ukbjorn20001 Posted April 6, 2014 Posted April 6, 2014 I have a feeling that this may be a common question, but I couldn't find anything in the forum, so I apologize in advance. I have a large client site where we are making extensive use of the network module for the ISY994/Pro. (TV power, Shade control etc). I have hit a big road block, a number of the keypads installed throughout the home do not show their current status (or do not update when their is a status change), so my programs never get activated. units in question are 2486D v.41 2487S x.41 2334 x.43 It is weird, some switches correctly reflect status, some don't. I have tried everything from restoring the device, to removing it from the ISY altogether and re-adding it with no joy. Thanks in advance for your help.
oberkc Posted April 6, 2014 Posted April 6, 2014 The only thing that I can think that would cause this is a failure in communication between devices and PLM.
Michel Kohanim Posted April 7, 2014 Posted April 7, 2014 Hello ukbjorn20001, In addition to what oberkc correctly noted, it might be the case that your PLM has reached the max number of supported links (beyond which you will not get status updates from your devices). Please go to Tools | Diagnostics | Show PLM Link Table, click on Start , wait for completion and then click on the Count button. If the number is anything above 800, then you need to reduce the number of scenes you have. Especially, you need to merge scenes where most of devices are common with other scenes. If you are still having any problems, please do not hesitate to contact our tech support team (links below). With kind regards, Michel
ukbjorn20001 Posted April 25, 2014 Author Posted April 25, 2014 Hi Michael, I am back on site today and ran the PLM Links test you suggested, and yes it exceeds the 800, 841 to be exact. However, the challenge I have is that when I wired the house I installed ONLY keypads throughout the house and the physical load switching switches in 2 hidden locations, so 90% of my scenes are in fact just linking keypads to single switches and it's a BIG house. I have attached a backup of the ISY so you can see for yourself, I would welcome input from you on how to overcome this issue. Perhaps .... I have my old ISY99i from my house, that I upgraded to an ISY994 and promised not to use (which I haven't). Perhaps if I used that with another PLM to just control the network controlled items that I need to read state on the keypads ? Any other ideas ? ISY-Backup.v4.1.2__Thu 2014.04.24 06.53.43 PM.zipFetching info...
Michel Kohanim Posted April 25, 2014 Posted April 25, 2014 Hi ukbjorn20001, Thank you. Can you please go to Tools | Topology, save, and send it me to support@universal-devices.com? With kind regards, Michel
ukbjorn20001 Posted April 25, 2014 Author Posted April 25, 2014 Will do when I'm next on site (probably next Friday)
upstatemike Posted April 26, 2014 Posted April 26, 2014 I would like to learn the solution to this as well since I am seeing similar issues. I'm about to resort to setting up a bunch of new events to query key loads and then send a group command to refresh the keypads to make sure their status matches the load state.
ukbjorn20001 Posted May 13, 2014 Author Posted May 13, 2014 Have emailed the topology report. I am on-site today so any input would be helpful as I don't have remote access Thanks
