January 24, 201510 yr Hi, Is there any way to adjust the text size in the admin console java app? I recently got a new laptop with a 3200x1800 resolution in a 15 inch screen. It looks amazing in nearly every application, but in the admin console the text size is nearly unreadable it is so small. Other applications seem to scale appropriately but this one doesn't. The command prompt is the only other app I've used that is all squinty-text. Thanks for your time! Edited January 24, 201510 yr by Methos000
January 25, 201510 yr Hi Methos000, Unfortunately not yet but definitely on our list. With kind regards, Michel
January 28, 201510 yr haha I have same problem on my surface pro, so nice to hear this is on the list. I tried turning off and on the high-DPI setting on Jave program executable - strangely it does effect the size of some fonts in the java app, but not the main ones
June 3, 201510 yr haha I have same problem on my surface pro, so nice to hear this is on the list. I tried turning off and on the high-DPI setting on Jave program executable - strangely it does effect the size of some fonts in the java app, but not the main ones Any updates in this area? I'm loving my ISY but it's so very hard to use the Java interface on a 4K monitor.
June 28, 201510 yr Me too! Having a great time playing around with the ISY, but the tiny text size of the Admin Console makes it really frustrating sometimes.
August 8, 201510 yr I just found that there is a Windows option to select "disable display scaling on high dpi settings" in the shortcut properties. Right click the console shortcut and select PROPERTIES Select the COMPATABILITY tab In the Settings section, select the box next to "Disable display scaling on high dpi settings." These instructions are from my Windows 10 desktop, earlier versions may be slightly different. After making this change, the admin console now opens in a perfectly readable scale. Combined with the recent console update that remembers the previous screen location, using the console on a multi-monitor setup is now pain free!
December 11, 201510 yr Unfortunately the Compatibitliity settings change didn't change anything for me. Running Win7. I too would really like to see a scalable, or even just one extra "large" size font display for the adm console. * Orest
December 11, 201510 yr Orest, I had to pick both XP service pack 3 and 640x480 resolution. Both were needed to get it to change I did it on W10, but I recall the settings being fairly similar to W7. Paul
December 20, 201510 yr All, There isn't a compatibility mode setting on admin.jnlp just on exe files. What file are you doing this compatibility mode setting on? Scott
December 20, 201510 yr All, There isn't a compatibility mode setting on admin.jnlp just on exe files. What file are you doing this compatibility mode setting on? Scott Scott If you follow the steps in the previous post, when you right click on the admin console local icon, it applies the compatibility mode settings to the java environment (jp2launcher). Maybe W7 is different in that regard, I don't have a w7 environment. Paul Edited December 20, 201510 yr by paulbates
December 20, 201510 yr Paul I see what your saying now and I'm running Win 10 but not having any luck. Playing around with the compatibility troubleshooter I did finally get the 640 X 480 screen size to work but that resulted in the following Java error. --------------------------- Java Web Start 11.66.2.18-fcs --------------------------- Error encountered while invoking Java Web Start (SysExec) C:\Program Files (x86)\Java\jre1.8.0_66\bin\jp2launcher.exe --------------------------- OK --------------------------- From the look of what little I could see on the screen that wasn't going to work either. I'm running on an iMac 5K (Boot Camp). When I run it in OSX it's gorgeous. Scott
December 20, 201510 yr Paul I see what your saying now and I'm running Win 10 but not having any luck. Playing around with the compatibility troubleshooter I did finally get the 640 X 480 screen size to work but that resulted in the following Java error. --------------------------- Java Web Start 11.66.2.18-fcs --------------------------- Error encountered while invoking Java Web Start (SysExec) C:\Program Files (x86)\Java\jre1.8.0_66\bin\jp2launcher.exe --------------------------- OK --------------------------- From the look of what little I could see on the screen that wasn't going to work either. I'm running on an iMac 5K (Boot Camp). When I run it in OSX it's gorgeous. Scott Scott, ok, I picked around in the java / bin folder. The settings seemed to have landed on javaws.exe . Change that and see if that works. Edit. now I see something else. After the first time I run the admin.jnlp, I right click on its icon in the task bar and add that to the task bar. It changes to the ISY icon (house on globe). My directions start by right clicking that. Paul Edited December 20, 201510 yr by paulbates
December 20, 201510 yr Paul I saw your message this morning and went to try it but now I have Java stuck in 640 X 480 and I can't change it. I've removed Java, deleted the files in the program folder, rebooted, and re-installed it but when I go to check the version I get a 640 X 480 window that's very hard to navigate. I have nothing set in compatibility mode but it's stuck there at 640 X 480. Google hasn't helped and I'm currently at a loss for the next step. While in this 640 X 480 screen I've managed to get to display settings and set things right but then it always reverts back. There must be a setting in the registry that doesn't get cleared when I uninstall. Anyway thanks for your suggestion and I will pursue it when I can. Scott
December 20, 201510 yr Hi Scott, May I suggest 4.4.1 UI? It allows you to change the font sizes and, although there are some anomalies (programs), it should help: http://forum.universal-devices.com/topic/17359-release-441-beta-is-now-available/ With kind regards, Michel
December 21, 201510 yr Michel I finally got my Java install straightened out and tried your suggestion. Now I can actually use my ISY994i on my new high DPI Windows 10 platform. Thank you. Scott
December 22, 201510 yr Hi Scott, Thanks so very much for the update and I am so very glad it worked out. With kind regards, Michel
December 5, 20169 yr Glad I found this thread, and it solves a problem I was having too. But is there a way to make this "automatic"? By that I mean that, with the increasing usage of 4K monitors, many programs automatically figure things out and resize fonts, spacing, window size, etc. automatically, as the default condition. This would be a step in the direction of addressing the "DOS-like" criticisms I've heard about this essential program, which I love, incidentally. Just trying to be helpful, not critical...Jack
December 5, 20169 yr Glad I found this thread, and it solves a problem I was having too. But is there a way to make this "automatic"? By that I mean that, with the increasing usage of 4K monitors, many programs automatically figure things out and resize fonts, spacing, window size, etc. automatically, as the default condition. This would be a step in the direction of addressing the "DOS-like" criticisms I've heard about this essential program, which I love, incidentally. Just trying to be helpful, not critical...JackWelcome to the forums! NO automatic font sizing, only manual. Font sizing should really be the jobs of any decent OS making the system hardware independent. Trouble is the font size is an out of date syste based on printer dots and vide card dots and not the actual size seen by the user. Windows has attempted to correct some of this by implementing scaling factors on the fonts but has let the user base down, apparently. Apple, Andoid and ancient Linux knock offs, have done worse. This should not be up to the application to determine the size of your monitor but I guess a few more gigabytes of code spread and duplicated through every application known to mankind is OK in this wasteful era.
