bipto Posted April 12, 2015 Posted April 12, 2015 So several days ago I finally got around to self-signing the certificates and switching from http to https client access. All seemed fine until, during the course of an ISY backup, I saw the following error... It doesn't halt the backup, in fact it seems as if the backup goes on to complete successfully (though I am hesitant to attempt a restore to find out for sure). Stranger still is that subsequent backup attempt showed that these errors seem to occur at arbitrary times during the backup, sometimes multiple times... Anybody else seeing this..? I'm running 4.2.30 with https configured to TLS 1.2 Low for both client and server...
MustangChris04 Posted April 12, 2015 Posted April 12, 2015 I would try making sure java is up-to-date and that your certificate is on your trusted list.
bipto Posted April 12, 2015 Author Posted April 12, 2015 On 4/12/2015 at 4:14 AM, MustangChris04 said: I would try making sure java is up-to-date and that your certificate is on your trusted list. Both are true, thanks.
Michel Kohanim Posted April 13, 2015 Posted April 13, 2015 Hi bipto, Admin Console regularly checks the status of ISY (busy/not) based on the events it receives. So, while you are backing up, and if you have too many events (things being queried, programs running, etc.), the background process in the Admin Console that checks for status might be closed by ISY so that backup can continue. This is especially the case if you are on a low bandwidth connection as backup takes priority over everything else. The main thing you need to make sure is that whether or not backup fails not using http. In that case, the problem might be SD Card related. With kind regards, Michel
bipto Posted April 13, 2015 Author Posted April 13, 2015 Hi Michel! Given that this behavior seems to be a direct result of my switching to https client access, I'm thinking your bandwidth suggestion may be right on the money, but I'll go back on http tonight and try it a couple of times just to be sure. Thanks! --Bill
Michel Kohanim Posted April 13, 2015 Posted April 13, 2015 Hi Bill, Thank you. Please do keep me posted. With kind regards, Michel
Xathros Posted April 13, 2015 Posted April 13, 2015 For what its worth, I have always seen this issue when backing up my ISY locally or remotely via https and never locally via http. Up until this morning that is. Today I was able to complete a full backup remotely via https with no socket open failed messages. This appears to be due to improvements in the UDI firmware in a pre-release build 4.3.0 that I'm testing. This while my router and 3 processess running on a RPi were all frequently posting data to the ISY. Additionally, my backups have always been good in spite of these socket open failed messages. -Xathros
bipto Posted April 14, 2015 Author Posted April 14, 2015 Indeed, as suggested this behavior disappeared when I switched back to http access. Thank you both!
