Turning off keypad button
Hi,
I have two keypads, one is an 8-button and one a six-button. In both, I have a couple small buttons controlling various light fixtures.
The problem I have is:
I have one of the buttons (Dinner) set to enable a scene for dinner. It turns on 3 lights at a set brightness. When I do this, the KPL buttons that control each of those lights individually lights up to the "on brightness" which is fine.
I also have a program to turn off the dinner scene if I double-press Dinner, it will turn off each of the three lights. It does this properly, however, it leaves the buttons for each of those lights *ON* on the keypad.
I modified my Dinner OFF program so it would not only turn off those 3 lights but also set the KPL buttons for those lights to "Off". Still, it leaves them set to "on brightness" when double-press the Dinner button (the 3 lights do turn off properly though).
Any idea how I can turn off the KPL buttons for those three lights when this program is run to turn off the dinner scene?
Vinnie
Secondary KeypadLinc buttons cannot be turned On/Off with Direct commands. Assign the KPL buttons as Responders to an ISY Scene and turn the Scene Off.
Try making a scene that contains all the lights you want off and the KPL buttons you want off, then have the program turn that scene off when you double click it.
