GSpitale01 Posted September 15, 2014 Posted September 15, 2014 Some relatively simple things I'd like to see in upcoming releases: 1. Ability to use input parameters (ie climate module parameters) either directly in program comparisons OR at least the ability to assign a variable value using those parameters. 2. Floating point math. 3. Ability to use variables in wait statements. And one that's likely a bit harder to implement: "While" comparisons in addition to "If". I know that there are workarounds (mostly) to my "wish list", but implementing these would make programming a lot simpler and more powerful. Thanks for consideration....
Michel Kohanim Posted September 16, 2014 Posted September 16, 2014 Hi gspitale, Except for the While construct, all are in 5.x release. With kind regards, Michel
