices that go on randomly are not ones that I have a spoke for in the portal. @IndyMike I think (I hope) that @oberkc meant insteon instead of instagram. I hope there is no way for instagram to directly control our homes. 😄 just this morning, I had an event occur where I had a number of devices turn on. Some of the devices that went on were the same and as yesterday and are frequent offenders. some of the devices were not usual offenders. also: many of the devices that went on this morning are fairly new or very new dual band switchlincs. any other suggestions?
  13. @IndyMike : I tried factory resetting the main devices that are culprits here and they still randomly and occasionally turn on. It is mostly three or four bathroom fans that I find on with no explanation as to why they are on. it is possible that they are the ones that I'm finding on because the lights get turned off by someone else in the house (I have four kids and a wife). about a week ago, quite a few items went on and one of them was the master bedroom light at around 5am while my wife was sleeping. needless to say that didn't go over well. any other suggestions as to how to fix this problem?
  14. @Javi I'm on Elk 3.10.15 and it hasn't fixed the problem with the Elk system not getting updates on Eisy device status.
  15. I was having trouble with my Elk alarm, but with a restart of the PG3 node, it now works. sorry to cry wolf.
  16. @BILJ I found a way that could work to remove old spokens. I created a new thread because I didn't think it was directly within the confines of this thread. it is here: https://forum.universal-devices.com/topic/46013-python-script-to-delete-echoalexa-devices/
  17. I found this python script that seems to be able to delete alexa devices: https://github.com/Shereef/Python-Delete-Alexa-Devices it looks fairly complicated to me, and Id like to know if it can see the "hidden" devices or is it just seeing the same ones that I can see in the app. has anyone tried it or does anyone know of a better way to remove old devices (most notably those that may be trying to using the V2 skill and are clogging up our system)?
  18. @IndyMike I do very much appreciate your help with this! One of my three devices had a missing link in the link table but the device shows as "identical". it is missing the "E2 01 71.17.AC..." link. I've had this problem with other devices in the past. To fix this, I'll remove the device and then re-add it and this should fix this problem. None of my problematic devices are part of any scenes, by the way. this doesn't explain why these devices are turning on for no reason. any more thoughts? is it possible that they are just old switches that somehow go on for no reason? seems unlikely to me.
  19. I have a program running that checks to see if any of my offenders are on when ISY thinks they are off. I had three of my common offenders on at 8am yesterday. here is the log for the previous four hours. the offenders are: 15.A6.B2, 71.C2.58, and 15.A2.CC I don't see anywhere that these devices are being contacted by the system except at around 8am when I query them and then turn them off (with my program that does so). ISY-Events-Log.v6.0.0__Tue 2025.11.18 17.53.56.txt
  20. @IndyMike I started my even viewer. I will only send it if I have an event occur, which happens about 2-3 times per week. my suspicion is that you'd just want the event viewer info surrounding the event. @Techman questions answered: yes, I have insteon motion sensors. no, I haven't had an "all on" event happen in recent years. my abnormal events are rare enough that it rarely is a witnessed event. I just come home and find something on when no one has been home and no program could have turned that device on. yes, I have some older non dual-band insteon devices installed. yes, I have power supplies plugged into some of my outletlincs (but those outletlincs haven't, to my knowledge, gone on (or off) in one of these events). because I almost never know, exactly, when these events occur, I haven't been able to find a program that could be causing them.
  21. I've found a way to get rid of the duplicate items. it has been mentioned before. 1) create a group with the name, e.g. "kitchen lights" 2) upon creating the group you add in both the "devices" called kitchen lights and the "scene" that is called kitchen lights. Interestingly, when you look through the list to find the kitchen lights, there are dozens more devices that are available when using them normally. 3) once the group has been created, it should work just fine. somehow, as has been noted previously in this thread, groups take precedence over devices and scenes. this will solve the duplicate devices problem. but: I went a little further and found that if you mess around with the group, you can figure out which device and which scenes actually work and which are the broken ones (perhaps they are the ones connected to the V2 skill). you can then, while still modifying the group, deleted those devices or scenes...... BUT THE PROBLEM I had with doing this is the the V3 skill did not work consistently when using alexa+. (here is what I mean: if I said "turn the kitchen lights on" 10 times, it would work maybe 4 times and not work the other 6. I couldn't figure out any reason why it only worked part of the time.) Here is how I solved the “I can’t control the <device name> because its skill is disabled. You can find the skill and enable it again in the Alexa app" problem: I downgraded to remove alexa+ for now. I liked alexa+ but the problems with the voice controls weren't worth it.
  22. I would like to continue to try to solve (if possible) this problem as I still have devices occasionaly going on for no obvious reason. most of what you kind fellows are saying in this thread goes over my head, unfortunately. is there any way I can contribute to try to solve this problem? is running my "event viewer" on level 3 going to help me (us) any?
  23. FYI: I went into the isy.io access for alexa and found that my "devices" still worked as listed in the "amazon echo device list" but the "scenes" did not work. I then went into the alexa app and asked it (by typing "disable alexa+") and it did so and then, voilà: all of my scenes and devices all work without any problems! I'll just await this being solved and then re-enable alexa+.
  24. I'd like to keep the alexa + capability but get rid of the sassy "... November 4..." responses. any suggestions?
  25. when I added the V3 skill, I looked for the V2 skill to remove it and it was nowhere to be found. Perhaps there is a way to find it and remove it? and by the way; its actually "after November 4".
