Yale lock YRD120-ZW options page
Hi! I have 3 Yale locks YRD220-ZW, everything seams to work well.
I just bought a new lock YRD120-ZW. This is a new model with integrated Zwave chip oposed to old one YRD240-ZW which has plug-in Zwave module.
When I try to open options page first it gives a SLL error (see image) and if i close and reopen options page just get an error.
My ISY ver. is 4.3.26.
Anything I can do to fix it?
Once you get this sorted out, I'm curious to see how your battery life ends up. It'd be nice if they made some design changes that resulted in longer battery life.
I've got 4 of the older ones and battery life was a handful of weeks if I was lucky, but after a tip here or from reddit, I added a status test so that I'd only send commands when they were needed and it doubled or tripled the battery life. For example, when the front door is locked I send a lock command to all the others... I changed that behavior by adding an "if not locked" test for each lock to cut down on the number of noop signals sent.
Edited by fryfrog
I have the same issue with the newer keyless (YRD120-ZW) yale locks.  I have 2 of these.   My other lock with key (YRD220-ZW) works just fine.  I get the same error message as the OP when trying to access the options page.
All other interactions with the locks seem fine, although one seems to randomly show status of unlocked when it has not been touched.  Not sure if that is a zwave issue or not.
Here are my versions
ISY version 4.3.26
UI version 4.2.18
Your UI should match the ISY version. You'll need to clear your Java cache.
Upgraded the UI to 4.3.26.  Same issue.  Tested all 3 locks multiple times.  Older lock works fine.  The two newer keyless locks fail on the options page.
For what it's worth, I get the same "request error", but I was pretty sure when I first set it up back in August of this year, I didn't. I think that was with an earlier version of the ISY UI and firmware, but I don't remember. I'm on 4.3.26 now for the firmware and UI.
@fryfrog, I installed the lock the end of Aug 2015. The battery life is at 87% with the original batteries.
Edited by joelika
I have a Yale lock that was connected to my Veralite equipment and then I switched the ISY and added in the Z wave module. I am not able to add it to my network. Is there a way to find out why it will not add?
Do an exclude or two first. Move it close to the ISY. Those are the two main things for getting a lock to pair, in my experience. Pairing before installation w/ it next to ISY has been my best result. Moving the ISY is painful because of network and PLM, but I've done that too.
