Version 2.6 Officially Released
Release 2.6
Officially Released.
For Release 2.5 (RC1)
Fixes
- Fix: Schedule 'Time is' entries run intermittently
- Fix: Cannot enable programs
- 'Replace Device' now updates all remoteLincs first
- 'Replace Device' does not require exact device type/subtype match
- 'Restore Device' now removes links to unknown devices
- 'Restore Device' now removes duplicate links
- 'Restore Device' now moves keypad led links to front of link database
- 'Restore Device' now ensures link to PLM for responder only devices
- Less aggressive network crawl (now ignores inactive links)
- Missing PLM links added when device added to ISY
- For Linux, Log can be saved to filesystem
- Updated User Guide
Features
- Detailed progress in Java console for long running commands (Restore Devices, etc.)
Known Bugs
- None
For 2.4.15 -
Fixes
- Or (...)/And (...) logic in programs
- 'New Insteon Device' now removes old links immediately (as currently done if linked instead)
- Sunset/Sunrise now recalculated at DST changeover
- Device now working correctly after 'Replace Device'
- Move 'True/False' to own column in Program Summary
- Widen h/m/s input dropboxes (showed '...' in some browsers)
- Proper file cleanup when removing a device from ISY and device communication fails.
- Device firmware levels in GUI
- Regression: ELK/Notification setting are not saved
- Progress bar when saving programs
- Sunrise/set "Same Day" now working correctly when the From is a fixed time or lastrun time, and the To is a sunrise/set.
Known Bugs
- Documentation is still at 2.4 level
For 2.4.13 -
Fixes
- Overwrite existing links now immediately overwrites links when the device is added
- 00 in the middle of Insteon address
- Removed notification settings from Configuration tab
- 'Repeat 0 times' entry fixed
- Program Summary shows True/False state of programs
- Various minor bug fixes
For 2.4.12 -
Fixes
New Triggers/Schedules
- 'On Never' schedule entry fixed (no longer hangs the box)
- AM/PM in Summary table displays and sorts correctly
- Changes to 'Run at Reboot' automatically updated in summary screen
For 2.4.11 -
Fixes
- Last run times would show 00:00:00
Enhancements
- Show [Applied Locally], in Red for local scene controllers
- Maintain the state of program GUI
- Added "Run at Bootup" to address the power failure issues
- Retain combobox values between Status/Control
For 2.4.10 -
Fixes
- Newlines preserved in Program Comment field
- 'Finally' replaced by 'Else'; semantic difference is 'Else' runs independent of whether 'Then' ran
- Fixed program true/false status, and various logic bugs in programs.
- Added 'is not received' to X10 conditions
- Keypad buttons available in Status conditions and actions
- Log key presses/X10 messages received to the java console (turned on/off in the shell)
For 2.4.9 -
Here is the list of fixes going into the next beta drop, we'll be updating this as more bugs are found and fixes are made:
Fixes
Main Application
- INSTEON address is now shown on the Device View next to Device Type
- Now, the same on level and ramp rate can be applied to all the devices within a scene
- Clicking on 'New Folder', now uses 'New Folder' as default name instead of 'New Program'.
- 'My Lighting' now included in drop down lists
- Fix for non-toggle buttons. An event occurs whenever a button is pressed (i.e. not just when the current value of the button changes)
- Configuration fix for Relay devices; now allows Fast On/Off etc.
- Node combo boxes widened to accomodate long names
- Schedule migration no longer turns lights Off instead of On
- Copy readable contents of program to clipboard
- Copy program
- Program tree has popup menu
- Fix for box hanging when deleting all contents of a folder and the folder itself
- Fix for intermittent save/delete program errors
- Fix for null references to programs and nodes within a program
Regression
- Fixed not being able to change the userid/password
- Removing devices from a scene, left residue and in some cases the device would still respond to commands from the scene it previously belonged to
This weekend would be cool but looks like the list is short up there so it may not be many noticable changes yet.
What are they going to do about the version number because this is beta for version 2.5. The last release was version 2.4.9, will the next be 2.4.95?
Chris,
Is today going to be a 2.4.13 beta release?
If so could you update the top post with what is in it.
  • 1 month later...
