elvisimprsntr
Everything posted by elvisimprsntr
  1. I briefly upgraded to Alexa+, only to quickly discover the MobiLinc and Lorex camera skills stopped working. I simply asked Alexa to uninstall Alexa+ via a voice command.
  2. I don't have an eISY (MeLE Quieter3Q), but do have a MeLE Quieter3C running Ubuntu with Homebridge. The cooling fins on the top of the unit are plastic, not aluminum. I simply mounted it to the back of a monitor with a VESA mount. Hasn't been a problem after 2.56 years. root@mele-ud22:~# sensors coretemp-isa-0000 Adapter: ISA adapter Package id 0: +49.0°C (high = +105.0°C, crit = +105.0°C) Core 0: +41.0°C (high = +105.0°C, crit = +105.0°C) Core 1: +41.0°C (high = +105.0°C, crit = +105.0°C) Core 2: +41.0°C (high = +105.0°C, crit = +105.0°C) Core 3: +41.0°C (high = +105.0°C, crit = +105.0°C) acpitz-acpi-0 Adapter: ACPI interface temp1: +27.8°C (crit = +119.0°C) nvme-pci-0200 Adapter: PCI adapter Composite: +41.9°C (low = -0.1°C, high = +84.8°C) (crit = +94.8°C) Sensor 1: +41.9°C (low = -273.1°C, high = +65261.8°C) Sensor 2: +46.9°C (low = -273.1°C, high = +65261.8°C) Sensor 8: +41.9°C (low = -273.1°C, high = +65261.8°C) root@mele-ud22:~# nvme smart-log /dev/nvme0 Smart Log for NVME device:nvme0 namespace-id:ffffffff critical_warning : 0 temperature : 42 C (315 Kelvin) available_spare : 100% available_spare_threshold : 5% percentage_used : 11% endurance group critical warning summary: 0 data_units_read : 1,495,531 data_units_written : 41,693,437 host_read_commands : 21,305,919 host_write_commands : 1,899,017,040 controller_busy_time : 1,898 power_cycles : 36 power_on_hours : 22,418 unsafe_shutdowns : 12 media_errors : 0 num_err_log_entries : 1,098 Warning Temperature Time : 0 Critical Composite Temperature Time : 0 Temperature Sensor 1 : 42 C (315 Kelvin) Temperature Sensor 2 : 46 C (319 Kelvin) Temperature Sensor 8 : 42 C (315 Kelvin) Thermal Management T1 Trans Count : 0 Thermal Management T2 Trans Count : 0 Thermal Management T1 Total Time : 0 Thermal Management T2 Total Time : 0 Not sure if the eISY comes with the original warning label on it, but here is a pic from a 3Q review.
  3. Correction: "... older products that did not have a subscription based business model are now e-waste." Thats the dilemma. Adopt a new product/technology that does not have a sustainable business model and you get left holding the bag. Just ask anyone who purchased Sonos gear.
  4. Skills working again as of 21:00 EDT
  5. All skills are not working. https://downdetector.com/status/amazon-alexa/
  6. @apostolakisl Serial PLM uses non-standard pinout. The one UDI sells is a modified off the shelf cable. https://www.universal-devices.com/product/serial-plm-kit/ Or you can make your own.
  7. I have an adjustable inductive current sense relay on my doorbell transformer to detect when a video doorbell is pressed, which is wired to an Elk input zone. Note: The ELK-930 doorbell/ring detector only works on traditional mechanical doorbell chimes and is not user adjustable. I use the Elk zone to trigger the exterior lights on for 30 seconds when a doorbell is pressed. I also have an ISY program to continuously flash the exterior lights if the Elk alarm is set off or one of the keypad panic buttons is pressed to help emergency responders quickly narrow down which house.
  8. Apparently, Notifyre touts its self as an alternative. I tried to register, but apparently you need an employer EIN. I think it is geared more towards enterprise. Pushover seems to be the best and most cost effective alternative. 30-day free trial and $4.99 one time license per platform. Already updated my ISY and Elk to use Pushover.
  9. Thanks ATT. This is how I send notifications on certain events (alarm, doorbell, left garage door open at night, etc.) effectively acting like push notifications.
  10. For the record page 386 (PDF sheet 399) has the schematic and pin-out. https://cache.insteon.com/developer/developer-guide-022009-en.pdf
  11. Use an ohm meter to compare the pinout of the two sets of DE9 to RJ45 cables. I suspect the new cables are a standard Cisco serial console cable, which is not compatible with the serial PLM, and our mutual friends at the new Insteon don't know or assumed users would know. In which case, you can continue to use the old cables or cut off the RJ45 and re-terminate with the correct pin-out.
  12. @Rapidway Excellent job. Just be careful what you use to control a GD. In my experience, the IO Linc reliability was not sufficient to connect to a GD controller, especially with a wall transformer right next to the IO Linc
  13. Have you confirmed you previously configured the ISY to use a static IP? If so, your ISY has a static IP on a completely different subnet from your new ISP gear. You need to use one of the methods above to change the ISY to use DHCP, or set a static IP, subnet mask, gateway, and DNS aligned with your new ISP gear. If not, have you performed a network scan or logged into your new ISP gear to see what IP address was assigned? Or you may need to clear your Java cache to force the ISY launcher to stop looking for the old IP address.
