Leak sensors
Hi
I just updated my ISY and now the leak sensors are not showing there status, do I have to reset them ?
Thanks Jeff
Hi
Thanks Jeff
No, but you can press the set button if you simply wish to see some kind of status like on/off/heartbeat.
Thanks Teken
Will they start showing status on there own ? It doesn't come up on the ISY or mobilinc, One is easy to get at , in the basement, other is under the dishwasher and have to take the front panel to get to it
Thanks Teken
Hello Jeff,
The Admin Console will only show if a status change, or if the device trips or you press the set button manually. Also, if you have not created the heart beat tracking program from Belias please do so.
As its one of the most powerful programs out there that offers great insight and e-mail notifications of the status of the leak sensor or any device that has the heart beat node feature.
Edited by Teken
My newer LeakLincs send different commands from a long tap and a short tap. IIRC one is a Wet On and the other is Dry On.
Yeah. I triggered my pump shut off, send notification to my wife out shopping, and flashed my lights and doorbell again  until I figured it out.
Moral? Tapping the link button does not always reset the programs.
Now I send a piece of text with my notifications:
     "To restore the water pressure press "AAAA" on the KPL"
My multi code combination program can decode many codes and reset things.
http://forum.universal-devices.com/topic/16135-using-keypad-triggers-for-a-multiple-combination-locks/
