Run At Start Up - FAQ
I thought it would be beneficial to many of us to know when a Run At Startup should be used and applied. I think knowing when not to use it is even more beneficial to the masses.
What are the caveats of using this feature in ISY-994 Series Controller? Are there downsides in deploying too many and what defines too many?
This would also be a good thread for those to supply their programs along with details of how they use, deploy, and the idea of the Run At Startup program.
Much Thanks!
I have exactly one program that is set to "Run at Startup"  I call other programs from that.  Some of those call others.  Building in some delays here and there, allows me to time phase startup runs so that they don't all just run at once as well as add some logic to decide what needs to run and what doesn't.
I only have a few that run at startup, probably the same that many due:
Reboot notification:
        Send Notification to 'All' content 'Startup'
DSCLink heartbeat ($Alarm_Heartbeat is init'ed to 2):
        $Alarm_Heartbeat is not 0
        Repeat Every  0 seconds
           Wait  10 minutes
           Send Notification to 'All' content 'Alarm Heartbeat'
DSCLink status:
        Resource 'Alarm - Get Status'
Leak sensor startup program:
see here: http://forum.universal-devices.com/topic/11566-leak-sensors-a-suggested-complete-program-package/
