Blackbird
Everything posted by Blackbird
  1. I switched out the PLM to my new USB PLM. Everything seems to work fine. Took me about an hour. Thanks again to all of your help!!!!!
  2. Nevermind looks like everything cleared on its own. Thanks
  3. I am installing a new USB PLM on my POLISY. In the instructions Mishel gave me it shows this. To replace a PLM: Unplug ISY from the power outlet Unplug the PLM from ISY and power outlet Connect ISY’s port A to the new PLM Plug the new PLM into a power outlet Plug ISY into a power outlet Go to Admin Console and wait for system initialization to complete If you have PRO Series, click on the Battery icon at the top. This will prevent ISY from trying to update programming on your RF devices which are probably in sleep mode Click on the Restore Modem (PLM) menu option In case ISY cannot communicate (or decides not to if an RF device/PRO Series) during the process, you will have a series of nodes with green 1011 icons in the device tree. For each one of those nodes: If an RF device, ensure that the device is in Programming mode Right mouse click | Write pending updates ... On this line "In case ISY cannot communicate (or decides not to if an RF device/PRO Series) during the process, you will have a series of nodes with green 1011 icons in the device tree. For each one of those nodes:" is that meant to be done after the system busy progress bar is finished at 100%? I am at 20% and have a bunch of 10011 icons but some are slowly going away. Or do I right click and write to devices during the system busy process? Thanks
  4. I didn't check the status of udmobile but admin console showed it off
  5. I just tried to turn on the computer room light, pushed ON once with admin console and the light didnt turn on even after 5 min.
  6. On the screenshot, what does that tell you?
  7. The screenshot below shows me trying to turn on the computer room light with admin console. The first two lines, the lights wouldnt come on then I clicked on again and the lights came on and lines 3 through 8 popped up.
  8. I just turned on my computer room light with UDmobile. turned on instantly. Then turned it off and wouldnt turn off. Tried twice. Then opened the event viewer and set to level 3 and turned the computer room light off with udmobile and it wouldnt turn off but the event viewer recognized the command then a popup came up saying couldnt connect to computer room light. Computer room light has an exclamation mark, I clicked on it in admin console and clicked off and it turned off right away and the exclamation mark went away. Now turned it back on and 15 seconds later the light comes on.
  9. Delay is usually seconds but I usually dont wait and keep hitting the on or off button but as I said with the shed, sometimes the command is missed all together. A few time I have noticed the bedroom light turning on by itself for no reason. I think its when i tried doing a restore or maybe when I rebooted the ISY, not sure.
  10. Thanks guys. Yes I would say things are currently working normally, 60% to 70% of the time. Sometimes a device turns on instantly using udmobile and other times I have to turn that device on 3 or 4 times before it will turn on. Same with programs running. For example the light on my shed shuts off at sunrise and out of the past week it failed to turn off two separate days after sunrise.
  11. Thats my dilemma, things work now but take time or multiple retries. I was able to order a PLM USB that was the last one in stock and should get here in about 5 days. Maybe I am best to wait as I rely on so many things on the ISY.
  12. Are you thinking that factory resetting my plm then restoring it wont help?
  13. Wow thats a hell of a reply. Thanks for the detailed explanation. Thank you and this was Michel's reply "There's no queue. Every time you click on Restore, the same set of files are reset to their original state and then IoX starts from scratch. What you are getting is a failure for "resetting the PLM". This means that the PLM is not honoring the request to have it reset. If communications are OK (i.e. Tools/Diagnostics/PLM Status/Info shows Connected), in 99.99% of the cases, the issue is the PLM itself."
  14. Would factory reset clear all that?
  15. Will do thanks. Im sure I will still need help.
  16. I just asked him about this. Thank you
  17. Michel says the PLM needs to be replaced. I have a serial plm model EZICOmm #5010k. Will this work? Also as you suggested, how do I factory reset my PLM and try that first? Thanks
  18. Yes Michel reached out this morning asking for a file and some screenshots. Thanks for asking.
  19. Status shows connected.
  20. Just tried to restore the PLM and got an error after 1% "Failed writing PLM master link (Kitchen Light) [-200000/-3]. Driver not found [[Unknown ] 0240 ] " Tried it twice and same issue. I disabled the Kitchen light then it made it to 3% and came up with the same error but this time for the "Computer room light"
  21. Well I said that UDmobile always showed the correct status but now its delayed as well. I did turn off each breaker one at a time and no difference. I will try to restore my existing plm. thanks
  22. Will I have to re add all of the wireless devices after I do a restore on my current plm? Will any programs get messed up? Thanks
  23. Thanks for the response. Yes mine is dual band. I dont have a filterlinc. Maybe I should get one.
  24. No he didnt suggest to restore the PLM just gave me instructions on how to do it when I get a replacement. Is the process different if you are restoring an existing PLM? I didnt try the breakers yet but I think I will. I think Michel was leaning more to line noise as he advised about moving the plm. At the end he suggested speaking to Insteon but I thought I would give all of you a chance as you guys have helped me so much in the past years! What does it mean that admin console and UDmobile are always accurate about the status of the devices when they are manually turned on but sometimes fail when turning them on with AC or UDmobile? Does that mean the the PLM receives fine but has problems sending? The reason I ask is if it was line noise, wouldnt that also effect how the PLM receives? Thanks
  25. Yikes. That does sound painful.
