Can the Insteon IP Camera be controlled by the ISY?
Hi,
Does anyone know if the INSTEON Wireless Security IP Camera (Item #75790WH) can be controlled by the ISY? I am open to any type of solution that enables me to trigger the recording or taking pictures based on motion detected by the camera.
John
The Smarthome "Insteon" camera is just a rebranded Foscam camera. If you have the UDI Network module installed in your ISY, you can create network resources to control the camera position, enable/disable record on motion and manage other aspects of the cams.