  14. Or connect up the serial console cable. https://wiki.universal-devices.com/ISY-99i/ISY-26_INSTEON:Quick_Start_Guide Then you can check/change the IP configuration. Personally, I prefer DHCP and use static reservations in my pfSense firewall. Another option would be to connect the ISY99 LAN connection directly to a computer, then assign the computer a fixed IP address on the same subnet. Then you can log into the admin console and make a backup and change IP settings.
  15. Spammers were using bulk email to sms/mms. My guess is ATT is trying hard to detect and block this sort of abuse, which may have the unintended consequence of blocking legitimate use of the feature. We can all thank ATT for releasing all our sensitive information. https://www.bleepingcomputer.com/news/security/att-now-says-data-breach-impacted-51-million-customers/
  16. I spun up my own instance of Homebridge and connected it to my ISY, Elk, and cameras. Works automatically! Theoretically is should work with the eISY.
  17. Glad I have a dumb Chamberlain garage door opener. I bought/installed mine in 2009 before MyQ was even a thing. I wired a magnetic door sensor on the door header to an Elk M1 input zone and a relay output soldered to the back of the Chamberlain wall mount controller push button contacts. IMHO, the Insteon garage door kit with the relay module is just too unreliable for anything safety and security related, not to mention the documented Insteon vulnerabilities. I configured the Elk relay output as a momentary output and programmed an Elk keypad function key to toggle the relay and blink the illuminated function key when the door is open. Both driveway and interior garage cameras allow me to confirm there are no humans/pets or obstructions in harms ways before remotely closing the door, e.g. after letting a contractor in. I also use a MobiLinc HD geofence to open the door (if not already open) when I arrive 200m from my house and turn on the exterior lights. You can set ML to not update an ISY variable if the phone is locked to prevent someone who steals your phone from gaining access to the garage. I never perform autonomous automatic closing of the garage door based on time of day or when leaving. Closing is always a manually initiated action performed by a human. Although not stated in Chamberlain’s official statement, it would not surprise me to find out Chamberlain’s lawyers advised them to shutdown unauthorized access to their APIs because of potential liability when someone does something stupid which results in injury or death.
  18. elvisimprsntr replied to SSS's topic in eisy
    @SSS Since there is no official package for FreeBSD, I suspect it will be awhile. I suggest you spin up a bare metal Linux distro, VM, or Docker container. https://homebridge.io/how-to-install-homebridge
  19. In South Florida, momentary (<2 seconds) power interruptions are a common occurrence (weekly), even on clear sunny days. Since FPL installed smart meters, brown outs are extremely rare. When I had the ISY-99(4)i on UPS power, 90% of the time it would lock up. In fact, I actually prefer to see the lights flash off, then back on when the ISY reboots. Let's me know all systems are go. Choose what works best for you.
  20. You should consider stepping up an enterprise level open source firewall, which can monitor a WAN connection and failover to a cellular backup if you are having so much trouble with your current provider, and/or switch providers. https://pfsense.org runs on almost any x86_64 hardware, including virtualized. Orders of magnitude more capable and flexible than cheap consumer [redacted]
  21. Why not just use the time offset since dusk/dawn based on your location? Infinitely more reliable than a Rube Goldberg contraption
  22. I don't have a single program set to run at startup and have all the other checkboxes enabled. Upon reboot, any time of day event driven lights will momentarily turn off, then turn back on.
  23. I have a MeLE 3C running Ubuntu 24/7/375 Keep in mind the finned top is actually plastic, not aluminum. Make sure it is well ventilated on all sides. root@mele-ud22:~# sensors coretemp-isa-0000 Adapter: ISA adapter Package id 0: +47.0°C (high = +105.0°C, crit = +105.0°C) Core 0: +41.0°C (high = +105.0°C, crit = +105.0°C) Core 1: +41.0°C (high = +105.0°C, crit = +105.0°C) Core 2: +41.0°C (high = +105.0°C, crit = +105.0°C) Core 3: +41.0°C (high = +105.0°C, crit = +105.0°C) acpitz-acpi-0 Adapter: ACPI interface temp1: +27.8°C (crit = +119.0°C) nvme-pci-0200 Adapter: PCI adapter Composite: +39.9°C (low = -0.1°C, high = +84.8°C) (crit = +94.8°C) Sensor 1: +40.9°C (low = -273.1°C, high = +65261.8°C) Sensor 2: +46.9°C (low = -273.1°C, high = +65261.8°C) Sensor 8: +40.9°C (low = -273.1°C, high = +65261.8°
  24. During a momentary power outage, the ISY loses communication with the PLM and frequently locks up. I’ve always found that it is better to not put the ISY on UPS power and just let it reboot.
