November 23, 201510 yr I’d like to be able to control a LG TV using my ISY. Turn on/off, open Netflix app on TV, etc. Is this possible? If so, I presume it’s done via REST commands? Could someone point me in the right direction to figuring this out/describing what can be done (if anything)? I’ve got a LG Smart TV model 55LB7200. I currently have it hardwired into my network and wireless turned off.
November 24, 201510 yr Author Are there any API specs for your TV? I don't know. I've found this: http://developer.lgappstv.com/TV_HELP/index.jsp?topic=%2Flge.tvsdk.developing.book%2Fhtml%2FAPI%2FAPI%2FWeb+API+Overview.htm I'm not good enough to understand if that's even the right thing. I've been able to figure out basic things with the network module such as how to control my Sonos system with my ISY but I'm not advanced enough to figure it out myself. I need a working example I can tweak to for my uses. Any help would be great, thanks!
November 25, 201510 yr Hi zerop, I took a quick look and the only thing available is JavaScript APIs. It's very hard to decipher what's being done behind the scenes. I am so sorry. With kind regards, Michel
November 25, 201510 yr Author Hi zerop, I took a quick look and the only thing available is JavaScript APIs. It's very hard to decipher what's being done behind the scenes. I am so sorry. With kind regards, Michel Thanks you so much for looking into this for me. Appreciate it. Oh well, onto the next idea.
November 28, 201510 yr Too bad this didn't work. I always wanted to control my tv so that whenever someone rang my doorbell, my tv would automatically switch to another input to view the camera at the front door. This sounded like a promising way to do it. Maybe there is another way. Sent from my iPad using Tapatalk
November 28, 201510 yr I’d like to be able to control a LG TV using my ISY. Turn on/off, open Netflix app on TV, etc. Is this possible? If so, I presume it’s done via REST commands? Could someone point me in the right direction to figuring this out/describing what can be done (if anything)? I’ve got a LG Smart TV model 55LB7200. I currently have it hardwired into my network and wireless turned off. Too bad this didn't work. I always wanted to control my tv so that whenever someone rang my doorbell, my tv would automatically switch to another input to view the camera at the front door. This sounded like a promising way to do it. Maybe there is another way. Sent from my iPad using Tapatalk Why not get something like the Harmony Hub via a IR blaster to do this? You should be able to easy enough.
November 28, 201510 yr You can use global cache to do it. REST commands go to it and it outputs the IR codes.
November 28, 201510 yr Thanks for the ideas! I have never heard of the global cache, and didn't think of the harmony hub. it will be my next project!
