Buzzed Posted November 20, 2014 Posted November 20, 2014 I recently started having some issues with lighting commands not firing with my ElkM1G panel. I was messing around in the ISY99i console and merely changed the internet (I believe subnet mask). Now after exiting the console I can't seem to get back into it. Help would be appreciated.
Xathros Posted November 20, 2014 Posted November 20, 2014 Do you know what you changed the netmask to? -Xathros Sent from my iPhone using Tapatalk
Xathros Posted November 20, 2014 Posted November 20, 2014 Then try this, adjust the settings on your computer's network connection to have the same netmask and then try to access the ISY and fix the netmask. Then set your computer's netmask back to 255.255.255.0 -Xathros
Teken Posted November 20, 2014 Posted November 20, 2014 (edited) If the above fails to work because its going through a router. You may have to use a cross over cable and connect directly to the ISY and make the connections then adjust the subnet mask to its previous value. NOTE: Newer laptop (some) computers can auto configure to cross over via their Ethernet card. You have a 50/50 chance of this working if a cross over cable is not available. Edited November 20, 2014 by Teken
Buzzed Posted November 25, 2014 Author Posted November 25, 2014 Sorry I haven't responded sooner but the Ethernet crossover cable just arrived in the mail however I am still unable to get into the administrative console. Any further suggestions?
stusviews Posted November 25, 2014 Posted November 25, 2014 Is you NIC set to obtain an IP and DNS address automatically? If so, and address If http://isy( or http://isy:port_number) doesn't work and you have a recent backup, then try a factory reset.
Michel Kohanim Posted January 1, 2015 Posted January 1, 2015 Sajata, If you have problems getting into the admin console please contact our tech support team. With kind regards, Michel
