User definable variable folder tabs eg. Constants
larryllix
I use integer variables as constants and it would be nice to keep variables sorted and out of the way of everyday life for writing programs to keep lists shorter.
They make program reading much more human.
$cTRUE  = 1
$cFALSE = 0
$cMODE.TV             = 1
$cMODE.READING = 2
$cMODE.FULLON   = 6
$cHUE.RED     = 22000
$cHUE.BLUE   = 48000
$cHUE.VIOLET = 65000
$cROOM.MUD      = 20
$cROOM.MBR      = 21
$cROOM.RECRM = 13
User definable variable tabs may be the best method so that users can style their system they want by function, location, etc...
Hi larryllix,
Thanks so very much for the feedback. Alas, I am a little confused: all ISY variables are user defined. Can you please elaborate on what you mean? Is this a UI only feature? How's it different than what we already have?
I *think* he just means variables that don't show up the same way in drop down lists for variables... but to use them, they'd have to show up. So I'm not sure how it'd work. As a do it yourself workaround, you *could* just start all those variable names with z.
  • 2 months later...
Hi larryllix,
This would be mostly, if not all, a UI handled feature.
Currently I have about 150 integer variables and they get hard to find and sift through sometimes to find the "active" variables.
- a separate tab for them and no left side of assignment availability on the variable pulldowns.
- I use them with a prefix "c" to denote they are constants as well as ALL CAP names, following other language standards. This is the same style as "I" for ineteger and "s" for state variables.
- should not be assignable as their values should never need to be changed. Other types are for that. values are assigned manually in the variable type tab
- this is handled via string substitution in assemblers and some high-level languages. This would be easier to implement using ISY's current toolchest of variables under different tabs.
examples
  set $iVar1 to $cCONSTANT_VALUE
      $iVar1 is $cTRUE
Zone.Util - [iD 0072][Parent 0082]
        'Utility Room / Motion.Util' is switched On
        $sZone.Violated  = $cROOM.UTILITY       <----using ISY engine , this is a passed parameter and trigger for handler
        $sAlarm.level  = $cFLASHandNOTIFY        <---using ISY engine, this is a passed parameter and trigger for handler
Stat Holidays - [iD 00CB][Parent 0020]
        $sISY.MMDD is 101
     Or (
             $sISY.MMDD >= 215
         And $sISY.MMDD <= 221
         And $sISY.DayOfWeek is $cDAY.MON       <-------easy remember days of week defined
     Or (
             $sISY.MMDD >= 518
         And $sISY.MMDD <= 524
     Or $sISY.MMDD is 701
     Or (
             $sISY.MMDD >= 801
         And $sISY.MMDD <= 807
     Or (
             $sISY.MMDD >= 901
         And $sISY.MMDD <= 907
     Or (
             $sISY.MMDD >= 1008
         And $sISY.MMDD <= 1014
     Or $sISY.MMDD is 1225
     Or $sISY.MMDD is 1226
   scene 'Get to stay home today'
Hi larryllix,
Thank you.
Is this only for constants? i.e. a separate tab for constants that never change and thus should not be available in left side of assignments?
In the true sense of the definition and to keep the implementation simple.
Constants should not be changeable in programs so could be eliminated from selections on left sides of assignment program lines.
On a broader spectrum if f more ">" groupings were added, the new ">" button could isolate and reduce the list lengths by dividing selections into  state, integer, constants, number, system , and devices adding a few to what it currently selects in v5.xx'
A small bug? clicking on the ">" the first time does not select another type, it does nothing on the first click.
