Everything posted by johnjces
Upgrading from old upgradable version to 7.0/7.1
Thank-you!!!
Does the latest update to 7.0/7.1 require the 6.x upgrade first? Or will the update do the full upgrade from 5.9.1 to 7.1. Just wondering about the sequence of events for those units not getting upgraded yet. Sometimes you have to update then do update again to get caught up. I still have one eisy on 5.9.1 that I won't get to until mid November. I had great luck with my local eisy from 5.9.1 to 6.0. will move to 7.1 in the next week or so on my local unit. Thanks. John
Kind of scary. Update to 14.3/IoX 6
@jkmcfadden I do not have any zwave stuff yet. All insteon but the time is coming when I will need zwave items such as for one, motion detectors. The insteon motion sensors just don't work well. Don't think insteon has revealed all the coding aspects to UDI on some of their products. I am also not an early adopter or upgrader. My guess is by now, udi has worked out most all of the upgrade kinks we have been following. Please keep us posted. John
Well, I couldn't wait and checked the sysconfig.txt file and showed everything up to date. Looked at the UDM and showed the same so logged in and WOW! everything was there via the java appet. Up to date. Logged in via the web and all seemed good. PG3 was running, my notifications were working so far so good! I was prepared for a looong process but 12-13 minutes?! Good job UDI! My wish is that this wasn't, or so it may seem, going out to the cloud for logins via portal logins. I would like my old username back for both. I can sort of understand the change for the java applet but the web browser? But it is acceptable. I have one more to go in about a month as it is remote. Hope I have the same luck. John
I did all the checks to ensure my eisy was previously updated to the most recent versions, backed everything up and started the upgrade. My UD Portal signaled upgrade in progress several times, stopped pg3, told me my eisy rebooted and then told me that my node server was back up. What scares me is this took only 12 minutes. I am fearful of trying to log on lest I interfere with the process. How long should I wait? 2 hours? Thanks John
ANDs and Parenthesis'
@apostolakisl Thank-you! John
Thank-you sir!
I have three (3) ANDed conditions that must be met before an action, (THEN), can occur. what is best practice in IOX. As I recall from past programming in IOX parenthesis' must be used for ANDing or ORing at times. XOR and XAND. I always get this stuff mixed up these days! So, is the following best, (pretty exclusive that the first two conditions must be met), practice... If ( 'Double Garage Door-Sensor' Status is On And $Can_Close is 1 ) And $s_GarageDoorIsOPEN is 1 Then ..... or is the code snippet the next best method to ensure that all 3 conditions are in fact met. If ( 'Double Garage Door-Sensor' Status is On And $Can_Close is 1 And $s_GarageDoorIsOPEN is 1 ) Then .... Thanks!! John
Replaced IOLinc All works but Amazon Alexa (Echo).
Bummer.. but understood.
I did that, discover devices, but Alexa will only see what the Portal shows from my understanding. From what I understand, I need to remove it from the portal and reconfigure? There is no way to edit an existing Spoken? When I try in the Portal; Alexa Spokens page, no address is even shown, (even tho the list of all devices shows an address) and when I try and edit it the select box is not enabled for device. Thanks for the reply!
I just replaced a bad IOLinc in my garage as the heat in AZ has finally cooked it. I had no problem replacing the old with a new IOLinc and all works via Agave and via the eISY JAVA GUI and I can open and close the door and show status via the Portal. However... The Portal for spokens shows the old device's address and not the new one and Alexa won't tell me the garage is opening or closing. How do I force a portal refresh of all devices? Thanks! John
Removing Device From Folders Prior To Using Replace
I worry too much. That was a piece of cake!
Please forgive a probably simple yet stupid question, (I am known for them), as I try hard not to have any issues in doing things to my eISY and home setups. This morning I was replacing a bulb in my aged dining room 'chandelier' and in screwing in the bulb there was a pop and my Insteon 6 button dimmer part of the Keypad fried. In all probability just the SCR and associated circuitry, as the keypad stayed lit and it did not pop my circuit breaker. All the other buttons still do thier job except for ON and Off. It appears that in screwing in the bulb, as over the last 40 years, the socket base must have loosened and in screwing the bulb in the wires crossed. Ugh. In reading up on using Replace within eISY, it stated to remove the device from any folder it belongs in. Just so I fully understand; I have the device and buttons in several scenes within the Scenes folder. By removing the keypad and associated buttons from the scenes folder, that's all I need to do. I do not delete the scenes. (First Image) Should I Ungroup the Dining Room Group? (Second Image) Lastly, if all goes to plan, will the scenes all be properly associated with the new device? Then just put them back in the Scenes Folder? Thanks for your understanding and help. John
Saved from flooding!!!
