seacontracting Posted August 11, 2015 Posted August 11, 2015 Hi There I purchased the Elk module, and when I try to install it, it comes up with an error: TCP client DNS error [www.universal-devices.com] see attached file Any help would be greatly appreciated
MWareman Posted August 11, 2015 Posted August 11, 2015 Your screenshot is covering the network settings. Since you've disabled DHCP, what is the DNS setting set to? Are the rest of the settings correct for your network?
Michel Kohanim Posted August 11, 2015 Posted August 11, 2015 Hi seacontracting, As MWareman suggested, we need to know what DNS is being used. If you have configured your ISY with a static IP address, then: 1. Either revert to DHCP and use DHCP reservation in your router OR 2. Try changing the DNS to 8.8.4.4 (Googe's public DNS) With kind regards, Michel
seacontracting Posted August 13, 2015 Author Posted August 13, 2015 Thanks for the replies, I changed it back to DHCP and it worked. Thanks heaps
