Cant add Insteon 2672-222
slytsi
I am trying to add a new insteon light switch to my mix. I have 2 insteon motion sensors that seem to have a distance problem so i am adding an insteon light closer to them in hopes that it will boost the signal. In any event, I am getting the following issue when adding the light bulb.
Any insight would be greatly appreciated!
I went thru the steps that I thought would be appropriate, but without any specific documentation I feel like I am guessing. Attached are the screenshots of my process.
LOG BELOW.
Tue 12/08/2015 08:35:24 AM : [ZWAVE-RX ZW006_1] [0114000400060E32]...
Tue 12/08/2015 08:35:24 AM : [ZWAVE-TX        ] ACK
Tue 12/08/2015 08:35:24 AM : [ZWAVE-RX ZW006_1] [0118000400061260]...
Tue 12/08/2015 08:35:34 AM : [ZWAVE-RX ZW006_1] [010E000400060832]...
Tue 12/08/2015 08:35:34 AM : [ZWAVE-TX        ] ACK
Tue 12/08/2015 08:35:34 AM : [D2D EVENT   ] Event [ZW006_143] [sT] [2862] uom=73 prec=2
Tue 12/08/2015 08:35:34 AM : [   ZW006_143]       ST 2862 (uom=73 prec=2)
Tue 12/08/2015 08:35:34 AM : [D2D-CMP 002D] STS [ZW006_143] ST op=3 Event(val=2862 uom=73 prec=2) > Condition(val=0 uom=73 prec=2) --> true
Tue 12/08/2015 08:35:34 AM : [ZWAVE-RX ZW006_1] [0114000400060E32]...
Tue 12/08/2015 08:35:34 AM : [ZWAVE-RX ZW006_1] [0112000400060C60]...
Tue 12/08/2015 08:35:34 AM : [ZWAVE-RX ZW006_1] [0118000400061260]...
Tue 12/08/2015 08:35:35 AM : [ZWAVE-RX ZW006_1] [0118000400061260]...
Tue 12/08/2015 08:35:35 AM : [ZWAVE-TX        ] ACK
Tue 12/08/2015 08:35:44 AM : [ZWAVE-RX ZW006_1] [010E000400060832]...
Tue 12/08/2015 08:35:44 AM : [ZWAVE-TX        ] ACK
Tue 12/08/2015 08:35:44 AM : [D2D EVENT   ] Event [ZW006_143] [sT] [2604] uom=73 prec=2
Tue 12/08/2015 08:35:44 AM : [   ZW006_143]       ST 2604 (uom=73 prec=2)
Tue 12/08/2015 08:35:44 AM : [D2D-CMP 002D] STS [ZW006_143] ST op=3 Event(val=2604 uom=73 prec=2) > Condition(val=0 uom=73 prec=2) --> true
Tue 12/08/2015 08:35:44 AM : [ZWAVE-RX ZW006_1] [0114000400060E32]...
Tue 12/08/2015 08:35:44 AM : [ZWAVE-RX ZW006_1] [0112000400060C60]...
Tue 12/08/2015 08:35:44 AM : [ZWAVE-RX ZW006_1] [0118000400061260]...
Tue 12/08/2015 08:35:45 AM : [ZWAVE-RX ZW006_1] [0118000400061260]...
Tue 12/08/2015 08:35:45 AM : [ZWAVE-TX        ] ACK
Tue 12/08/2015 08:35:54 AM : [ZWAVE-RX ZW006_1] [010E000400060832]...
Tue 12/08/2015 08:35:54 AM : [ZWAVE-TX        ] ACK
Tue 12/08/2015 08:35:54 AM : [D2D EVENT   ] Event [ZW006_143] [sT] [2846] uom=73 prec=2
Tue 12/08/2015 08:35:54 AM : [   ZW006_143]       ST 2846 (uom=73 prec=2)
Tue 12/08/2015 08:35:54 AM : [D2D-CMP 002D] STS [ZW006_143] ST op=3 Event(val=2846 uom=73 prec=2) > Condition(val=0 uom=73 prec=2) --> true
Tue 12/08/2015 08:35:54 AM : [ZWAVE-RX ZW006_1] [0114000400060E32]...
Tue 12/08/2015 08:35:54 AM : [ZWAVE-RX ZW006_1] [0112000400060C60]...
Tue 12/08/2015 08:35:54 AM : [ZWAVE-RX ZW006_1] [0118000400061260]...