I have been a UDI/ISY user and supporter for... I don't know how long. Started with the ISY 994 so maybe at least 10 years ago and upgraded to the eISY about 6 months after it came out. Since we are away from home, a lot, I purchased some of the inexpensive Insteon Leak Sensors, (2852-222), and installed them under my kitchen sink as that seems to be the place where I have had most of my problems with drips and an occasional minor leak. (Did I mention I hate plumbing). We also placed mats under the sink that will hold about an inch of water just in case. Lastly, I used the "recipes" (code) in the pdf version of the ISY cookbook for these leak sensors. The code and sensors were tested and it worked. And boy did it! https://docs.universal-devices.com/production/The%2BISY994%2BHome%2BAutomation%2BCookbook.pdf Today I was happily trying to find the end of the Internet when the siren in my phone went off, (thank you for UD Mobile and Notifications), which alerted me that a leak was detected. OH MY GOSH. In the moment it took me to get up and get to the kitchen, that flood mat was filled up! Something popped in one of my RO filter seats. After re-seating my filters and checking the water, the water pressure was beyond amazing. A call to the city was made and I was told that they were flushing water lines in our area which can cause a rise in water pressure and boy did it rise! Had we not known about this leak or not been at home, some pretty extensive damage could have occurred. We are fortunate that we have great neighbors and friends who we could call and who would check and shut the water off if we weren't home. Flood averted. THANK-YOU to UDI and Insteon! John
Release 5.9.1 discussion
Holy Smokes! Adding a Matter device even a simple Matter WiFi device seems like a real PITA right now. Hopefully UDI will come out with a really good HowTo Wiki page in the near future. UDI, please? This has been eye opening. John
All the 'Matters'
Since I upgraded my eisy to the latest OS and IOX and having a look around UDM, I have to ask a few more questions about Matter on WiFi. I am a bit confused about WiFi Matter vs ZWave Matter, which I 'think' uses the RF ZWave dongle. I was looking through the UDM and found where one can add a Matter device. When trying to enable it to see what might happen next, it pretty much told me that I have to have the ZWave dongle or hardware or something attached. Is this true? Must I have the ZWave dongle to use WiFi Matter? Just some WiFi Matter compatible light bulbs. I have no reason not to by a dongle or two, but when I am slowly learning, I don't want to have hardware that I may not use since I am 99% Insteon... so far. OR, is there a full wiki yet or "how to" somewhere on how to enable WiFi Matter devices and create a node and exactly what is needed? Thanks again for all your help and information. John
WOW! That was just too quick and easy! Everything seems to work, OS updated, and IOX updated as well. One more to go next week. Just reporting... John
Looks like I won't be an early adopter! How long did this upgrade take for those of you that were successful? Thanks. John
Has a Date Been Set?
I have been scouring the forums and trying to keep an eye on when the January 2025 OS upgrade along with Matter support and other cool stuff will be available. All I know is January. https://www.universal-devices.com/2025-liftoff/ Has a release date been set? What order of upgrade? OS first then IoX? Does the mobile app in its last update have the graphing ability now? I'm certain full information will be forthcoming but trying to plan on the upgrade and find time to work out any issues that might occur. Thanks for any info. John
All the 'Matters'
@Goose66 This too is what I am hoping for as, for right now, I have no need of zmatter/zigbee stuff and desiring direct wifi to matter. And a dongle, IMHO, just adds another layer of complexity, if it were to be required. I must give kudos to the UDI team for working on all of this so diligently! I think the wait will be worth it! John
All the 'Matters'
Thanks Guy! I am hoping for an accurate answer to my query as well as the unknowns you mentioned. Maybe one of the UDI folks will respond after the Holidays... or sooner! John
All the 'Matters'
With all the Matters, I guess only a couple really, I have two stupid questions which I am just unclear about. UDI is coming out with a pretty major upgrade in early 2025 for our eisys and it includes, "...Link WiFi-based Matter switches/plugins directly." 1). What does this mean, "Link...directly"? 2). Do I need to purchase the ZMatter USB dongle to utilize WiFi/IP based Matter devices? Such as those Matter based WiFi light bulbs and more, that hook up to your WiFI network, not a wireless connection from the dongle. Thanks! John
UDM Shows I Have Notifications But None Are Showing
A user preference would be great! I am always an oddball it seems!
@Javi I stand corrected.. If I go to Home and change accounts there, the results are the same. When I go to notifications and change accounts I can see the notifications! And can delete them! Yea!! Is this now new normal behavior. One must change accounts to delete and see the notifications? I certainly liked being able to see notifications from any account/device no matter what account I'm in as some notifications from the account I am not in or viewing might be critical! Is this a new "feature"? I don't recall this behavior a couple weeks ago. If this is new please then add a View All and Delete All. This would lessen confusion for most users I might assume... Or go back to what it was some time ago to fewer steps and a little less code. I guess I'm the only one finding this annoying and not a fan. Oh well. I do wonder how and why things change and must have been from user feedback? Thanks! John
@Javi I have done that a bunch of times too in just general use and in trying to see which device might cause this if that might be the cause. In any event, There is no change in the results. What ever account I am in, it displays the same results and numbers in both accounts. I have gone into app settings and cleared the cache but not data. John
