biredale Posted August 22, 2013 Posted August 22, 2013 Hi all.. I am trying to use my KeypadLinc 4 scene buttons to be a passive display of on/off conditions. For example, if my motion detector is activated I want one scene button to light up. I tried using the Then action when motion detection is enabled as; Set 'KeypadLinc - A' On Nothing seems to happen, is this possible and has anyone had any luck with something like this? Thanks! Brian
oberkc Posted August 22, 2013 Posted August 22, 2013 I recall cases where secondary keypad buttons will not respond from commands such as this. Perhaps including the keypad buttons in a scene (even if only device in the scene) and controlling the scene via program would work.
Xathros Posted August 22, 2013 Posted August 22, 2013 Brian- The secondary keypad buttons cannot be controlled directly like that. You will need to create a scene for each button that you want to use this way. Create a scene and include the button as a responder (or controller if you want). Then call your scene with the program. In the case of your example, you don't even need a program. Just make the motion detector a controller in the scene with the button. -Xathros
biredale Posted August 22, 2013 Author Posted August 22, 2013 Ah.. Thanks guys, will give that a try. Thanks! Brian
biredale Posted August 23, 2013 Author Posted August 23, 2013 That worked perfectly.. Thx! Thanks! Brian
