Device Manager not working
fyi: I am VERY new to the isy
When I open device manager I see three columns. my devices, my scenes, my folders. when i click the configurations icon, nothing happens. What am I doing wrong.
Devices I expected to have conectability:
FIOS box connected to global cache.
PS3 connected to modem via ethernet
Logitech Harmony Hub
Michel,
I registered the isy994izs/ir at your direction. I am using url http://192.168.1.111, based on the static ip i set.
This is what happened when i did a diagnostic on the PLM
When I go into Link management then Start Linking, nothing happens. no error message. nothing. is there something i have to do on the control end? i thought that since my ps3 (via ethernet) and my tv & Fios box (via the gc100) were connected to the network that they would show up automatically. Am i missing a step?
The ISY does not list devices on the local LAN.
Also when Start Linking is clicked a popup window should display. The lack of the popup window could indicate an issue with the AV being used. What AV is in use?
global cache, ps3, harmony, and fios don't link to ISY.
You can send commands to a global cache using the network module, and harmony can send IR commands to ISY (if you have the ISY IR model).
is there a link that explains how to go through the global cache to harmony…or can you outline how to do that.
What Harmony do you have? I do believe some of the new ones have network accessibility.
Anyway, you need the ISY network module to send any network commands to anything. I know for a fact that you can send network commands from ISY to GC units as I have one of the wf2ir models. I have a harmony 890, but it has no network accessibility.
Hi modex,
I do not think you have purchased the correct unit. ISY is an INSTEON/X10/Zigbee (and lately Z-Wave) controller. You can use network resources to communicate with devices on the network. This said, the focus is INSTEON and Z-Wave.
Do you have a PLM attached to ISY? If so, can you tell me what you get when you go to Tools | Diagnostics | PLM Info/Status?
