Bxsteez Posted February 27, 2014 Share Posted February 27, 2014 Does anyone know if the Z-wave module is compatible with z-wave motion sensors? Link to comment
Michel Kohanim Posted February 27, 2014 Share Posted February 27, 2014 Hi Bxsteez, Yes but in 4.1.3 to be out in couple of weeks. With kind regards, Michel Link to comment
Bxsteez Posted February 27, 2014 Author Share Posted February 27, 2014 Hi Bxsteez, Yes but in 4.1.3 to be out in couple of weeks. With kind regards, Michel AWESOME!! I'm not sure if the Z-wave motion sensors are better than insteon but they do look better and there are far more options. Link to comment
fbelg210 Posted February 28, 2014 Share Posted February 28, 2014 I am new to ISY's. I have ADT Pulse with a front door keyed entry system (which is Z-wave). I saw that the isy has a Z-Wave module which I have installed. However, I think it need a Z-Wave Dongle. Which one should I get. I want to be able to have my ISY994 control the door lock. Is this possible? Frank Link to comment
Xathros Posted February 28, 2014 Share Posted February 28, 2014 I am new to ISY's. I have ADT Pulse with a front door keyed entry system (which is Z-wave). I saw that the isy has a Z-Wave module which I have installed. However, I think it need a Z-Wave Dongle. Which one should I get. I want to be able to have my ISY994 control the door lock. Is this possible? Frank Hi Frank- The door locks are most certainly possible. Not so sure about the ADT keypad. I suspect that will be a problem. For the dongle, you need the "Z-Wave Assembly Kit" from UDI. Go here: http://www.universal-devices.com/sales/products/ and scroll down to accessories. -Xathros Link to comment
fbelg210 Posted March 1, 2014 Share Posted March 1, 2014 I am new to ISY's. I have ADT Pulse with a front door keyed entry system (which is Z-wave). I saw that the isy has a Z-Wave module which I have installed. However, I think it need a Z-Wave Dongle. Which one should I get. I want to be able to have my ISY994 control the door lock. Is this possible? Frank Hi Frank- The door locks are most certainly possible. Not so sure about the ADT keypad. I suspect that will be a problem. For the dongle, you need the "Z-Wave Assembly Kit" from UDI. Go here: http://www.universal-devices.com/sales/products/ and scroll down to accessories. -Xathros Thanks Xathros.. They have other USB dongles. Can I use that instead? Or is this the only way. Frank Link to comment
Xathros Posted March 1, 2014 Share Posted March 1, 2014 The ISY does not support usb connected dongles. There is an expansion connector inside the ISY to accept the ZWave daughter board. -Xathros Sent from my iPhone using Tapatalk Link to comment
Bxsteez Posted June 15, 2014 Author Share Posted June 15, 2014 So it seems 4.1.3 never came out but 4.2.x did. Does it support Z-wave motion sensors? Is there a place I can find a list of supported Z-wave devices so I don't have to buy, try and return? Link to comment
Michel Kohanim Posted June 15, 2014 Share Posted June 15, 2014 Hello Bxsteez, Unfortunately such list does not exist simply because ISY supports most high level command classes exceptions are: - Multi-Channel devices such as remote controls - Scenes Motion sensors should be supported. With kind regards, Michel Link to comment
