Setting Up ISY with no ISP
matapan
What steps does one need to follow when setting up ISY to run on a home network with internet service subscription? Can anyone speak to how a router should be set up to run in this environement, if it even works? Thanks.
Michel-
I think he is asking about setting up an ISY with no internet available. I was thinking disable NTP but not sure if there is anything else that should be done for a LAN only setup. I know the ISY calls home to check for firmware updates and module installs. Not sure how it ill behave when it can't make the connection back to UDI.
Michel-
Gotcha. That makes sense. I have to remember that there is more than one piece to this puzzle.
Still wouldn't having NTP enabled cause DNS lookup errors / fail to connect errors in the log? Certainly the NTP stuff happens in the ISY rather than the console right?
      378.9k
