Schlage BE469
hart2hart
Hi Mike,
Awesome. Thank you. Wish me luck. I see a good day or two of playing in my future.
Mitch
Hi Mitch,
I am sure you will quickly get everything configured and running this weekend. Glad I could help. :-)
~Mike
  • 1 year later...
Hi Waketech,
This will be somewhat lengthy however I hope it will be beneficial to others. I basically use two integer variables, $iSchlageLockedBy and $iSchlageUnlockedBy to track everything. The variables are change whenever an action is reported by the lock.
Here is one of my user programs that sets the variables, turns on a Scene (button on a few KeypadLincs) and sends a Notification via Prowl.
        Status  '.Z-Wave / ZW 006 Schlage Door Lock' is Access Code 1
    And Control '.Z-Wave / ZW 006 Schlage Door Lock' is switched Unlocked by Keypad
        $iSchlageLockedBy  = 0
        $iSchlageUnLockedBy  = 1
        Set Scene 'Scenes / SchlageButton-A' On
        Resource 'SchlageMary'
'SchlageButtonA' program that controls the lock from a KeypadLinc button.
        Control 'Living Room Wall / A-Schlage Lock' is switched On
    And Control 'Living Room Wall / A-Schlage Lock' is not switched Off
     Or (
             Control 'Mike Bedside KPL / A-Schlage Lock' is switched On
         And Control 'Mike Bedside KPL / A-Schlage Lock' is not switched Off
        Set '.Z-Wave / ZW 006 Schlage Door Lock' Unlock
        $iSchlageUnLockedBy  = 55
        Resource 'SchlageKPLUnLock'
        Set '.Z-Wave / ZW 006 Schlage Door Lock' Lock
        $iSchlageLockedBy  = 3
        Set Scene 'Scenes / SchlageUnlock' Off
        Stop program 'SchlageTimeout'
        Resource 'SchlageKPLLock'
'SchlageTimeout' (Disabled) program that locks the front door with exceptions noted.
        Status  '.Z-Wave / ZW 006 Schlage Door Lock' is Unlocked
        Wait  10 minutes
        $iSchlageLockedBy  = 555
        Set Scene 'Scenes / SchlageButton-A' Off
        Resource 'SchlageTimeout'
NOTES:
*Must Remain DISABLED otherwise 10 minute time period starts as soon as door is unlocked.*
Called by SchlageTimeoutEnable If LRWallKPL-B is Off.
Stopped by FrontDoor program and resets upon every door closure.
Stopped by SchlageLockedInside and SchlageLockedOutside programs.
'SchlageTimeoutEnable' program. I use a State variable called $sSchalgeTimeoutEnabled. (Another program is triggered when the state of this variable changes and Notifies me via Prowl.)
        Status  'Living Room Wall / B-Disable Lock' is Off
        $sSchlageTimeoutEnabled  = 1
        Wait  5 seconds
        Run Program 'SchlageTimeout' (If)
        $sSchlageTimeoutEnabled  = 0
NOTES:
Called by FrontDoor program.
LRWallKPL-B Status:
On: Prevents FrontDoor from locking after 10 minutes.
Off: Calls SchlageTimeout(If) program, that will lock the FrontDoor unless reopened within 10 minutes.
'FrontDoor' program.
        Status  'z-Door Sensors / Front Door' is 100%
        Resource 'FrontDrSensorOpen'
        Resource 'FrontDrSensorClosed'
        Run Program 'SchlageTimeoutEnable' (If)
NOTES:
Stops SchlageTimeout when evaluated True and Runs SchlageTimeoutEnable when evaluated False.
Front Door will automatically re-lock after closure when parameters if LRWallKPL-B is Off.
LRWallKPL-B disables SchlageTimeout if On in SchlageTimeoutEnable program.
'SchlageLockedInside' program.
        Control '.Z-Wave / ZW 006 Schlage Door Lock' is switched Key/Manually Locked
        $iSchlageLockedBy  = 1
        Wait  1 second
        Resource 'SchlageLockedInside'
'SchlageLockedOutside' program.