Tue 12/08/2015 08:36:03 AM : [32 C0 AA    ] Added to list of devices to link to ISY
Tue 12/08/2015 08:36:03 AM : [iNST-TX-I1  ] 02 62 32 C0 AA 0F 0D 00
Tue 12/08/2015 08:36:03 AM : [iNST-ACK    ] 02 62 32.C0.AA 0F 0D 00 06                 (00)
Tue 12/08/2015 08:36:04 AM : [ZWAVE-RX ZW006_1] [0114000400060E32]...
Tue 12/08/2015 08:36:04 AM : [ZWAVE-TX        ] ACK
Tue 12/08/2015 08:36:04 AM : [ZWAVE-RX ZW006_1] [0118000400061260]...
Tue 12/08/2015 08:36:12 AM : [iNST-TX-I1  ] 02 62 32 C0 AA 0F 0D 00
Tue 12/08/2015 08:36:12 AM : [iNST-ACK    ] 02 62 32.C0.AA 0F 0D 00 06                 (00)
Tue 12/08/2015 08:36:14 AM : [ZWAVE-RX ZW006_1] [0114000400060E32]...
Tue 12/08/2015 08:36:14 AM : [ZWAVE-TX        ] ACK
Tue 12/08/2015 08:36:14 AM : [ZWAVE-RX ZW006_1] [0112000400060C60]...
Tue 12/08/2015 08:36:14 AM : [ZWAVE-RX ZW006_1] [0118000400061260]...
Tue 12/08/2015 08:36:21 AM : [iNST-TX-I1  ] 02 62 32 C0 AA 0F 0D 00
Tue 12/08/2015 08:36:21 AM : [iNST-ACK    ] 02 62 32.C0.AA 0F 0D 00 06                 (00)
Tue 12/08/2015 08:36:24 AM : [ZWAVE-RX ZW006_1] [0114000400060E32]...
Tue 12/08/2015 08:36:24 AM : [ZWAVE-TX        ] ACK
Tue 12/08/2015 08:36:24 AM : [ZWAVE-RX ZW006_1] [0118000400061260]...
Tue 12/08/2015 08:36:25 AM : [32 C0 AA 0  ] Failed to add device, reason 3
Tue 12/08/2015 08:36:25 AM : ---- Start: Generate Scenes from links ----
Tue 12/08/2015 08:36:25 AM : ---- End: Generate Scenes from links ----
Tue 12/08/2015 08:36:25 AM : [All         ] Writing 0 bytes to devices
Tue 12/08/2015 08:36:34 AM : [ZWAVE-RX ZW006_1] [010E000400060832]...
Tue 12/08/2015 08:36:34 AM : [ZWAVE-TX        ] ACK
Tue 12/08/2015 08:36:34 AM : [D2D EVENT   ] Event [ZW006_143] [sT] [2574] uom=73 prec=2
Tue 12/08/2015 08:36:34 AM : [   ZW006_143]       ST 2574 (uom=73 prec=2)
Tue 12/08/2015 08:36:34 AM : [D2D-CMP 002D] STS [ZW006_143] ST op=3 Event(val=2574 uom=73 prec=2) > Condition(val=0 uom=73 prec=2) --> true
Tue 12/08/2015 08:36:34 AM : [ZWAVE-RX ZW006_1] [0114000400060E32]...
Tue 12/08/2015 08:36:34 AM : [ZWAVE-RX ZW006_1] [0118000400061260]...
insteonadd.tiff
It is not all ZWave.  See Red lines below.  The Insteon address 32.C0.AA does not respond to 0x0D command.  The .tiff attachment in OP post indicates New INSTEON Device being used.
The .tiff attachment in OP post shows New INSTEON Device being used.
As LeeG pointed out "Failed to add device, reason 3" I believe indicates you have poor communication with the device.  You shouldn't have this problem if your electrical legs are properly bridged (coupled.)
Jon...
Could be a comm issue.   Could also indicate that [32 C0 AA ]  is not correct address of LED bulb.
EDIT:  could also be the LED bulb is in a light socket that does not have power.  Like all Insteon devices powered from 120v, the LED bulb must be powered at all times.
Thanks all! It looks like the issue was with the outlet that the PLM was in as jerlands mentioned. After relocating it to another outlet the light bulb discovers fine. Of course this moves the PLM further away from the motion sensors, so I have some more work to do to solve the distance issue.
Motion sensors do not need to be near the PLM. What is important is that the MS be within RF range of any dual-band device (and that the opposite legs of the split, single-phase electric supply be adequately bridged).
So besides the PLM the only insteon devices I have are the two MS, 2 leak detectors and now the light bulb. I opened a new thread to cover this issue. I am starting to wonder about the opposite legs being bridged. I am not sure what that means, but sounds like it could be an issue for me as I had to try a few different light sockets to get it to finally work.
     Insteon Motion Sensor range problem?
