Portal maintenance - October 2 - 4am-5am Pacific ×
SSL handshake Android Chrome
dfetzer
Hi
New to the forum and trying to access my isy994i remotely. I am successful reaching the web interface hitting my direct IP but Android chrome is complaining that its an unmatched cert and I have to click proceed anyway. Well, I tried creating a self-signed cert using the local address as the host 192.168...etc, but is that actually supposed to be my direct IP instead? I have HTTPS server and client settings at TLS 1.2 and 1.0 respectively.
When I launch the URL via HTTPS android chrome states the identity not verified, server cert does not match UL, non trusted cert, It says that the connection is using ssl 3.0 yet I set up the client settings to TLS1.0 and it also complains that the server does not support TLS 1.0
I am trying to use tasker to call an insteon URL to shut off lights using autovoice but if I have not accessed in some time, it will open the URL and then request that i proceed anyway with this unverfied cert. Also doing the same with llama so that when I reach home it instantiates scenes for my arrival by calling https://my ip:my port/rest/nodes/16431/cmd/DON
What am I doing wrong?
Appreciate any help
Hi dfetzer,
Hi
It should be the URL/IP address that you use to access ISY from your Android
You will always get this unless you use a certificate from a Certificate Authority (CA)
Are you certain the server settings are set to TLS 1.2? Do you have an ISY994i PRO Series?
  • 2 months later...
appreciate the response...So I am still looking into the CA signed certs. You mentioned this in another thread:
Use your own domain, setup a CNAME record for 'isy.yourdomain.com' pointing to 'yourhost.dyndns.org'.
Request the cert for 'isy.yourdomain.com', you'll get the email to an address you control.
This is exactly what I do.
Michael.
I just would like to use IP address and not run through dyndns - I don't want to pay anything if I can get around it. Maybe that is impossible. I used to use dyndns back about 2002, would rather just hit my IP for now. If I use IP I assume I dont need cname etc. I requested the cert through the ISY but I never received anything...Sounds to me like I need a domain, pay for hosting, point an alias from ISY to dynamic dns domain and then I can request the cert??? How exactly do I need to request this cert, and then use the wiki for installing cert in ISY?
I need the 'how to do not get the cert error for dummies' edition using just my static IP address.
i see this:
If you have already made a Cert Request (#d) and have now been given an actual
certificate based on your Cert Request (CSR), (I HAVE NOT RECEIVED THIS - how long does this take?) then
click on the Receive Cert button to import the Certificate into ISY.