        Control '.Z-Wave / ZW 006 Schlage Door Lock' is switched Locked by Keypad
        $iSchlageLockedBy  = 2
        Wait  1 second
        Resource 'SchlageLockedOutside'
'SchlageManualUnlocked' program.
        Control '.Z-Wave / ZW 006 Schlage Door Lock' is switched Key/Manually Unlocked
        $iSchlageUnLockedBy  = 0
        Resource 'SchlageManualUnLocked'
'SchlageTamper' program.
        Control '.Z-Wave / ZW 006 Schlage Door Lock' is switched Tamper Code Entry Limit
        $iSchlageLockedBy  = 999
        $iSchlageUnLockedBy  = 999
        Resource 'SchlageTamper'
        Send Notification to 'Michael' content 'SchlageTamper'
Here are my variable definitions.
iSchlageUnLockedBy
999 = Tamper Alarm
 55 = Insteon Keypad
  0 = Manually UNLOCKED
  1 = Mary
  2 = Michael
  3 = Janet
  4 = Tina
  5 = Joe
  6 = Alice
iSchlageLockedBy
999 = Tamper Alarm
  0 = Reset when UNLOCKed by Keypad or Manually UNLOCKED
  1 = Manually LOCKED from inside
  2 = LOCKED by Outside Schlage button
  3 = LOCKED by Insteon Keypad
  4 = LOCKED by KPLAllOffButton Program
555 = LOCKED by SchlageTimeout Program
I also have two other programs to send a notification if the lock is Not Responding or Jammed.
~Mike
Mike D, would you mind sharing your Scene in how you get the KPL to report the status of the locks?  I am having trouble getting them to report status correctly.
AnthemAVM,
Create a scene that has the lock and button as responders. Write a program to control the scene. Here's the scene I use:
DR Deadbolt
        Control 'DR / Devices / DR Side Door Light / DR Side Door G Front Off' is switched Off
      Or Control 'DR / Devices / DR ZW Deadbolt' is switched Key/Manually Locked
        Set 'DR / Devices / DR ZW Deadbolt' Lock
        Set Scene 'DR / Scenes / DR Deadbolt' Off
        Set 'DR / Devices / DR ZW Deadbolt' Unlock
        Set Scene 'DR / Scenes / DR Deadbolt' On
AnthemAVM,
DR Deadbolt
Stusviews,
I have the KPL-B buttons and the Schlage lock in a scene, both are responders.
This is my program
Front Door Status KPL
        Control 'KPL Buttons / Becca KPL.B' is switched Off
     Or Control 'KPL Buttons / Michael KPL.B' is switched Off
     Or Control 'Front Door' is switched Key/Manually Locked
        Set 'Front Door' Lock
        Set Scene 'Front Door Deadbolt' Off
        Set 'Front Door' Unlock
        Set Scene 'Front Door Deadbolt' On
The KPL buttons are in toggle mode, is that correct?  When I hit the B button on the KPL button that lock unlocks, and only the button you pushed lights up, other KPL B do not light up.  I also can't relock the door.
Any suggestions on what I am doing wrong?
I'm out of town at a mathematics convention, so I won't be able to verify anything until early next week.
Stusviews,
This is my program
I do not see a way for your (or stusviews) program to execute the ELSE path.  The program is triggered only by the OFF/LOCKED commands and, once triggered, will always evaluate TRUE.  Perhaps I miss something here.
I would expect you may need a couple of extra conditions in your program:
​     or Control 'KPL Buttons / Becca KPL.B' is not switched On
     Or Control 'KPL Buttons / Michael KPL.B' is not switched On
     Or Control 'Front Door' is not switched Key/Manually Unlocked
Edited by oberkc
If the door is manually locked why would you want a program to unlock it?
B.R.I.A.D.A.
Best regards,
Gary Funk
That logic always give me some problems also.
​     AND Control 'KPL Buttons / Becca KPL.B' is not switched On
     AND Control 'KPL Buttons / Michael KPL.B' is not switched On
     AND Control 'Front Door' is not switched Key/Manually Unlocked
The top three conditions are always false unless one trigger is being processed.
When any one triggers the whole logic becomes true.
The bottom three line are always true unless a trigger is being processed.
When any one triggers the whole logic becomes false.
