Wake-on-Lan
I'm trying to configure a Wake on LAN device, i enter MAC Address (with dashes, all upper-case), IP Address (in my case 10.10.1.115), Subnet (255.255.255.0) and Press Calculate and click "OK". When I open the settings again, the IP Address is always "10.10.1.126"... i'm i doing something wrong? I'm running 4.2.2
That's correct. You are not doing anything wrong. The IP address, 10.10.1.126, is the public address for any and all devices connected to your LAN.
The IP address, 10.10.1.115 is the address assigned to your device on your LAN and is subject to change. But changing it won't affect wake-on-LAN ability. The particular device you want to wake is identified by the MAC number.
I don't know much about the wake on lan.  But I can tell you that 10.10.anything.anything is not a public IP adress.  Both addresses you list there are private LAN addresses.
