Programs stopped running last night
Something strange happened on my ISY last night at around 02:00...
My regularly scheduled programs all stopped running!
when entering the program summary section of the admin console I noticed that all the time last started and time last finished entries were empty! The same was true for the scheduled next run time.
The only entry that was still in there was the 03:00 entry for the query all process. It was almost as though the ISY had rebooted - but it had not.
Could this be something related to the change in DST?
I could understand it if some of the programs had stooped due to the time suddenly jumping by 1 hour ( as the test is time last run plus 15 mins) but it doesn't explain why all the time entries were blank in the admin console.
My apologies, I should have been more clear.
My run times were blank until I manually ran the "If" statement, but the programs still work as they should, I just tested one.
Now, that was an sensor-based program (I opened a monitored door), not a time-based one.
The next time-based event will be sundown, and I'll check this evening to be sure that ran.
The OP indicated his programs weren't at all, apparently
(I.... may have the same problem, come to re-read his post, but I won't know until roughly sundown.)
I know my 4:50AM and 8:00AM programs ran today.
They are showing Status False and the Last Run and Last Finished areas are blank.
All the Next Run Times are showing a valid correct time for them to run.
Hi Michel
This one stopped running after 2:00 AM:
Repeat Every 3 minutes
Set Elk Zone 'OutLightLevel' Query Voltage
And this one didn't run but it was set for 2 AM so I changed it to run at 1:45AM from now on.
Time is 2:00:00AM
Set Scene 'Outside Lighting / Low Voltage Lighting' Off
Gary
