I have a 16pt Elk expander. Up until now I was using just the first eight inputs. The ISY showed 24 inputs( the first 8 of the expander). I just added "enabled" input 25 and 26 but the isy does not show them. What am I missing? I have the elk module. how do I force it to show the other 8 inputs?
Ok i got them to import BUT even though the voltage changes in the ISY it does not report the status correctly. Elk says violated ISY says normal.
Why is something so simple so difficult.
yes about 100x it does not always update but eventually does. Still have issues with updating elk IO elk says one thing ISY says another. I had one instance where i disarmed elk from the keypad bUT ISY said still armed. Also elk "web" keypad said still armed.
argh why can't it all work as advertised.
If tee elk web keypad isn't showing the correct status, then that sounds like it might be an issue with either your m1xep. Try unplugging it, leave it disconnected for 1 minute, and see if that helps. The m1xep can be so NM rebar tempermental.
Sent from my Nexus 7 using Tapatalk 4
Argh More elk IO stuff. After I get the new ELK IO to show in the ELK status tab. It will not show when I try to select the Zone from the programming tab
Now that I have left the site (not on local network) I can not refresh the topology. Says Elk disconnected. Yet it seems to connect (report alarm status and other info). In the elk configuration tab the address was the IP address of the elk on the local net. now that I am away I tried changing it to a mapped address "URL"
I hate stuff that does not work as advertised
I have another issue with the elk web keypad it that it only Occasionally shows the correct status. It was once always correct.
