Cannot backup ISY - Could not retrieve file /CONF/172.PRP
I just upgraded my ISY 994i/IR Pro from firmware v3.3.10 to v4.0.5. I noticed that the backup performed during the upgrade processed failed. Luckily, the upgrade appears to have worked as I am now running at v4.0.5 and all appears OK. I then tried to backup again. And again it failed where I received a popup message 'Could Not Retrieve File /CONF/172.PRP'. After clicking OK on this message, I receive another message 'Could Not Create the Zip File.' When I look in the PC folder where I was going to store the backup file, there is a file there but it is only 1K in size.
Any ideas on what is causing this and how to clear it?
That took care of the issue.
Thank you! :D
