INSTEON I/O Linc Doorbell Kit Flash Lights Then Return
Hi,
I am brand new to ISY and INSTEON. I purchased the INSTEON Doorbell and Telephone Ring Alert Kit and I am trying program my SwitchLinc Dimmer to flash the lights when doorbell rings but return lights to previous state. So for example, if I am watching movie with lighting at 30% brightness I want it to flash full on and full off but return to 30%. How do I accomplish this?
My program currently looks like this:
Control ‘Device A’ is switched On
Repeat 2 times
Set ‘Device B’ Fast On
Wait 1 Seconds
Set ‘Device B’ Fast Off
Wait 1 Seconds
Hi DAlba-
You need two programs for this.
First:
f
Run Program Flasher (If Path)
Program: Flasher (Disabled)
if
  Status Device B is Off
Repeat 2 times
Wait 1 Seconds
Wait 1 Seconds
Repeat 2 times
Wait 1 Seconds
Wait 1 Seconds
Very important: Make sure the flasher program is disabled!
-Xathros
Thank you for the response Xathros. I tried that but it doesn't seem to return lights back to previous state. For example, if lights are at 30% I would like it to flash but return to 30%. Right now it either ends in Off or On.
What am I missing?
The exact previous state cannot be stored and reused today. Perhaps in a few months Variables will be updated with that capability but that is only speculation at this point. The best you can do is use a set of Programs ...
If Status 'xxxx' => 20
and Status 'xxxx' <= 40
do the flashing
Set 'xxxx' 30%
  • 1 year later...
do the flashing
Set 'xxxx' 30%
Hi,
I haven't really kept up with this stuff. Just wondering if variables have been updated yet to allow this capability?
thank you
No but that capability is just around the corner I believe.
-Xathros
  • 7 months later...
It's in beta version 5.x... It's beta though - currently with some rough edges.
In the latest 4.x version, you can use the network module and variable substitution to do the same thing.