Reverse the condition and you have to reverse the logic to keep them equal (deMorgans theorem).
Not(A or B or C) = Not(A) and Not(B ) and Not©
It won't be nice if it rains, or snows, or sleets.
= It won't be nice if it rains, and it won't be nice if it snows, and it won't be nice if it sleets.
1. Because I can. :)
2. So do not have to go to the door and physically unlock it.
~Mike
- My Schlage lock is not in the Scene. The lock is always controlled by one of my programs. Only the KPL buttons are in this Scene and they are both Controllers.
- Yes, my KPL buttons are in toggle mode.
Hope this helps!
~Mike
But that program would unlock it as soon as it's locked.
Not in the way I wrote my programs. If unlocked my 'SchlageTimeout' program will automatically lock it unless it is stopped by another KPL button that runs my 'SchlageTimeoutEnable' program or the door is left open.
~Mike
How can you have two KPL buttons "H" in a scene that can be turned on/off from a program?
Can't seem to get an option for on/off...
Can this only be done with "A"?
Edited by aLf
Put them in a scene.
I'm Gary Funk and I approved this message.
  • 4 months later...
AnthemAVM,
DR Deadbolt
Sorry to bring this topic back, but I am trying to do something similar below is my program, I have both the lock(be469) and KPL H(toggle only) in a scene called "Lock" as responders only. The program works but the KPL button does not light up when the door is unlocked?
BackDoor - [iD 003E][Parent 000A]
        Control 'MasterBedroom KeypadA / MasterBedroom KeypadH' is switched Off
     Or Control 'ZW 004 Schlage Door Lock' is switched Key/Manually Locked
        Set 'ZW 004 Schlage Door Lock' Lock
        Set Scene 'Lock' Off
        Set 'ZW 004 Schlage Door Lock' Unlock
        Set Scene 'Lock' On
You only have statements that describe what to do when the lock is locked, but noting about what to do if it's not locked.
To expand upon stusview response...
Your program will never run the ELSE path as written. Upon what condition do you wish to run thw ELSE path?
Curios if someone has found a good online source for buying the BE469 units?  Home depot was $199 in the store the other day and I thought they were pretty high.
Wanting to get a couple for in the yard type doors so they can be locked all the time but not require a kit to get in :)
Edited by arw01
Note that the BE469 locks can be unlocked from the inside side. If someone can reach over the gate, then the locks are useless. I use GTO (Gates That Open) locks for all our gate locks. They remain locked (unless left unlocked using a key) and can be controlled using an I/O Linc.
Amazon had a sale a few weeks back for $175 for the black one (which I wanted) but I have also gotten one of Ebay new for $150.
 OK that helps me understand why its not running, but I thought if the "IF" statement is not true then it runs the "Else" statement. So what I was trying to accomplish is,
If the KPL is switched off--->then Lock the door, or if the lock is manually locked then turn off the the Scene(KPL button).
If neither the above is happening then turn the scene ON (KPL button)
Should i change the KPL to a controller in the scene and try use:
        Control 'MasterBedroom KeypadA / MasterBedroom KeypadH' is not switched On
That way I can change the LED in that KPL to red, so when at night I glance over I can see red and know the door is unlocked, but if everything is off I am secure.
Edited by Ajax
Ajax. You are correct that a if statement is false it will run the ELSE path. What may be less obvious is that for a statement to be evaluated as false, it must be triggered at such times. One MUST be aware of when programs trigger an evaluation. In your case, it would trigger only at specific events: keypadH switced off and doorlock is locked. In both cases your condition evaluates TRUE. Your program has no triggers that can cause a false evaluation.
Yes, try the kpl in a scene as controller with lock as responder. See if this causes the door to lock/unlock without further neednfor a program.
On further review, also perform some tests to be sure the ISY reacts to the 'control...door lock" command. When I use zwave devices as program conditions, they respond to STATUS conditions only.
As far as your program conditions, I pose a question for you to consider: how would your program behave differently if you used STATUS rather than CONTROL as conditions?
