PLM 'Not Conncted'
If I go to the diagnostics - PLM info, it tells me I am not connected.
I have tried doing a FR command through telnet and also a restore PLM which fails (i guess you need to be connected to a PLM to restore it?).
Is there any way to force a connection to the PLM
Any help appreciated - Thanks
Hello doowadiddy2003,
Apologies for a tardy reply.
Usually there are two causes for this:
1. a faulty PLM
2. a faulty Cat5 cable
Would you be kind enough to swap the cat5 cable that goes from ISY to the PLM and see if that solves the problem? If not, then - and unfortunately so - you will need to request for a replacement PLM.
