jerlands Posted March 10, 2013 Posted March 10, 2013 Greatly appreciate all the help here but.. I'd like to see the topic "Wiki Feedback" or equivalent. I see an issue with the program "Light Data" in that "Stormy Days" will not run if Module 'Climate' Light doesn't exceed value within the folder "Everyday" time conditions. The following day "Wait to Change Outside Lights" status will have remained False and "Stormy Days" doesn't run. I've also seen an error with instructions for the motion detector (which was corrected I believe.) People could comment and offer suggestions or corrections to the resource. Thanks, Jon Light Data http://wiki.universal-devices.com/index.php?title=ISY-99i_Series_INSTEON:Light_Data_Program
Michel Kohanim Posted March 11, 2013 Posted March 11, 2013 Hi Jon, I am so very sorry but can you elaborate please? The program Everyday is predicated upon time being between sunrise and sunset the same day. What does this have to do with the next day? With kind regards, Michel
jerlands Posted March 11, 2013 Author Posted March 11, 2013 Hi Jon, I am so very sorry but can you elaborate please? The program Everyday is predicated upon time being between sunrise and sunset the same day. What does this have to do with the next day? With kind regards, Michel Could be I'm confused .. I'm using a variant of the program, lights are not in a Scene because I use the lights in other programs that operate throughout the day and night. If after sunset and the program "Wait to Change Outside Lights" has a False status i.e., "Stormy Day" ran last, it will remain False into the next day. "Clear Day" is the only means of changing the status of "Wait to Change Outside Lights" to True. If the Scene has changed to off by another program (lets say running for evening lighting) and the day begins off as Dark and Cloudy, "Stormy Day" will not run because of the "False" status of "Wait to Change Outside Lights." Like I say... could be I'm confused but this has been my observation. Jon
Michel Kohanim Posted March 12, 2013 Posted March 12, 2013 Hi Jon, I think I understand what you mean but perhaps differently. Basically "Wait to Change Outside Lights" will only work if there's an alternating dark/clear. So, when the folder turns false (sunset), there are no other programs that can toggle the status of "Wait to Change Outside Lights" and thus it may never run again. Let me check with Subroutine and see if I am getting this correctly. With kind regards, Michel
jerlands Posted March 12, 2013 Author Posted March 12, 2013 Hi Jon, I think I understand what you mean but perhaps differently. Basically "Wait to Change Outside Lights" will only work if there's an alternating dark/clear. So, when the folder turns false (sunset), there are no other programs that can toggle the status of "Wait to Change Outside Lights" and thus it may never run again. Let me check with Subroutine and see if I am getting this correctly. With kind regards, Michel The program gets stuck under certain conditions. It would make things easy if I could change the status of a program directly without calling "Then" or "Else." Like... If From Sunset + 5 minutes To Sunset + 6 minutes (same day) And Program 'Wait to Change Lights' is False Then Set Program 'Wait to Change Lights' to True Else - No Actions - (To add one, press 'Action') I'm using a not so elegant method that seems to work.. Clear Wait to Change Lights If Program 'Wait to Change Lights' is False And Module 'Climate' Light <= 5 And Program 'Stormy Day' is False And Program 'Clear Wait to Change Lights' is False Then Run Program 'Wait to Change Lights' (Else Path) Else - No Actions - (To add one, press 'Action')
Sub-Routine Posted March 12, 2013 Posted March 12, 2013 Hi Jon, I am so very sorry but can you elaborate please? The program Everyday is predicated upon time being between sunrise and sunset the same day. What does this have to do with the next day? With kind regards, Michel Could be I'm confused .. I'm using a variant of the program, lights are not in a Scene because I use the lights in other programs that operate throughout the day and night. If after sunset and the program "Wait to Change Outside Lights" has a False status i.e., "Stormy Day" ran last, it will remain False into the next day. "Clear Day" is the only means of changing the status of "Wait to Change Outside Lights" to True. If the Scene has changed to off by another program (lets say running for evening lighting) and the day begins off as Dark and Cloudy, "Stormy Day" will not run because of the "False" status of "Wait to Change Outside Lights." Like I say... could be I'm confused but this has been my observation. Jon Hello Jon, You are correct. I use a schedule to turn the lights Off in the morning. If Time is Sunrise + 15 minutes Then Run Program 'Wait to Change Outside Lights' (Else Path) Else - No Actions - (To add one, press 'Action') Thank you for pointing that out. Rand