OK this is getting me thinking thanks for the help, appreciate the directions and actually think I have it working! Although I can only test it from work but will have to try pushing the KPL button at home and see what happends, but yes short and sweet
Backdoor - [iD 0041][Parent 000A]
        Status  'ZW 004 Schlage Door Lock' is Locked
        Set Scene 'Lock' On
Did you create the scene with KPL as controller and lock as responder? If so, I am hopeful that pressing the button will control the lock.
Yes, and you think that would work, but I dont get a response from the lock when I push the KPL(controller) Did a test and results are below:
Fri 03/17/2017 04:42:08 PM : [GRP-RX      ] 02 61 29 13 00 06
Fri 03/17/2017 04:42:09 PM : [CLEAN-UP-RPT] 02 58 06
Fri 03/17/2017 04:42:09 PM : [iNST-SRX    ] 02 50 3D.C3.C9 3B.96.22 E1 13 FC    LTOFFRR(FC)
<html><font color="red">----- Lock Test Results -----</font></html>
<html><font color="red">[Failed]</font> MasterBedroom KeypadH (3D C3 C9 8)</html>
<html><font color="red">[Failed]</font> ZW 004 Schlage Door Lock (ZW004_1)</html>
Fri 03/17/2017 04:42:18 PM : [ZWAVE-TX ZW004_1] ...
Fri 03/17/2017 04:42:18 PM : [ZWAVE-RX        ] ACK
Fri 03/17/2017 04:42:18 PM : [ZWAVE-RX        ] [0104011301E8]
Fri 03/17/2017 04:42:18 PM : [ZWAVE-TX        ] ACK
Fri 03/17/2017 04:42:19 PM : [ZWAVE-RX        ] [01050013EC0005]
Fri 03/17/2017 04:42:19 PM : [ZWAVE-TX        ] ACK
Fri 03/17/2017 04:42:19 PM : [ZWAVE-RX ZW004_1] ...
Fri 03/17/2017 04:42:19 PM : [ZWAVE-TX ZW004_1] ...
Fri 03/17/2017 04:42:19 PM : [ZWAVE-RX        ] ACK
Fri 03/17/2017 04:42:19 PM : [ZWAVE-RX        ] [0104011301E8]
Fri 03/17/2017 04:42:19 PM : [ZWAVE-RX        ] [01050013ED0004]
Fri 03/17/2017 04:42:20 PM : [ZWAVE-RX ZW004_1] ...
Fri 03/17/2017 04:42:20 PM : [ZWAVE-TX        ] ACK
Fri 03/17/2017 04:42:20 PM : [ZWAVE-TX        ] ...
Fri 03/17/2017 04:42:20 PM : [ZWAVE-RX        ] ACK
Fri 03/17/2017 04:42:20 PM : [ZWAVE-RX        ] [0104011301E8]
Fri 03/17/2017 04:42:20 PM : [ZWAVE-RX        ] [01050013EE0007]
Fri 03/17/2017 04:42:20 PM : [ZWAVE-TX ZW004_1] ...
Fri 03/17/2017 04:42:21 PM : [ZWAVE-RX        ] [01050013F00019]
Fri 03/17/2017 04:42:21 PM : [ZWAVE-TX        ] ACK
Fri 03/17/2017 04:42:21 PM : [ZWAVE-RX ZW004_1] ...
Fri 03/17/2017 04:42:21 PM : [ZWAVE-TX ZW004_1] ...
Fri 03/17/2017 04:42:21 PM : [ZWAVE-RX        ] ACK
Fri 03/17/2017 04:42:21 PM : [ZWAVE-RX        ] [0104011301E8]
Fri 03/17/2017 04:42:21 PM : [ZWAVE-RX        ] [01050013F10018]
Fri 03/17/2017 04:42:22 PM : [ZWAVE-RX ZW004_1] ...
Fri 03/17/2017 04:42:22 PM : [ZWAVE-TX        ] ACK
Fri 03/17/2017 04:42:22 PM : [ZWAVE-TX        ] ...
Fri 03/17/2017 04:42:22 PM : [ZWAVE-RX        ] ACK
Fri 03/17/2017 04:42:22 PM : [ZWAVE-RX        ] [0104011301E8]
Fri 03/17/2017 04:42:22 PM : [ZWAVE-RX        ] [01050013F2001B]
