ISY Java Application Question
Hello Guys!
Last night I added a video surveillance system to my network. The accompanying software made changes to my router setting it up automatically. Since installing the VS system my ISY has been acting a little strange. I can control things with mobilinc at home and away. I can also access the ISY via the IP address then clicking admin console both at home and away (https) but the admin console will not start simply by double clicking on the java application on my desktop. Then I double click it....the small blue window comes up but it's blank. The small blue window used to have the IP address in pink at the top. How can I get it to work again?
BTW, the VS system was setup using ports 80, 8000, and 1050. Again the VS software did this automatically. Today I changed 80 to 1025 since my ISY uses 80. This didn't seem to help though.
Any suggestions?
Thanks! :P
After fooling around with it just now it is working. I had to "Load" the url in the ISY finder. It's working but should I do anything else? Never had to do that before.
