System -101 http errors
Can anyone tell me what these errors are:
Wed 2015/01/28 06:09:19 PM	System	-101	http
My ISY has locked up 3 times in the last 3 weeks.  Each time the lockup was preceeded by thousands of these entries withing a 3-5 minute period.
-Xathros
Hi Xathros,
Is it -101 or perhaps it's -101xx :
http://wiki.universal-devices.com/index.php?title=ISY-99i/ISY-26_INSTEON:Errors_And_Error_Messages
I think your system being in being hacked. The best thing to do would be to turn debugging on do that at the least we can get the source IP address.
Has anything changed in your network?
Hi Michel-
I will turn on debugging and watch the logs. Nothing new on my network. The errors were exactly as I posted, -101. My ISY does make extensive use of my network so this could be related to something I have done. I will post back when I know more.
-Xathros
Hi Xathros,
I don't know if you've seen this, but in case you didn't here's the ISY error list
Hi Stu-
I'm 'm quite familiar with that list. You will notice that it does not list -101
-Xathros
Which is why Michel asked about -101xx
And why I responded that they were just -101
-Xathros
Thanks Michel-
I've had UPnP bombardment from my DirecTV receivers in the past.  I have debug on and am waiting for it to happen again.  I will let you know what I see on the next occurrence.
-Xathros
Hi Xathros,
Thank you. Very much looking forward to it. Do you have UPnP enabled in your ISY? I do not think this is UPnP related.
No, nor in my router.  So far this has not happened again.  I just turned debug back on (after yesterdays update) and am awaiting another occurrence.
-Xathros
