Release 2.6.12 beta is now available
Release 2.6.12 beta is now available and may be downloaded immediately.
For fixes and enhancements, please peruse our beta forum at http://forum.universal-devices.com/viewtopic.php?t=930. You may also post your comments/questions and issues relating to 2.6.12 to this forum.
This release provides the following important features:
1. 99i Series Optional Modules (Help->Purchase Modules)
--> Weather Module: allows you to add weather information in your programs
--> Energy Meter Module: allows you to use Brultech Meter information in your programs
--> Online Upgrade from 99i Series to 99i PRO Series
2. i2 Support
Bugs
None
IMPORTANT
1. For those upgrading from release 2.6
--->Please note that releases 2.6.1 and above will use default HTTP/HTTPS ports of 80/443 respectively. As such, before upgrading Disable Internet Access
--->You will have to upgrade to release 2.6.5 ( http://forum.universal-devices.com/viewtopic.php?t=1409 ) before upgrading to release 2.6.9
--->If you are upgrading from 2.6.1, please make sure you export all your programs and store them in a safe place
2. If you have used bookmarks, please update them accordingly. If you have problems finding ISY, try http://www.universal-devices.com/99i
3. As always, please take a backup of your ISY
Due to massive [plumbing] changes in this release, please do be kind enough to thoroughly test i2 related issues such as not receiving status feedback from i2 devices.
INSTRUCTIONS for ISY-26
- Userid = isy
- Password = autoupdate
-- Step 1 - This step is necessary if and only if you are upgrading from any release except 2.6.11
- Download the update from http://www.universal-devices.com/update ... nsteon.zip do not unzip
- Login to Admin Console
- Choose Help->Manually Upgrade My Lighting and choose the file you downloaded in the previous step
-- Step 2
INSTRUCTIONS for ISY 99i Series
- Userid = isy
- Important: After upgrading, please close Admin Console, close all web browser processes, clear your Java cache, and reopen Admin Console. If there are any web browser processes running, the Java cache will not be cleared.
Woo Hoo! First to report. No issues here so far.
Thank you Michel for sacrificing for us, we appreciate it!
The Query Button at the bottom now works correctly. The system shows system busy and the progrerss bar appears. Good work.
I just got my 99i/IR and updated to 2.6.11, after spending 12 hours converting my Homeseer installation to ISY I ran into the Scene bug here described today. Luckly I managed to check back and see 2.6.12 up and grabbed that. Scene bug gone, but I had to delete my scenes created with 2.6.11 and rebuild them under 2.6.12 to make them work.
What I'm running into now is a program bug (or feature??). I was trying to find a way to group programs based on how I did it in Homeseer. Create a folder for Midnight, Sunrise, Sunset, etc.... Create some programs in each folder. If you manually try to run them while in the folder, they won't run, no matter what you do. If you yank them out of the folder and put them on the root one, they run fine. I'm not quite sure what to make of that.
I'm using the Homeseer ISY program that will read the ISY and create all the devices on the fly in Homeseer. So far, so good --- and I'm able to run my programs out of homeseer, but would rather do it directly on the ISY.
Other then that, great product! Look forward to all the updates.
Brian
Loaded 12 and all devices were set to 0%/9min again. Ran a query all to fix it, lets see if it sticks this time.
Jim H.
Under program details, to add or edit a schedule the time drop down menus just show .... Also under Manage Programs, the buttons show partial words then... (New...; Und...) I am using Firefox with an iMac. It looks like a font size issue. Is this something I can correct? I think it happened when I upgraded to 2.6.10.
Thanks.
I am having an issue with the web service. I get the error:
Subscription is referenced but not defined
What am I to define?
Name: http://x.x.x.x/services.wsdl. WSDL: http://x.x.x.x/services.wsdl. java.io.IOException: Type {http://www.universal-devices.com/wsdk/isy/1.0}Subscription is referenced but not defined. It is recommended that you use a web browser to retrieve and examine the requested WSDL document to ensure it is correct. If the requested WSDL document cannot be retrieved or is dynamically generated, it is likely that the target web service has programming errors.
Brian
I am assuming you have conditions on the folders that you have your programs in (midnight, sunrise, etc.). If the folder condition is NOT true then any programs within that folder can not be run...even manually.
However, I would assume that even though the folder conditions are False, when you right click on the folder in Program Summary, and select "Run Then" which would bypass the condition and "Allow all programs in this folder to run", it should run all programs in that folder.... as long as there are no "If" conditions on those programs within that folder as well.... That would seem logical to me...
Brian
Hi Michael,
Apologies ... we have left all the GUI bugs for last but this shall surely be fixed in our official 2.7 release (as soon as we get all the i2/Insteon bugs fixed).
Thanks so very much for your patience,
Thanks.
Hi Gary, Please retry.
I do apologize for not updating the website with the most recent WSDL.
Brian
That's not the way it works... If the folder conditions are not true, the program will not run.
Hello all,
For all who are interested in a possible fix for the on level/ramp rate issue, please checkout this post:
http://forum.universal-devices.com/view ... hp?p=14246
Thanks and with kind regards,
Hi Michel,
I've tested 2.6.13 and so far, cannot duplicate any problems with ramp rates, trying local control, status seems fine in this version. I'll let it run throughout the day and see what heppens, but so far so good.
I'm really impressed with the service level at UDI!
Brian
Michel,
I tried again. I even went into Dreamweaver and it's still giving me the same error. I will keep at it as I really don't know what is wrong. But it did work in the past.
Just to make sure, I went back to .8 and the web service is working in Dreamweaver.
Edit:Again.
I see what you did now. You removed the following:
I'm guessing something is not being read correctly now.
I was also having problems with PHP not liking the wsdl file, in version .9 and .10 I did not try .11 or higher. I decided to downgrade and stay at .8 for a little while, which works without problems.
-Nick
I have an EZIO 2x4 which was linked during the 2.6.8 days.
The 2.6.12 update seemed not to allow me to add it with the linking drop down menu as I could with the Motion Sensors. So I added it the old fashioned way and it seems that there is not full support of that device.
Do the latter releases fully support the EZIO 2x4?
Joe
Gary and Nick,
Where would we be without you? Eclipse decided that we could have a type (Subscription) without it being defined. I now added it back and it should work fine ... please do wait for 2.6.13.
Thanks SO very much,
Michel,
I see you updated udiws10.wsdl but not udiws10.ws
http://www.universal-devices.com/wsdk/isy/1.0/
Could that be the reason I can't get the web service to work?
Hi Joe,
It's with regret that I have to inform you none of our releases fully support EZIO. It's basically dependent on your luck (and our luck) ... we have almost exhausted all our options: sometimes it works and sometimes it does not. We have not been able to figure out the secret ingredient yet.
This said, however, we have not given up yet.
Joe
Thank you Michel. It is good to know I'm not totally crazy. (grin)
And for .13... is it done yet?
I'm starting to think Michel may have found a life. It's been almost 20 hours since he replied to this thread. LOL
I am sooooo funny.
