Setting Up ISY
I am setting up my ISY and have encountered a problem with access using the external IP address. The app loads and gives me access to my devices and scenes but when I attempt to access the admin console I get the message "Error. Click for details." When I click I get the following:
Java Plug-in 10.51.2.13
Using JRE version 1.7.0_51-b13 Java HotSpot 64-Bit Server VM
User home directory = /Users/dwheeler
c: clear console window
f: finalize objects on finalization queue
Resource http://crl.globalsign.net/root.crl has future expires: Wed Jan 29 15:57:58 EST 2014 update check skipped.
g: garbage collect
h: display this help message
l: dump classloader list
m: print memory usage
o: trigger logging
q: hide console
r: reload policy configuration
s: dump system and deployment properties
t: dump thread list
v: dump thread stack
x: clear classloader cache
0-5: set trace level to
Yes, I am on my home Wi-Fi and testing the external URL.
I tried the URL and Safari said it could not find the server.
The WiFi is on the local LAN. The ability to send an external IP address on the LAN side depends on whether your router supports that. Does your router accept an external IP address from the LAN? Since it did not work it sounds like no.
It did when I used the SmartLinc. In fact, I never used the internal IP while at home or away; I always used the external IP. The router is an Airport Extreme.
I now have an icon on the desktop that takes me directly to the admin console. Will I be able to use that icon when I am not home, i.e., will it give me remote access?
  • 3 weeks later...
Michel:
I am sorry it has taken so long for me to get back to you with this question, but I have been in and out of the hospital.
Where and how do I post the URL?
Hi smokegrub-
Open the admin console using the applet on your desktop. After it opens, minimize the console screen. You should find the smaller ISY Finder screen hiding behind the console. Click the Add button and filling the URL for your ISY using the external IP address or DynDNS address.
-Xathros
