AT&T to end email-to-text ×
Cannot detect a replacement INSTEON 2473S OutletLinc
ricke
I have a number of INSTEON OutletLincs throughout my house that I use a lot at this time of year for controlling Christmas lights around my house.
I've had consistent issue with a single OutletLinc that would only respond to On/Off during a scene about 40% of the time. However if I manually turned the device on/off using the ISY99 admin console, it always worked.
So I just replaced it with a brand new INSTEON 2473S OutletLinc and for some reason I can't detect it.
I put the admin tool into linking mode and then held and pressed and held the Set button on the OutletLinc for 10 seconds to put it into linking mode.
I clicked Finish on the admin side yet it does not seem to detect the device and when I go and look at the OutletLinc, its still blinking.
Any suggestions on what I can try to make sure I can get it detected and linked?
I have a lot of INSTEON devices and repeaters so I would expect I should have a strong mesh by now enabling communications.
Rick
Do you have any access points, confirmed on opposite legs of your electrical system? Is your PLM a dual band version? Is your PLM plugged into the same circuit or outlet as a bunch of other computer devices? Is your PLM pluggedinto, or next to, a surge suppressor or UPS?
For now, you can run an extension cord from the always-on outlet of the outletlinc into which plug the plm. Can you now add the outletlinc?
