How do I start again
Obviously there's something in my system or house that doesn't want me to have the ISY run smooth.
I log in today and all my devices are set at a ramp of 9 min and a local load of 0.
So..
how do i reboot the ISY and start discovering devices so i can start again.
The GUI won't open my backups for my programs or timers or my backup.
Still not losing patience (maybe my mind, though)
Drew
Drew,
I replied to your "other" post regarding the ISY being in safe mode.
It sounds as if your PLM may have "locked up" and is not communicating with the ISY.
Please try cycling power to the PLM (10 sec power interrupt) to see if it recovers. If you are using a ISY-26, remove power from the ISY first.
IM
So..
Drew
Thank you IndyMike
I've never had a PLM lock up.
What makes it do that? Surge? Is there any way I can get it to not do it in the future?
No big worry as it seems like a simple fix to power down.
Thanks again.
Drew
Drew,
If this has happened without any external intervention, then I would worry about it: you will have to find the cause. Can you think of anything that might've powered down your PLM?
Thank you IndyMike
Thanks again.
Drew
