testing for control on all switchlincs
bbrally
I'm trying to write a program where the condition is the on or off of any the switchlincs in the house. Is there a better way of testing this condition other than an "or" statement for every on or off command such as below? I have so many switches that this seems rediculous.
Control 'Basement' is switched Off
Or Control 'Basement' is switched On
Or Control 'Basement slave' is switched Off
Or Control 'Basement slave' is switched On
Or Control 'Den' is switched Off
Or Control 'Den' is switched On
Or Control 'Den slave' is switched Off
Or Control 'Den slave' is switched On
Or Control 'Dining Area' is switched Off
Or Control 'Dining Area' is switched On
Or Control 'Fireplace' is switched Off
Or Control 'Fireplace' is switched On
etc....
etc....
etc....
That is the way it is done. Note that If Control is looking for an Off command from each device. It sounds like you want to know if a device is On or Off which is determined by If Status.
That's a lot of conditions......
I'm wanting to test if a switch has been pressed, on or off. The if control seems to be working for that.
Thanks for the confirmation.
I have a "Control event detection" routine as part of my occupancy programs. This is exactly how it works. Lots of If Control Switched..." statements ored together. Nasty to look at but seems to function just fine. I have two lines for most switches (On/Off) and four lines each for a few dimmers that see fade up/down regularly.
FYI I've asked (in the programming improvements area in the past) for the ability to write a program like this based on a scene and have the ISY internally 'break it out' into the list of individual devices (so that if you update the scene membership the program would automatically update).
E.g. is control 'All Light Switch Scene' is on and internally the ISY would generate a list much like what you wrote above. We shall see if it is considered...
      38k
      379.4k
