2663-222 Dual Band Outlet
The 2663-222 Dual Band Outlet is now in the FCC Database.
Both outlets are switched.
http://transition.fcc.gov/oet/ea/fccid/
Grantee: SBP
Product Code 26632
Details Tab.
Internal and external photos. Test reports, preliminary manual.
Full Users Manual.
http://cache.insteon.com/pdf/2663-222-us.pdf
Edited by Brian H
Brian,
As always your keen eye and follow up on the FCC site is greatly appreciated.
SH has stepped up to the plate and listened to the end users about having control to both outlets.
So glad I waited for this release !
Encrypted By: Phoenix Security Solutions
I had a few minutes to review the users manual thanks to Brian.  :-P  I was sad to see the hard factory reset still requires the two man operational method.  :x  Energy consumption is indicated as <0.75 watts vs the originals 1.44 watts, which I will confirm via my Dash Box (DB) & Green Eye Monitor (GEM) when this product is released.  :mrgreen:
I was very happy to see the surge rating has been upgraded to 1000 VAC vs the original 150 VAC.  :D The manual indicates its also 120 VAC 50/60 Hz compatible. This new Error Blink diagnostic is something I am hoping will be pushed into all newer devices in the future.
Over all I am extremely pleased that Smarthome / Insteon has been able to bring this new device to market with an eye towards energy efficiency and long term reliability from surge / spike conditions.
Edited by Teken
That's not what I see. The manual describes a technique for performing a Factory Reset using only the Set button on the chart on page 22, *as well as* an ALTERNATIVE two-person technique described a couple of pages later.
In the flow chart does the user press and hold down one of the buttons?
This flow chart is just terrible. [emoji53]
Or is it tap four times, than hold? [emoji55]
I hope they are less susceptible to noise, that's been my issues with outletlncs (no db). Even with filters on the load, they occasionally lock up and need the power killed and reapplied. They replaced supersockets on the same loads that never had those issues (but had durability issues).
I realize that these new ones are dualband, but the places I use them are in metal boxes, radio most likely won't be that helpful. I think I will watch for them them to be released into the wild and see how others fair with them
I think its safe to say that waiting for a few months to see devices in the wild is very prudent!
There are also a few new features in this version that are not mentioned here that will be worth seeing. Once released I will be replacing most of my outlets with them.
That is the new way they do the flowcharts.   The pages before describe it.
Press/hold to move right.   Tap to move down.
So a factory reset would be:
- Press/hold (device starts blinking green)
- Press/hold (device starts blinking red)
- Tap (device starts double-blinking green)
- Tap (device starts blinking green)
- Press/hold (device is reset)
I have an LampLinc dimmer module that will not enter the second green blinking stage. It only blinks red and exits immediately from the flow chart from there.  IOW: the factory reset leg of the flowchart doesn't seem to exist despite the manual showing the same chart.
I will not use the receptacle modules as long as there are plug-in modules available. Imagine the RF standing waves inside a metal box? I am surprised these things don't go up in smoke every few weeks.
Nearly all my dual-band devices have been functioning reliably for years in metal boxes. That includes both wall and ceiling boxes. The metal box may reduce RF range to the sides and back, but other than that there is absolutely no harmful effect.
BTW, many municipalities require metal boxes and conduit, such as Miami, NYC, Chicago and more.
The earlier 2457D Dual Band Lamplincs do not follow the flow chart. I had the same problem with a refurbished one I recently purchased from Smarthome.
Mine used the older method. Unplug for ten seconds. Plug in while holding the set button. Will start beeping. Keep holding until beeping stops.
I did find the proper manual for the older version with out the flow chart. Though it was not available  in the manuals section of the Insteon web site.
2457D.pdf
Edited by Brian H
The earlier 2457D Dual Band Lamplincs do not follow the flow chart. I had the same problem with a refurbished  one I recently purchased form Smarthome.
attachicon.gif2457D.pdf
Thanks Brian!
This LampLinc is labelled "2457D2" R1.9  2212 (probably mfg. week 22 of 2012). The unit seems to do the first two legs of the flowchart but not any further (no factory reset leg). It flashes red and flashes green and also does the double flash sequence to indicate the options down each leg of the chart.
I have to assume this unit may be the "missing link" between the old style and the new style settability. I was attempting to factory reset the beast and I am not sure the power up with button pressed was doing the job either.
Was this problem with a newer lamplinc too or just the refurbished one? The manuals are usually geared towards the recent devices so if your using rev 1.9, then the process would be different
All of my devices are less than 9 months old and none are refurbished. Brian had the refurbished unit.
2012 is a few years back. Yours is old enough to follow the old manuals instructions.
Mine has a label:
2457D2R
R3.4
4413
Firmware as reported in the Administrative Console v.41
Back then there was also a 2457D2X. The X version was single band power line only and was cheaper than the Dual Band version.
There is an unofficial chart of Insteon Models on this web site: http://www.madreporite.com/insteon/Insteon_device_list.htm
It is from end users reporting things like model, date code, reported firmware, date purchased and known issues found by the user.
Edited by Brian H
  • 4 weeks later...
I was really hoping to see this product available for the Black Friday event. So far nothing has been listed or announced for this dual band outlet linc.
I have a few places where having the ability to turn two separate devices on / off are present.
Got an email this morning.
Now a shipping product.
I downloaded the Full Users Manual and Quick Start Guide. I will see what they say .
http://www.smarthome.com/insteon-2663-222-on-off-outlet-white.html/
 The Insteon Gods must have been listening to my prayers! I also just received the e-mail and look forward to reviewing the user manual. I was extremely happy to read the depth has been reduced from 1.42" to 1.32" it also has the maximum power output for a 15 amp receptacle of 1800 watts.
Typically you see a rating of 1500 max, excellent product release Smarthome / Insteon!
Edited by Teken
I was looking on the website & in the user guide but couldn’t find the maximum watts. Where did you find it? I was also looking to see what happens after a power outage if it goes back to the previous state. I couldn't find that piece of info either. This used to be clearly stated on each device page. They started making fancy manuals & have a new fancier looking website, but it seems its at the expense of providing relevant info.
Edited by hbsh01
I was looking on the website & in the user guide but couldn’t find the maximum watts. I was also looking to see what happens after a power outage if it goes back to previous state. I couldn't find that piece of info either.
Not too sure how this new device will behave after a power outage. But, the recent trend from Smartlabs is to return to a off state. I prefer that the device come back up in the exact same state it was before.
I think the trend was in the opposite direction. I have an OutletLinc that's about 4-5 years old & it goes to the off state. But the OutletLincs from the last few years reverted back to the previous state. I also prefer it that way.
I prefer it to be settable.
I'd prefer an "off" state for certain things, and a "previous state" for others.  In general, I suppose it is safer to have them refer to off.
Having options is always better.
OK, so which of you fine gentlemen are going to take one for the team and purchase one??  :mrgreen:
