Help using nodelink
Paul is exactly right - a single node server only in the ISY.
After that, if you add a new device to NodeLink you just hit the Install Nodes button on its device tab in NodeLink.
OK I think I have some of the problem identified.
My backup are useless because
1 - when ISY v5.0.2 boots up it tries to identify devices and if they are not found, removes any program with usage of any device that doesn't exist. No unknown place holders are left.
2 - I cannot replace my T7900 device vai NodeLink 4.1 because ISY has named the node "n001_gathrmstat -" from the original NodeLink 3.x install Nodes command process.
     Now it would appear that a node name with "gathrmstat" is not possible and the longest node name that NodeLink v4.1 will truncate to is "gathrmsta".  It seems the allowable v4.1 node name length is only 9 characters instead of the 10 characters NodeLink 3.x previously truncated the name to.
ISY cannot be fooled into thinking this device is the same device, as it knew of previously, and deletes any of my programs that even mention the device "n001_gathrmstat"
Any ideas?
Not following, just delete the node from the ISY and reinstall it from NodeLink.
Here are the two node names
NodeLink 4.1 cannot produce the original node name 10 character long node name NodeLink 3.x produced.
When ISY does not find the same Node device name it removes any and all programs that use that  node device. :(  This will take days of recreation time.
IOW: I can delete my node(s) and start over installing the nodes again.
         And all my programs will have to be written from scratch .
         The nodes do not install with any data on the device pages now??? (I can use verbose modes and view the data being sent and acknowledged by ISY) Previously a whole page of data fields were displayed in Admin Console.  Now none are displayed but I believe the programs may work. (v5.0.2 GUI bug??)
I may be able to recover this if I can load and use NodeLink v4.0 or v3.x to temporarily change the node name and do a mass Replace in ISY.
Can't help with the ISY, 5.0.2 has a bunch of node related load/view bugs
I had to shrink the node name size. The ISY limits the number of characters allowed and I needed some extra to accommodate subnodes.
OK, how can I load NodeLink v3.x into my RPi to change the node_address and then upgrade NodeLink back?
You're asking for trouble. Try editing Config.XML to the older nodename, it'd achieve the same result.
If it doesn't work, you're gonna have to bite the bullet.
I'll give that a try. I assume that is in the RPi where NodeLink is located Then restart NodeLink and see what happens?. fingers crossed....
I tried to edit theConfig.xml file but it won't see it as the original device...failed.
I started over to rebuilt things and rebuilt the two devices in NodeLink 4.1, then after removing, rebooting, reinstalling the nodesetup.zip file and rebooting, installed both T7900 Nodes from NodeLink again but they don't install.
ISY sees the attempt and installs the devices but no fields of data appear, and no parameters are available in ISY programs.  I can't install any nodes from NodeLink 4.1.
When the node installs in the ISY, you should see all the blank fields. If not it's an ISY prob. Try reloading the zip and rebooting.
I have done that probably thirty times now. It won't install any usable data. There are no blanks because there are no boxes. This worked when I installed them initially and did appear to work when I initially added the second T7900.  Quite strange that it would just quit.
Here is a verbose copy of the NodeLink reboot again.
2016-03-19 22:25:35 - ISY NodeLink Server v0.4.1 started
2016-03-19 22:25:37 - Web config server started (http://192.168.0.175:8090)
2016-03-19 22:25:37 - ISY resolved to 192.168.0.161
2016-03-19 22:25:38 - ISY: <?xml version="1.0"?><root xmlns="urn:schemas-upnp-org:device-1-0"><specVersion><major>1</major><minor>0</minor></specVersion><URLBase>http://192.168.0.161</URLBase><device><deviceType>urn:udi-com:device:X_Insteon_Lighting_Device:1</deviceType><friendlyName>ISY</friendlyName><manufacturer>Universal Devices Inc.</manufacturer><manufacturerURL>http://www.universal-devices.com</manufacturerURL><modelDescription>X_Insteon_Lighting_Device:1</modelDescription><modelName>ISY 994i 1024</modelName><modelNumber>1100</modelNumber><UDN>uuid:00:21:b9:02:00:42</UDN><UPC>uuid:00:21:b9:02:00:42</UPC><serviceList><service><serviceType>urn:udi-com:service:X_Insteon_Lighting_Service:1</serviceType><serviceId>urn:udi-com:serviceId:uuid:00:21:b9:02:00:42</serviceId><SCPDURL>/services.wsdl</SCPDURL><controlURL>/services</controlURL><eventSubURL>/eventing</eventSubURL></service><service><serviceType>UDIELKWebServices</serviceType><serviceId>uuid:00:21:b9:02:00:42-UDIELKWebServices</serviceId><SCPDURL>/elkServices.wsdl</SCPDURL><controlURL>/security/elk</controlURL></service><service><serviceType>UDISEPWebServices</serviceType><serviceId>uuid:00:21:b9:02:00:42-UDISEPWebServices</serviceId><SCPDURL>/sepServices.wsdl</SCPDURL><controlURL>/sepServices</controlURL></service><service><serviceType>UDIZWaveWebServices</serviceType><serviceId>uuid:00:21:b9:02:00:42-UDIZWaveWebServices</serviceId><SCPDURL>/zwaveServices.wsdl</SCPDURL><controlURL>/zwaveServices</controlURL></service></serviceList><presentationURL>/</presentationURL></device></root> (desc)
2016-03-19 22:25:39 - ISY: Node list request sent
2016-03-19 22:25:41 - ISY: <?xml version="1.0" encoding="UTF-8"?><nodes><root></root><folder flag="0"><address>11805</address><name>Garage</name></folder><folder flag="0"><address>17640</address><name>Mudroom</name></folder><folder flag="0"><address>1922</address><name>Dining Room</name></folder><folder flag="0"><address>27073</address><name>Library</name></folder><folder flag="0"><address>2829</address><name>Workshop</name></folder><folder flag="0"><address>28354</address><name>Evening Bedroom</name></folder><folder flag="0"><address>30216</address><name>Afternoon Bedroom</name></folder><folder flag="0"><address>32574</address><name>Utility Room</name></folder><folder flag="0"><address>35343</address><name>HVAC</name></folder><folder flag="0"><address>36547</address><name>Lower Landing</name></folder><folder flag="0"><address>39461</address><name>Rec Room</name></folder><folder flag="0"><address>40814</address><name>Foyer</name></folder><folder flag="0"><address>42163</address><name>Gathering Room</name></folder><folder flag="0"><address>53830</address><name>Master Bedroom</name></folder><folder flag="0"><address>55547</address><name>Cold Cellar</name></folder><folder flag="0"><address>59855</address><name>Kitchen</name></folder><node flag="128" nodeDefId="BinaryControl"><address>19 8E 3E 1</address><name>Dryer</name><parent type="3">17640</parent><type>7.9.48.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>19 8E 3E 1</pnode><ELK_ID>F02</ELK_ID><property id="ST" value="0" formatted="0%" uom="%/on/off" /></node><node flag="128" nodeDefId="DimmerLampSwitch"><address>1A D9 D0 1</address><name>MBR Wall Lamp</name><parent type="3">53830</parent><type>1.14.65.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>1A D9 D0 1</pnode><ELK_ID>C07</ELK_ID><property id="ST" value="0" formatted="0%" uom="%/on/off" /></node><node flag="128" nodeDefId="DimmerLampSwitch"><address>1A DA 2C 1</address><name>Libr Bankers Lamp</name><parent type="3">27073</parent><type>1.14.65.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>1A DA 2C 1</pnode><ELK_ID>C10</ELK_ID><property id="ST" value="0" formatted="0%" uom="%/on/off" /></node><node flag="128" nodeDefId="Thermostat"><address>20 48 B3 1</address><name>CCell Therm</name><parent type="3">55547</parent><type>5.10.13.0</type><enabled>true</enabled><deviceClass>1</deviceClass><wattage>1000</wattage><dcPeriod>60</dcPeriod><pnode>20 48 B3 1</pnode><ELK_ID>B01</ELK_ID><property id="ST" value=" " formatted=" " uom="degrees"/><property id="CLIMD" value="3" formatted="Auto" uom="n/a" /><property id="CLISPC" value="50" formatted="25.0°" uom="degrees" /><property id="CLISPH" value="8" formatted="4.0°" uom="degrees" /><property id="CLIHUM" value="52" formatted="52%" uom="%" /></node><node flag="0" nodeDefId="OnOffControl"><address>20 48 B3 2</address><name>CCell Therm.cool</name><parent type="1">20 48 B3 1</parent><type>5.10.13.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>20 48 B3 1</pnode><ELK_ID>B02</ELK_ID><property id="ST" value=" " formatted=" " uom="%/on/off"/></node><node flag="0" nodeDefId="OnOffControl"><address>20 48 B3 3</address><name>CCell Therm.heat</name><parent type="1">20 48 B3 1</parent><type>5.10.13.0</type><enabled>true</enabled><deviceClass>1</deviceClass><wattage>1000</wattage><dcPeriod>60</dcPeriod><pnode>20 48 B3 1</pnode><ELK_ID>B04</ELK_ID><property id="ST" value=" " formatted=" " uom="%/on/off"/></node><node flag="128" nodeDefId="RelayLampOnly"><address>20 C4 C7 1</address><name>spare ApplianceLinc.1</name><type>2.9.66.0</type><enabled>false</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>20 C4 C7 1</pnode><ELK_ID>C11</ELK_ID><property id="ST" value=" " formatted=" " uom="on/off"/></node><node flag="128" nodeDefId="RelayLampOnly"><address>22 C3 CF 1</address><name>CCel Ventilation Fan</name><parent type="3">55547</parent><type>2.9.66.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>22 C3 CF 1</pnode><ELK_ID>A03</ELK_ID><property id="ST" value="255" formatted="100%" uom="on/off" /></node><node flag="128" nodeDefId="Thermostat"><address>22 F 53 1</address><name>Util Therm</name><parent type="3">32574</parent><type>5.10.53.0</type><enabled>true</enabled><deviceClass>1</deviceClass><wattage>1000</wattage><dcPeriod>60</dcPeriod><pnode>22 F 53 1</pnode><ELK_ID>B08</ELK_ID><property id="ST" value=" " formatted=" " uom="degrees"/><property id="CLIMD" value="1" formatted="Heat" uom="n/a" /><property id="CLISPC" value="54" formatted="27.0°" uom="degrees" /><property id="CLISPH" value="32" formatted="16.0°" uom="degrees" /><property id="CLIHUM" value="38" formatted="38%" uom="%" /></node><node flag="0" nodeDefId="OnOffControl"><address>22 F 53 2</address><name>Util Therm.cool</name><parent type="1">22 F 53 1</parent><type>5.10.53.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>22 F 53 1</pnode><ELK_ID>E12</ELK_ID><property id="ST" value=" " formatted=" " uom="%/on/off"/></node><node flag="0" nodeDefId="OnOffControl"><address>22 F 53 3</address><name>Util Therm.heat</name><parent type="1">22 F 53 1</parent><type>5.10.53.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>22 F 53 1</pnode><ELK_ID>E13</ELK_ID><property id="ST" value=" " formatted=" " uom="%/on/off"/></node><node flag="128" nodeDefId="DimmerLampSwitch"><address>23 6D 7B 1</address><name>spare LampLinc.4</name><type>1.14.65.0</type><enabled>false</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>23 6D 7B 1</pnode><ELK_ID>A04</ELK_ID><property id="ST" value=" " formatted=" " uom="%/on/off"/></node><node flag="128" nodeDefId="BinaryAlarm"><address>25 B2 4E 1</address><name>Util Leak.dry</name><parent type="3">32574</parent><type>16.8.65.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>25 B2 4E 1</pnode><ELK_ID>D13</ELK_ID><property id="ST" value=" " formatted=" " uom="on/off"/></node><node flag="0" nodeDefId="BinaryAlarm"><address>25 B2 4E 2</address><name>Util Leak.Wet</name><parent type="3">32574</parent><type>16.8.65.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>25 B2 4E 1</pnode><ELK_ID>D14</ELK_ID><property id="ST" value=" " formatted=" " uom="on/off"/></node><node flag="0" nodeDefId="BinaryAlarm"><address>25 B2 4E 4</address><name>Util Leak.heartbeat</name><parent type="3">32574</parent><type>16.8.65.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>25 B2 4E 1</pnode><ELK_ID>D15</ELK_ID><property id="ST" value=" " formatted=" " uom="on/off"/></node><node flag="128" nodeDefId="DimmerLampSwitch"><address>26 B7 D6 1</address><name>RecRm Cabinet Light</name><parent type="3">39461</parent><type>1.14.65.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>26 B7 D6 1</pnode><ELK_ID>D09</ELK_ID><property id="ST" value="0" formatted="0%" uom="%/on/off" /></node><node flag="128" nodeDefId="DimmerLampSwitch"><address>26 BA 73 1</address><name>AftBR Table Lamp</name><parent type="3">30216</parent><type>1.14.65.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>26 BA 73 1</pnode><ELK_ID>C09</ELK_ID><property id="ST" value="0" formatted="0%" uom="%/on/off" /></node><node flag="128" nodeDefId="DimmerLampSwitch"><address>26 C5 EB 1</address><name>LL Clock Lamp</name><parent type="3">36547</parent><type>1.14.65.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>26 C5 EB 1</pnode><ELK_ID>C01</ELK_ID><property id="ST" value="0" formatted="0%" uom="%/on/off" /></node><node flag="128" nodeDefId="DimmerLampSwitch"><address>26 C6 80 1</address><name>EveBR Table Lamp</name><parent type="3">28354</parent><type>1.14.65.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>26 C6 80 1</pnode><ELK_ID>C08</ELK_ID><property id="ST" value="0" formatted="0%" uom="%/on/off" /></node><node flag="128" nodeDefId="DimmerLampSwitch"><address>26 D2 CE 1</address><name>Libr Table Lamp</name><parent type="3">27073</parent><type>1.14.65.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>26 D2 CE 1</pnode><ELK_ID>E16</ELK_ID><property id="ST" value="0" formatted="0%" uom="%/on/off" /></node><node flag="128" nodeDefId="DimmerSwitchOnly"><address>27 1B 85 1</address><name>GathRm KeyPad.A</name><parent type="3">42163</parent><type>0.16.55.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>27 1B 85 1</pnode><ELK_ID>E03</ELK_ID><property id="ST" value=" " formatted=" " uom="%/on/off"/></node><node flag="0" nodeDefId="DimmerSwitchOnly"><address>27 1B 85 2</address><name>GathRm KeyPad.B</name><parent type="3">42163</parent><type>0.16.55.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>27 1B 85 1</pnode><ELK_ID>E04</ELK_ID><property id="ST" value=" " formatted=" " uom="%/on/off"/></node><node flag="0" nodeDefId="DimmerSwitchOnly"><address>27 1B 85 3</address><name>GathRm KeyPad.C</name><parent type="3">42163</parent><type>0.16.55.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>27 1B 85 1</pnode><ELK_ID>E05</ELK_ID><property id="ST" value=" " formatted=" " uom="%/on/off"/></node><node flag="0" nodeDefId="DimmerSwitchOnly"><address>27 1B 85 4</address><name>GathRm KeyPad.D</name><parent type="3">42163</parent><type>0.16.55.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>27 1B 85 1</pnode><ELK_ID>E06</ELK_ID><property id="ST" value=" " formatted=" " uom="%/on/off"/></node><node flag="128" nodeDefId="BinaryAlarm"><address>27 8C 31 1</address><name>Motion.Shop</name><parent type="3">2829</parent><type>16.1.65.0</type><enabled>true</enabled><deviceClass>512</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>27 8C 31 1</pnode><ELK_ID>C13</ELK_ID><property id="ST" value=" " formatted=" " uom="on/off"/></node><node flag="0" nodeDefId="BinaryAlarm"><address>27 8C 31 2</address><name>Dark.Shop</name><parent type="1">27 8C 31 1</parent><type>16.1.65.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>27 8C 31 1</pnode><ELK_ID>C14</ELK_ID><property id="ST" value="0" formatted="0%" uom="on/off" /></node><node flag="0" nodeDefId="BinaryAlarm"><address>27 8C 31 3</address><name>LowBat.Shop MS</name><parent type="1">27 8C 31 1</parent><type>16.1.65.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>27 8C 31 1</pnode><ELK_ID>C15</ELK_ID><property id="ST" value=" " formatted=" " uom="on/off"/></node><node flag="128" nodeDefId="RelayLampSwitch"><address>27 CE B2 1</address><name>Shop Webcontrol Board</name><parent type="3">2829</parent><type>2.55.70.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>27 CE B2 1</pnode><ELK_ID>A02</ELK_ID><property id="ST" value="255" formatted="100%" uom="on/off" /></node><node flag="128" nodeDefId="BinaryAlarm"><address>28 40 E7 1</address><name>Motion.MBR</name><parent type="3">53830</parent><type>16.1.65.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>28 40 E7 1</pnode><ELK_ID>B09</ELK_ID><property id="ST" value=" " formatted=" " uom="on/off"/></node><node flag="0" nodeDefId="BinaryAlarm"><address>28 40 E7 2</address><name>Dark.MBR</name><parent type="1">28 40 E7 1</parent><type>16.1.65.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>28 40 E7 1</pnode><ELK_ID>D04</ELK_ID><property id="ST" value=" " formatted=" " uom="on/off"/></node><node flag="0" nodeDefId="BinaryAlarm"><address>28 40 E7 3</address><name>LowBatt.MBR.MS</name><parent type="1">28 40 E7 1</parent><type>16.1.65.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>28 40 E7 1</pnode><ELK_ID>E11</ELK_ID><property id="ST" value=" " formatted=" " uom="on/off"/></node><node flag="128" nodeDefId="BinaryAlarm"><address>28 56 C 1</address><name>MudRm Leak.dry</name><parent type="3">17640</parent><type>16.8.65.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>28 56 C 1</pnode><ELK_ID>F16</ELK_ID><property id="ST" value=" " formatted=" " uom="on/off"/></node><node flag="0" nodeDefId="BinaryAlarm"><address>28 56 C 2</address><name>MudRm Leak.Wet</name><parent type="1">28 56 C 1</parent><type>16.8.65.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>28 56 C 1</pnode><ELK_ID>G01</ELK_ID><property id="ST" value=" " formatted=" " uom="on/off"/></node><node flag="0" nodeDefId="BinaryAlarm"><address>28 56 C 4</address><name>MudRm Leak.heartbeat</name><parent type="1">28 56 C 1</parent><type>16.8.65.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>28 56 C 1</pnode><ELK_ID>G02</ELK_ID><property id="ST" value=" " formatted=" " uom="on/off"/></node><node flag="128" nodeDefId="DimmerLampSwitch"><address>29 BE B7 1</address><name>PotLights over Chairs</name><parent type="3">42163</parent><type>1.32.65.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>29 BE B7 1</pnode><ELK_ID>C12</ELK_ID><property id="ST" value="0" formatted="0%" uom="%/on/off" /></node><node flag="128" nodeDefId="DimmerLampSwitch"><address>29 C1 25 1</address><name>PotLight over Table</name><parent type="3">42163</parent><type>1.32.65.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>29 C1 25 1</pnode><ELK_ID>C04</ELK_ID><property id="ST" value="0" formatted="0%" uom="%/on/off" /></node><node flag="128" nodeDefId="DimmerLampSwitch"><address>29 C2 B 1</address><name>PotLight over Desk</name><parent type="3">42163</parent><type>1.32.65.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>29 C2 B 1</pnode><ELK_ID>D03</ELK_ID><property id="ST" value="0" formatted="0%" uom="%/on/off" /></node><node flag="128" nodeDefId="DimmerLampSwitch"><address>29 C3 DB 1</address><name>Kitchen Bar PotLights</name><parent type="3">59855</parent><type>1.32.65.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>29 C3 DB 1</pnode><ELK_ID>D07</ELK_ID><property id="ST" value="0" formatted="0%" uom="%/on/off" /></node><node flag="128" nodeDefId="DimmerLampSwitch"><address>29 D2 4E 1</address><name>Side Deck Lights</name><parent type="3">40814</parent><type>1.32.65.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>29 D2 4E 1</pnode><ELK_ID>E02</ELK_ID><property id="ST" value="0" formatted="0%" uom="%/on/off" /></node><node flag="128" nodeDefId="DimmerLampSwitch"><address>29 D4 C4 1</address><name>Dining Table</name><parent type="3">1922</parent><type>1.32.65.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>29 D4 C4 1</pnode><ELK_ID>B03</ELK_ID><property id="ST" value="0" formatted="0%" uom="%/on/off" /></node><node flag="128" nodeDefId="DimmerLampSwitch"><address>29 E2 59 1</address><name>Front Porch Lights</name><parent type="3">40814</parent><type>1.32.65.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>29 E2 59 1</pnode><ELK_ID>D05</ELK_ID><property id="ST" value="0" formatted="0%" uom="%/on/off" /></node><node flag="128" nodeDefId="BinaryControl"><address>2B F9 D1 1</address><name>Doorbell.Front.Button</name><parent type="3">40814</parent><type>7.0.65.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>2B F9 D1 1</pnode><ELK_ID>F03</ELK_ID><property id="ST" value="0" formatted="0%" uom="on/off" /></node><node flag="0" nodeDefId="BinaryControl"><address>2B F9 D1 2</address><name>Doorbell.Back</name><parent type="3">40814</parent><type>7.0.65.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>2B F9 D1 1</pnode><ELK_ID>F04</ELK_ID><property id="ST" value="0" formatted="0%" uom="on/off" /></node><node flag="128" nodeDefId="BinaryAlarm"><address>2D 64 8E 1</address><name>Motion.RecRm</name><parent type="3">39461</parent><type>16.1.65.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>2D 64 8E 1</pnode><ELK_ID>F12</ELK_ID><property id="ST" value=" " formatted=" " uom="on/off"/></node><node flag="0" nodeDefId="BinaryAlarm"><address>2D 64 8E 2</address><name>Dark.RecRm</name><parent type="1">2D 64 8E 1</parent><type>16.1.65.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>2D 64 8E 1</pnode><ELK_ID>F13</ELK_ID><property id="ST" value=" " formatted=" " uom="on/off"/></node><node flag="0" nodeDefId="BinaryAlarm"><address>2D 64 8E 3</address><name>LowBat.RecRm.MS</name><parent type="1">2D 64 8E 1</parent><type>16.1.65.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>2D 64 8E 1</pnode><ELK_ID>F15</ELK_ID><property id="ST" value=" " formatted=" " uom="on/off"/></node><node flag="128" nodeDefId="BinaryAlarm"><address>2D 67 81 1</address><name>Motion.MudRm</name><parent type="3">17640</parent><type>16.1.65.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>2D 67 81 1</pnode><ELK_ID>G03</ELK_ID><property id="ST" value=" " formatted=" " uom="on/off"/></node><node flag="0" nodeDefId="BinaryAlarm"><address>2D 67 81 2</address><name>Dark.MudRm</name><parent type="1">2D 67 81 1</parent><type>16.1.65.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>2D 67 81 1</pnode><ELK_ID>G04</ELK_ID><property id="ST" value=" " formatted=" " uom="on/off"/></node><node flag="0" nodeDefId="BinaryAlarm"><address>2D 67 81 3</address><name>LowBatt.MudRm.MS</name><parent type="1">2D 67 81 1</parent><type>16.1.65.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>2D 67 81 1</pnode><ELK_ID>G05</ELK_ID><property id="ST" value=" " formatted=" " uom="on/off"/></node><node flag="128" nodeDefId="DimmerLampSwitch"><address>2E 62 FE 1</address><name>spare LampLinc.1</name><type>1.14.67.0</type><enabled>false</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>2E 62 FE 1</pnode><ELK_ID>E07</ELK_ID><property id="ST" value=" " formatted=" " uom="%/on/off"/></node><node flag="128" nodeDefId="DimmerLampSwitch"><address>2E 6C 31 1</address><name>spare LampLinc.3</name><type>1.14.67.0</type><enabled>false</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>2E 6C 31 1</pnode><ELK_ID>H02</ELK_ID><property id="ST" value=" " formatted=" " uom="%/on/off"/></node><node flag="128" nodeDefId="DimmerLampSwitch"><address>2E 6C 89 1</address><name>spare LampLinc.2</name><type>1.14.67.0</type><enabled>false</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>2E 6C 89 1</pnode><ELK_ID>E08</ELK_ID><property id="ST" value=" " formatted=" " uom="%/on/off"/></node><node flag="128" nodeDefId="DimmerSwitchOnly"><address>2E 71 91 1</address><name>MBR KeyPad.A</name><parent type="3">53830</parent><type>0.16.55.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>2E 71 91 1</pnode><ELK_ID>E15</ELK_ID><property id="ST" value=" " formatted=" " uom="%/on/off"/></node><node flag="0" nodeDefId="DimmerSwitchOnly"><address>2E 71 91 2</address><name>MBR KeyPad.B</name><parent type="3">53830</parent><type>0.16.55.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>2E 71 91 1</pnode><ELK_ID>F07</ELK_ID><property id="ST" value=" " formatted=" " uom="%/on/off"/></node><node flag="0" nodeDefId="DimmerSwitchOnly"><address>2E 71 91 3</address><name>MBR KeyPad.C</name><parent type="3">53830</parent><type>0.16.55.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>2E 71 91 1</pnode><ELK_ID>F08</ELK_ID><property id="ST" value=" " formatted=" " uom="%/on/off"/></node><node flag="0" nodeDefId="DimmerSwitchOnly"><address>2E 71 91 4</address><name>MBR KeyPad.D</name><parent type="3">53830</parent><type>0.16.55.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>2E 71 91 1</pnode><ELK_ID>F09</ELK_ID><property id="ST" value=" " formatted=" " uom="%/on/off"/></node><node flag="128" nodeDefId="BinaryAlarm"><address>31 D6 CA 1</address><name>Motion.AftBR</name><parent type="3">30216</parent><type>16.1.65.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>31 D6 CA 1</pnode><ELK_ID>G15</ELK_ID><property id="ST" value=" " formatted=" " uom="on/off"/></node><node flag="0" nodeDefId="BinaryAlarm"><address>31 D6 CA 2</address><name>Dark.AftBR</name><parent type="1">31 D6 CA 1</parent><type>16.1.65.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>31 D6 CA 1</pnode><ELK_ID>G16</ELK_ID><property id="ST" value=" " formatted=" " uom="on/off"/></node><node flag="0" nodeDefId="BinaryAlarm"><address>31 D6 CA 3</address><name>LowBatt.AftBR.MS</name><parent type="1">31 D6 CA 1</parent><type>16.1.65.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>31 D6 CA 1</pnode><ELK_ID>H01</ELK_ID><property id="ST" value=" " formatted=" " uom="on/off"/></node><node flag="128" nodeDefId="BinaryAlarm"><address>31 DD 62 1</address><name>Motion.LLand</name><parent type="3">36547</parent><type>16.1.65.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>31 DD 62 1</pnode><ELK_ID>G12</ELK_ID><property id="ST" value="255" formatted="100%" uom="on/off" /></node><node flag="0" nodeDefId="BinaryAlarm"><address>31 DD 62 2</address><name>Dark.LLand</name><parent type="1">31 DD 62 1</parent><type>16.1.65.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>31 DD 62 1</pnode><ELK_ID>G13</ELK_ID><property id="ST" value=" " formatted=" " uom="on/off"/></node><node flag="0" nodeDefId="BinaryAlarm"><address>31 DD 62 3</address><name>LowBatt.LLand.MS</name><parent type="1">31 DD 62 1</parent><type>16.1.65.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>31 DD 62 1</pnode><ELK_ID>G14</ELK_ID><property id="ST" value=" " formatted=" " uom="on/off"/></node><node flag="128" nodeDefId="BinaryAlarm"><address>31 DD 64 1</address><name>Motion.EveBR</name><parent type="3">28354</parent><type>16.1.65.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>31 DD 64 1</pnode><ELK_ID>G07</ELK_ID><property id="ST" value=" " formatted=" " uom="on/off"/></node><node flag="0" nodeDefId="BinaryAlarm"><address>31 DD 64 2</address><name>Dark.EveBR</name><parent type="1">31 DD 64 1</parent><type>16.1.65.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>31 DD 64 1</pnode><ELK_ID>G10</ELK_ID><property id="ST" value=" " formatted=" " uom="on/off"/></node><node flag="0" nodeDefId="BinaryAlarm"><address>31 DD 64 3</address><name>LowBatt.EveBR.MS</name><parent type="1">31 DD 64 1</parent><type>16.1.65.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>31 DD 64 1</pnode><ELK_ID>G11</ELK_ID><property id="ST" value=" " formatted=" " uom="on/off"/></node><node flag="128" nodeDefId="RelayLampSwitch"><address>32 2B 58 1</address><name>Xmas Lights.sequencer</name><parent type="3">40814</parent><type>2.56.67.0</type><enabled>false</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>32 2B 58 1</pnode><ELK_ID>C02</ELK_ID><property id="ST" value=" " formatted=" " uom="on/off"/></node><node flag="128" nodeDefId="BinaryControl"><address>34 6E 8A 1</address><name>MudRm IO.Linc.input</name><parent type="3">17640</parent><type>7.0.65.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>34 6E 8A 1</pnode><ELK_ID>H12</ELK_ID><property id="ST" value="0" formatted="0%" uom="on/off" /></node><node flag="0" nodeDefId="BinaryControl"><address>34 6E 8A 2</address><name>MudRm Beeper</name><parent type="3">17640</parent><type>7.0.65.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>34 6E 8A 1</pnode><ELK_ID>H13</ELK_ID><property id="ST" value="0" formatted="0%" uom="on/off" /></node><node flag="128" nodeDefId="DimmerLampSwitch"><address>34 7C 2C 1</address><name>MudRm Potlights</name><parent type="3">17640</parent><type>1.66.68.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>34 7C 2C 1</pnode><ELK_ID>H04</ELK_ID><property id="ST" value="0" formatted="0%" uom="%/on/off" /></node><node flag="0" nodeDefId="KeypadButton"><address>34 7C 2C 3</address><name>MudRm KeyPad.A</name><parent type="1">34 7C 2C 1</parent><type>1.66.68.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>34 7C 2C 1</pnode><ELK_ID>H05</ELK_ID><property id="ST" value="255" formatted="100%" uom="%/on/off" /></node><node flag="0" nodeDefId="KeypadButton"><address>34 7C 2C 4</address><name>MudRm KeyPad.B</name><parent type="1">34 7C 2C 1</parent><type>1.66.68.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>34 7C 2C 1</pnode><ELK_ID>H06</ELK_ID><property id="ST" value="0" formatted="0%" uom="%/on/off" /></node><node flag="0" nodeDefId="KeypadButton"><address>34 7C 2C 5</address><name>MudRm KeyPad.C</name><parent type="1">34 7C 2C 1</parent><type>1.66.68.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>34 7C 2C 1</pnode><ELK_ID>H07</ELK_ID><property id="ST" value="0" formatted="0%" uom="%/on/off" /></node><node flag="0" nodeDefId="KeypadButton"><address>34 7C 2C 6</address><name>MudRm KeyPad.D</name><parent type="1">34 7C 2C 1</parent><type>1.66.68.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>34 7C 2C 1</pnode><ELK_ID>H08</ELK_ID><property id="ST" value="255" formatted="100%" uom="%/on/off" /></node><node flag="128" nodeDefId="BinaryControl"><address>34 8D BC 1</address><name>Garage Door.closed</name><parent type="3">11805</parent><type>7.0.65.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>34 8D BC 1</pnode><ELK_ID>C03</ELK_ID><property id="ST" value="255" formatted="100%" uom="on/off" /></node><node flag="0" nodeDefId="BinaryControl"><address>34 8D BC 2</address><name>Garage Door-Relay</name><parent type="3">11805</parent><type>7.0.65.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>34 8D BC 1</pnode><ELK_ID>H09</ELK_ID><property id="ST" value="0" formatted="0%" uom="on/off" /></node><node flag="128" nodeDefId="BinaryAlarm"><address>36 78 CD 1</address><name>Motion.DinRm</name><parent type="3">1922</parent><type>16.1.68.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>36 78 CD 1</pnode><ELK_ID>A16</ELK_ID><property id="ST" value="255" formatted="100%" uom="on/off" /></node><node flag="0" nodeDefId="BinaryAlarm"><address>36 78 CD 2</address><name>Dark.DinRm</name><parent type="1">36 78 CD 1</parent><type>16.1.68.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>36 78 CD 1</pnode><ELK_ID>B14</ELK_ID><property id="ST" value=" " formatted=" " uom="on/off"/></node><node flag="0" nodeDefId="BinaryAlarm"><address>36 78 CD 3</address><name>LowBatt.DinRm.MS</name><parent type="1">36 78 CD 1</parent><type>16.1.68.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>36 78 CD 1</pnode><ELK_ID>H16</ELK_ID><property id="ST" value=" " formatted=" " uom="on/off"/></node><node flag="128" nodeDefId="BinaryAlarm"><address>36 78 EE 1</address><name>Motion.Util</name><parent type="3">32574</parent><type>16.1.68.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>36 78 EE 1</pnode><ELK_ID>B16</ELK_ID><property id="ST" value=" " formatted=" " uom="on/off"/></node><node flag="0" nodeDefId="BinaryAlarm"><address>36 78 EE 2</address><name>Dark.Util</name><parent type="1">36 78 EE 1</parent><type>16.1.68.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>36 78 EE 1</pnode><ELK_ID>F10</ELK_ID><property id="ST" value=" " formatted=" " uom="on/off"/></node><node flag="0" nodeDefId="BinaryAlarm"><address>36 78 EE 3</address><name>LowBatt.Util.MS</name><parent type="1">36 78 EE 1</parent><type>16.1.68.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>36 78 EE 1</pnode><ELK_ID>F11</ELK_ID><property id="ST" value=" " formatted=" " uom="on/off"/></node><node flag="128" nodeDefId="BinaryAlarm"><address>36 94 BA 1</address><name>Motion.Libr</name><parent type="3">27073</parent><type>16.1.68.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>36 94 BA 1</pnode><ELK_ID>B10</ELK_ID><property id="ST" value=" " formatted=" " uom="on/off"/></node><node flag="0" nodeDefId="BinaryAlarm"><address>36 94 BA 2</address><name>Dark.Libr</name><parent type="1">36 94 BA 1</parent><type>16.1.68.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>36 94 BA 1</pnode><ELK_ID>D10</ELK_ID><property id="ST" value=" " formatted=" " uom="on/off"/></node><node flag="0" nodeDefId="BinaryAlarm"><address>36 94 BA 3</address><name>LowBatt.Libr.MS</name><parent type="1">36 94 BA 1</parent><type>16.1.68.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>36 94 BA 1</pnode><ELK_ID>F01</ELK_ID><property id="ST" value=" " formatted=" " uom="on/off"/></node><node flag="128" nodeDefId="BinaryAlarm"><address>36 B5 53 1</address><name>HVAC Leak.dry</name><parent type="3">35343</parent><type>16.8.67.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>36 B5 53 1</pnode><ELK_ID>I01</ELK_ID><property id="ST" value=" " formatted=" " uom="on/off"/></node><node flag="0" nodeDefId="BinaryAlarm"><address>36 B5 53 2</address><name>HVAC Leak.Wet</name><parent type="3">35343</parent><type>16.8.67.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>36 B5 53 1</pnode><ELK_ID>I02</ELK_ID><property id="ST" value=" " formatted=" " uom="on/off"/></node><node flag="0" nodeDefId="BinaryAlarm"><address>36 B5 53 4</address><name>HVAC Leak.heartbeat</name><parent type="3">35343</parent><type>16.8.67.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>36 B5 53 1</pnode><ELK_ID>I03</ELK_ID><property id="ST" value=" " formatted=" " uom="on/off"/></node><node flag="128" nodeDefId="BinaryAlarm"><address>36 CA 8E 1</address><name>Kitchen Leak.dry</name><parent type="3">59855</parent><type>16.8.67.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>36 CA 8E 1</pnode><ELK_ID>I04</ELK_ID><property id="ST" value=" " formatted=" " uom="on/off"/></node><node flag="0" nodeDefId="BinaryAlarm"><address>36 CA 8E 2</address><name>Kitchen Leak.Wet</name><parent type="3">59855</parent><type>16.8.67.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>36 CA 8E 1</pnode><ELK_ID>I05</ELK_ID><property id="ST" value=" " formatted=" " uom="on/off"/></node><node flag="0" nodeDefId="BinaryAlarm"><address>36 CA 8E 4</address><name>Kitchen Leak.heartbeat</name><parent type="3">59855</parent><type>16.8.67.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>36 CA 8E 1</pnode><ELK_ID>I06</ELK_ID><property id="ST" value=" " formatted=" " uom="on/off"/></node><node flag="128" nodeDefId="RelayLampSwitch"><address>36 E C4 1</address><name>spare OnOffLinc.2</name><type>2.55.72.0</type><enabled>false</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>36 E C4 1</pnode><ELK_ID>D16</ELK_ID><property id="ST" value=" " formatted=" " uom="on/off"/></node><node flag="128" nodeDefId="RelayLampSwitch"><address>37 31 89 1</address><name>GathRm Christmas Tree</name><type>2.55.72.0</type><enabled>false</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>37 31 89 1</pnode><ELK_ID>I10</ELK_ID><property id="ST" value=" " formatted=" " uom="on/off"/></node><node flag="128" nodeDefId="RelayLampSwitch"><address>37 3A 5 1</address><name>spare OnOffLinc.1</name><type>2.55.72.0</type><enabled>false</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>37 3A 5 1</pnode><ELK_ID>I09</ELK_ID><property id="ST" value=" " formatted=" " uom="on/off"/></node><node flag="128" nodeDefId="RelayLampSwitch"><address>37 48 2C 1</address><name>Util Well Pump</name><parent type="3">32574</parent><type>2.55.72.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>37 48 2C 1</pnode><ELK_ID>H14</ELK_ID><property id="ST" value="255" formatted="100%" uom="on/off" /></node><node flag="128" nodeDefId="RelayLampSwitch"><address>37 4C 9 1</address><name>GathRm FibreLamp</name><parent type="3">42163</parent><type>2.55.72.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>37 4C 9 1</pnode><ELK_ID>H10</ELK_ID><property id="ST" value="0" formatted="0%" uom="on/off" /></node><node flag="128" nodeDefId="RelayLampSwitch"><address>37 57 48 1</address><name>Util Heater</name><parent type="3">32574</parent><type>2.55.72.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>37 57 48 1</pnode><ELK_ID>H15</ELK_ID><property id="ST" value="0" formatted="0%" uom="on/off" /></node><node flag="128" nodeDefId="RelayLampSwitch"><address>37 5E 54 1</address><name>MudRm WashMachine</name><parent type="3">17640</parent><type>2.55.72.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>37 5E 54 1</pnode><ELK_ID>H11</ELK_ID><property id="ST" value="255" formatted="100%" uom="on/off" /></node><node flag="128" nodeDefId="BinaryControl"><address>39 47 51 1</address><name>PV Battery.charged</name><parent type="3">32574</parent><type>7.0.65.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>39 47 51 1</pnode><ELK_ID>D11</ELK_ID><property id="ST" value="255" formatted="100%" uom="on/off" /></node><node flag="0" nodeDefId="BinaryControl"><address>39 47 51 2</address><name>Util Beeper</name><parent type="3">32574</parent><type>7.0.65.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>39 47 51 1</pnode><ELK_ID>F14</ELK_ID><property id="ST" value="0" formatted="0%" uom="on/off" /></node><node flag="128" nodeDefId="BinaryControl"><address>39 A3 4E 1</address><name>HRV Fan.status.inverted</name><parent type="3">35343</parent><type>7.0.65.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>39 A3 4E 1</pnode><ELK_ID>I11</ELK_ID><property id="ST" value="255" formatted="100%" uom="on/off" /></node><node flag="0" nodeDefId="BinaryControl"><address>39 A3 4E 2</address><name>HRV Fan.control</name><parent type="3">35343</parent><type>7.0.65.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>39 A3 4E 1</pnode><ELK_ID>I12</ELK_ID><property id="ST" value="0" formatted="0%" uom="on/off" /></node><node flag="128"><address>FF 03 02 1</address><name>Libr KeyPadC2.1</name><parent type="3">27073</parent><type>113.48.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>FF 03 02 1</pnode><ELK_ID>A08</ELK_ID><property id="ST" value=" " formatted=" " uom="%/on/off"/></node><node flag="128"><address>FF 03 03 1</address><name>Libr KeyPadC2.2</name><parent type="3">27073</parent><type>113.48.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>FF 03 03 1</pnode><ELK_ID>B06</ELK_ID><property id="ST" value=" " formatted=" " uom="%/on/off"/></node><node flag="128"><address>FF 03 05 1</address><name>Xmas Lights.road trees</name><parent type="3">40814</parent><type>113.48.0.0</type><enabled>false</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>FF 03 05 1</pnode><ELK_ID>I13</ELK_ID><property id="ST" value=" " formatted=" " uom="%/on/off"/></node><node flag="128"><address>FF 03 06 1</address><name>Foyer Christmas Tree</name><parent type="3">40814</parent><type>113.48.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>FF 03 06 1</pnode><ELK_ID>G06</ELK_ID><property id="ST" value=" " formatted=" " uom="%/on/off"/></node><node flag="128"><address>FF 03 0A 1</address><name>Humidifier</name><parent type="3">40814</parent><type>113.48.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>FF 03 0A 1</pnode><ELK_ID>G08</ELK_ID><property id="ST" value=" " formatted=" " uom="%/on/off"/></node><node flag="128"><address>FF 06 04 1</address><name>Chime</name><parent type="3">39461</parent><type>113.48.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>FF 06 04 1</pnode><ELK_ID>B07</ELK_ID><property id="ST" value=" " formatted=" " uom="%/on/off"/></node><node flag="128"><address>FF 0D 01 1</address><name>Shop Dust Collector</name><parent type="3">2829</parent><type>113.48.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>FF 0D 01 1</pnode><ELK_ID>C05</ELK_ID><property id="ST" value=" " formatted=" " uom="%/on/off"/></node><node flag="128" nodeDefId="VenstarC" nls="140"><address>n001_gathrmsta</address><name>GathRm VenStat</name><family instance="1">10</family><parent type="3">42163</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>n001_gathrmsta</pnode><ELK_ID>I14</ELK_ID></node><node flag="128" nodeDefId="VenstarC" nls="140"><address>n001_utilstat</address><name>Util VenStat</name><family instance="1">10</family><parent type="3">32574</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><pnode>n001_utilstat</pnode><ELK_ID>J02</ELK_ID></node><group flag="12"><address>00:21:b9:02:00:42</address><name>ISY</name><family>6</family><members><link type="0">27 CE B2 1</link><link type="0">22 C3 CF 1</link><link type="0">23 6D 7B 1</link><link type="0">FF 03 02 1</link><link type="0">36 78 CD 1</link><link type="0">20 48 B3 1</link><link type="0">20 48 B3 2</link><link type="0">29 D4 C4 1</link><link type="0">20 48 B3 3</link><link type="0">FF 03 03 1</link><link type="0">FF 06 04 1</link><link type="0">22 F 53 1</link><link type="0">28 40 E7 1</link><link type="0">36 94 BA 1</link><link type="0">36 78 CD 2</link><link type="0">36 78 EE 1</link><link type="0">26 C5 EB 1</link><link type="0">32 2B 58 1</link><link type="0">34 8D BC 1</link><link type="0">29 C1 25 1</link><link type="0">FF 0D 01 1</link><link type="0">1A D9 D0 1</link><link type="0">26 C6 80 1</link><link type="0">26 BA 73 1</link><link type="0">1A DA 2C 1</link><link type="0">20 C4 C7 1</link><link type="0">29 BE B7 1</link><link type="0">27 8C 31 1</link><link type="0">27 8C 31 2</link><link type="0">27 8C 31 3</link><link type="0">29 C2 B 1</link><link type="0">28 40 E7 2</link><link type="0">29 E2 59 1</link><link type="0">29 C3 DB 1</link><link type="0">26 B7 D6 1</link><link type="0">36 94 BA 2</link><link type="0">39 47 51 1</link><link type="0">25 B2 4E 1</link><link type="0">25 B2 4E 2</link><link type="0">25 B2 4E 4</link><link type="0">36 E C4 1</link><link type="0">29 D2 4E 1</link><link type="0">27 1B 85 1</link><link type="0">27 1B 85 2</link><link type="0">27 1B 85 3</link><link type="0">27 1B 85 4</link><link type="0">2E 62 FE 1</link><link type="0">2E 6C 89 1</link><link type="0">28 40 E7 3</link><link type="0">22 F 53 2</link><link type="0">22 F 53 3</link><link type="0">2E 71 91 1</link><link type="0">26 D2 CE 1</link><link type="0">36 94 BA 3</link><link type="0">19 8E 3E 1</link><link type="0">2B F9 D1 1</link><link type="0">2B F9 D1 2</link><link type="0">2E 71 91 2</link><link type="0">2E 71 91 3</link><link type="0">2E 71 91 4</link><link type="0">36 78 EE 2</link><link type="0">36 78 EE 3</link><link type="0">2D 64 8E 1</link><link type="0">2D 64 8E 2</link><link type="0">39 47 51 2</link><link type="0">2D 64 8E 3</link><link type="0">28 56 C 1</link><link type="0">28 56 C 2</link><link type="0">28 56 C 4</link><link type="0">2D 67 81 1</link><link type="0">2D 67 81 2</link><link type="0">2D 67 81 3</link><link type="0">FF 03 06 1</link><link type="0">31 DD 64 1</link><link type="0">FF 03 0A 1</link><link type="0">31 DD 64 2</link><link type="0">31 DD 64 3</link><link type="0">31 DD 62 1</link><link type="0">31 DD 62 2</link><link type="0">31 DD 62 3</link><link type="0">31 D6 CA 1</link><link type="0">31 D6 CA 2</link><link type="0">31 D6 CA 3</link><link type="0">2E 6C 31 1</link><link type="0">34 7C 2C 1</link><link type="0">34 7C 2C 3</link><link type="0">34 7C 2C 4</link><link type="0">34 7C 2C 5</link><link type="0">34 7C 2C 6</link><link type="0">34 8D BC 2</link><link type="0">37 4C 9 1</link><link type="0">37 5E 54 1</link><link type="0">34 6E 8A 1</link><link type="0">34 6E 8A 2</link><link type="0">37 48 2C 1</link><link type="0">37 57 48 1</link><link type="0">36 78 CD 3</link><link type="0">36 B5 53 1</link><link type="0">36 B5 53 2</link><link type="0">36 B5 53 4</link><link type="0">36 CA 8E 1</link><link type="0">36 CA 8E 2</link><link type="0">36 CA 8E 4</link><link type="0">37 3A 5 1</link><link type="0">37 31 89 1</link><link type="0">39 A3 4E 1</link><link type="0">39 A3 4E 2</link><link type="0">FF 03 05 1</link><link type="0">n001_gathrmsta</link><link type="0">n001_utilstat</link></members></group><group flag="132"><address>13229</address><name>MBR Passtrough</name><parent type="3">53830</parent><deviceGroup>28</deviceGroup><ELK_ID>G09</ELK_ID><members><link type="16">28 40 E7 1</link><link type="32">1A D9 D0 1</link></members></group><group flag="132"><address>13813</address><name>All Lights Downstairs</name><deviceGroup>26</deviceGroup><ELK_ID>F06</ELK_ID><members><link type="32">26 C5 EB 1</link><link type="32">26 C6 80 1</link><link type="32">26 BA 73 1</link><link type="32">1A DA 2C 1</link><link type="32">26 B7 D6 1</link><link type="32">26 D2 CE 1</link></members></group><group flag="132"><address>13922</address><name>TV Watching</name><parent type="3">42163</parent><deviceGroup>17</deviceGroup><ELK_ID>D02</ELK_ID><members><link type="32">29 D4 C4 1</link><link type="32">29 C1 25 1</link><link type="32">29 BE B7 1</link><link type="32">29 C2 B 1</link></members></group><group flag="132"><address>14574</address><name>Dining Only</name><parent type="3">42163</parent><deviceGroup>34</deviceGroup><ELK_ID>C16</ELK_ID><members><link type="32">29 D4 C4 1</link></members></group><group flag="132"><address>17374</address><name>All Lights Upstairs</name><deviceGroup>18</deviceGroup><ELK_ID>F05</ELK_ID><members><link type="32">29 D4 C4 1</link><link type="32">29 C1 25 1</link><link type="32">1A D9 D0 1</link><link type="32">29 BE B7 1</link><link type="32">29 C2 B 1</link><link type="32">29 E2 59 1</link><link type="32">29 C3 DB 1</link><link type="32">29 D2 4E 1</link><link type="32">34 7C 2C 1</link></members></group><group flag="132"><address>23879</address><name>RecRm Passthrough</name><parent type="3">39461</parent><deviceGroup>35</deviceGroup><ELK_ID>I08</ELK_ID><members><link type="32">26 B7 D6 1</link><link type="16">2D 64 8E 1</link></members></group><group flag="132"><address>26270</address><name>Lights, DoorBell and Beeper</name><deviceGroup>20</deviceGroup><ELK_ID>E14</ELK_ID><members><link type="32">29 D4 C4 1</link><link type="32">26 C5 EB 1</link><link type="32">29 C1 25 1</link><link type="32">1A D9 D0 1</link><link type="32">26 C6 80 1</link><link type="32">26 BA 73 1</link><link type="32">1A DA 2C 1</link><link type="32">29 BE B7 1</link><link type="32">29 C2 B 1</link><link type="32">29 E2 59 1</link><link type="32">29 C3 DB 1</link><link type="32">26 B7 D6 1</link><link type="32">29 D2 4E 1</link><link type="32">2B F9 D1 2</link><link type="32">39 47 51 2</link><link type="32">34 7C 2C 1</link><link type="32">34 6E 8A 2</link></members></group><group flag="132"><address>27226</address><name>LLand Passthrough</name><parent type="3">36547</parent><deviceGroup>29</deviceGroup><ELK_ID>A14</ELK_ID><members><link type="32">26 C5 EB 1</link><link type="16">31 DD 62 1</link></members></group><group flag="132"><address>2918</address><name>Off</name><parent type="3">42163</parent><deviceGroup>22</deviceGroup><ELK_ID>D12</ELK_ID><members><link type="32">29 D4 C4 1</link><link type="32">29 C1 25 1</link><link type="32">29 BE B7 1</link><link type="32">29 C2 B 1</link></members></group><group flag="132"><address>36685</address><name>AftBR Passthrough</name><parent type="3">30216</parent><deviceGroup>27</deviceGroup><ELK_ID>A10</ELK_ID><members><link type="32">26 BA 73 1</link><link type="16">31 D6 CA 1</link></members></group><group flag="132"><address>37613</address><name>MudRm Passthrough</name><parent type="3">17640</parent><deviceGroup>25</deviceGroup><ELK_ID>E10</ELK_ID><members><link type="16">2D 67 81 1</link><link type="32">34 7C 2C 1</link></members></group><group flag="132"><address>40546</address><name>Bright</name><parent type="3">42163</parent><deviceGroup>24</deviceGroup><ELK_ID>E01</ELK_ID><members><link type="32">29 D4 C4 1</link><link type="32">29 C1 25 1</link><link type="32">29 BE B7 1</link><link type="32">29 C2 B 1</link></members></group><group flag="132"><address>44365</address><name>FullOn</name><parent type="3">42163</parent><deviceGroup>23</deviceGroup><ELK_ID>E09</ELK_ID><members><link type="32">29 D4 C4 1</link><link type="32">29 C1 25 1</link><link type="32">29 BE B7 1</link><link type="32">29 C2 B 1</link><link type="32">29 C3 DB 1</link></members></group><group flag="132"><address>54684</address><name>Movie</name><parent type="3">42163</parent><deviceGroup>21</deviceGroup><ELK_ID>A09</ELK_ID><members><link type="32">29 D4 C4 1</link><link type="32">29 C1 25 1</link><link type="32">29 BE B7 1</link><link type="32">29 C2 B 1</link></members></group><group flag="132"><address>59187</address><name>MudRm LEDs.on</name><parent type="3">17640</parent><deviceGroup>31</deviceGroup><ELK_ID>I16</ELK_ID><members><link type="32">34 7C 2C 3</link><link type="32">34 7C 2C 4</link><link type="32">34 7C 2C 5</link><link type="32">34 7C 2C 6</link></members></group><group flag="132"><address>63972</address><name>Reading</name><parent type="3">42163</parent><deviceGroup>19</deviceGroup><ELK_ID>D08</ELK_ID><members><link type="32">29 D4 C4 1</link><link type="32">29 C1 25 1</link><link type="32">29 BE B7 1</link><link type="32">29 C2 B 1</link></members></group><group flag="132"><address>7861</address><name>MudRm LEDs.off</name><parent type="3">17640</parent><deviceGroup>33</deviceGroup><ELK_ID>J01</ELK_ID><members><link type="32">34 7C 2C 3</link><link type="32">34 7C 2C 4</link><link type="32">34 7C 2C 5</link><link type="32">34 7C 2C 6</link></members></group><group flag="132"><address>7920</address><name>EveBR Passthrough</name><parent type="3">28354</parent><deviceGroup>30</deviceGroup><ELK_ID>H03</ELK_ID><members><link type="32">26 C6 80 1</link><link type="16">31 DD 64 1</link></members></group><group flag="132"><address>9294</address><name>Library Passthrough</name><parent type="3">27073</parent><deviceGroup>32</deviceGroup><ELK_ID>B15</ELK_ID><members><link type="16">36 94 BA 1</link><link type="32">1A DA 2C 1</link></members></group><group flag="132"><address>ADR0001</address><name>Auto DR</name><family>5</family><deviceGroup>16</deviceGroup><ELK_ID>A01</ELK_ID><members></members></group></nodes> (nodes)
2016-03-19 22:25:42 - Web Request: /index.htm
2016-03-19 22:25:44 - {"runtimes":[{"ts":1458345600,"heat1":153,"heat2":0,"cool1":0,"cool2":0,"aux1":0,"aux2":0,"fc":0},{"ts":1458411939,"heat1":545,"heat2":0,"cool1":0,"cool2":0,"aux1":0,"aux2":0,"fc":0}]}(G) [gathrmsta]
2016-03-19 22:25:44 - Auto-Update: Checking for program update...
2016-03-19 22:25:45 - Auto-Update: No web update available
2016-03-19 22:25:46 - {"api_ver":5,"type":"residential"}(G) [gathrmsta]
2016-03-19 22:25:46 - Venstar Stat Data - {"api_ver":5,"type":"residential"} [gathrmsta]
2016-03-19 22:25:46 - {"name":"MAIN            0.000000LOOR","mode":1,"state":0,"fan":0,"fanstate":0,"tempunits":1,"schedule":1,"schedulepart":1,"away":0,"spacetemp":24.5,"heattemp":23.5,"cooltemp":23.5,"cooltempmin":18.5,"cooltempmax":37.0,"heattempmin":1.50,"heattempmax":26.5,"hum":0,"hum_setpoint":39,"dehum_setpoint":10,"hum_active":99,"setpointdelta":0.0,"availablemodes":1}(G) [gathrmsta]
2016-03-19 22:25:46 - Venstar Info Data - {"name":"MAIN            0.000000LOOR","mode":1,"state":0,"fan":0,"fanstate":0,"tempunits":1,"schedule":1,"schedulepart":1,"away":0,"spacetemp":24.5,"heattemp":23.5,"cooltemp":23.5,"cooltempmin":18.5,"cooltempmax":37.0,"heattempmin":1.50,"heattempmax":26.5,"hum":0,"hum_setpoint":39,"dehum_setpoint":10,"hum_active":99,"setpointdelta":0.0,"availablemodes":1} [gathrmsta]
2016-03-19 22:25:46 - {"sensors":[{"name":"Thermostat","temp":24.5,"hum":39},{"name":"Outdoor","temp":-5.0}]}(G) [gathrmsta]
2016-03-19 22:25:46 - Venstar Sensor Data - {"sensors":[{"name":"Thermostat","temp":24.5,"hum":39},{"name":"Outdoor","temp":-5.0}]} [gathrmsta]
2016-03-19 22:25:46 - {"alerts":[{"name":"Air Filter","active":false},{"name":"UV Lamp","active":false},{"name":"Service","active":false}]}(G) [gathrmsta]
2016-03-19 22:25:46 - Venstar Alert Data - {"alerts":[{"name":"Air Filter","active":false},{"name":"UV Lamp","active":false},{"name":"Service","active":false}]} [gathrmsta]
2016-03-19 22:25:46 - ISY: Variable gathrmsta-CLIMD added to queue (Val: 1, QS: 1)
2016-03-19 22:25:46 - ISY: Variable gathrmsta-CLIHCS added to queue (Val: 0, QS: 2)
2016-03-19 22:25:46 - ISY:  (ns/1/nodes/n001_gathrmsta/report/status/CLIMD/1/67)
2016-03-19 22:25:46 - ISY: Variable gathrmsta-CLIFS added to queue (Val: 0, QS: 2)
2016-03-19 22:25:46 - ISY: Variable gathrmsta-CLIFRS added to queue (Val: 0, QS: 3)
2016-03-19 22:25:46 - ISY: Variable gathrmsta-CLISMD added to queue (Val: 1, QS: 4)
2016-03-19 22:25:46 - ISY: Variable gathrmsta-GV3 added to queue (Val: 0, QS: 5)
2016-03-19 22:25:46 - ISY: Variable gathrmsta-ST added to queue (Val: 24.5, QS: 6)
2016-03-19 22:25:46 - ISY: Variable gathrmsta-CLISPC added to queue (Val: 23.5, QS: 7)
2016-03-19 22:25:46 - ISY: Variable gathrmsta-CLISPH added to queue (Val: 23.5, QS:
2016-03-19 22:25:46 - ISY:  (ns/1/nodes/n001_gathrmsta/report/status/CLIHCS/0/25)
2016-03-19 22:25:46 - ISY: Variable gathrmsta-CLIHUM added to queue (Val: 39, QS:
2016-03-19 22:25:46 - ISY: Variable gathrmsta-GV2 added to queue (Val: -1, QS: 9)
2016-03-19 22:25:47 - ISY: Variable gathrmsta-GV5 added to queue (Val: -5.0, QS: 10)
2016-03-19 22:25:47 - ISY: Variable gathrmsta-GV6 added to queue (Val: 0, QS: 11)
2016-03-19 22:25:47 - ISY: Variable utilstat-CLIMD added to queue (Val: 1, QS: 12)
2016-03-19 22:25:47 - ISY: Variable utilstat-CLIHCS added to queue (Val: 0, QS: 13)
2016-03-19 22:25:47 - ISY:  (ns/1/nodes/n001_gathrmsta/report/status/CLIFS/0/68)
2016-03-19 22:25:47 - ISY: Variable utilstat-CLIFS added to queue (Val: 0, QS: 13)
2016-03-19 22:25:47 - ISY: Variable utilstat-CLIFRS added to queue (Val: 0, QS: 14)
2016-03-19 22:25:47 - ISY: Variable utilstat-CLISMD added to queue (Val: 1, QS: 15)
2016-03-19 22:25:47 - ISY: Variable utilstat-GV3 added to queue (Val: 0, QS: 16)
2016-03-19 22:25:47 - ISY: Variable utilstat-ST added to queue (Val: 23.0, QS: 17)
2016-03-19 22:25:47 - ISY: Variable utilstat-CLISPC added to queue (Val: 23.0, QS: 18)
2016-03-19 22:25:47 - ISY: Variable utilstat-CLISPH added to queue (Val: 22.0, QS: 19)
2016-03-19 22:25:47 - ISY:  (ns/1/nodes/n001_gathrmsta/report/status/CLIFRS/0/80)
2016-03-19 22:25:47 - ISY: Variable utilstat-CLIHUM added to queue (Val: 37, QS: 19)
2016-03-19 22:25:47 - ISY: Variable utilstat-GV2 added to queue (Val: -1, QS: 20)
2016-03-19 22:25:47 - ISY: Variable utilstat-GV5 added to queue (Val: -40.0, QS: 21)
2016-03-19 22:25:47 - ISY: Variable utilstat-GV6 added to queue (Val: 0, QS: 22)
2016-03-19 22:25:47 - ISY:  (ns/1/nodes/n001_gathrmsta/report/status/CLISMD/1/25)
2016-03-19 22:25:47 - ISY:  (ns/1/nodes/n001_gathrmsta/report/status/GV3/0/25)
2016-03-19 22:25:48 - ISY:  (ns/1/nodes/n001_gathrmsta/report/status/ST/24.5/14)
2016-03-19 22:25:48 - ISY:  (ns/1/nodes/n001_gathrmsta/report/status/CLISPC/23.5/14)
2016-03-19 22:25:49 - ISY:  (ns/1/nodes/n001_gathrmsta/report/status/CLISPH/23.5/14)
2016-03-19 22:25:49 - ISY:  (ns/1/nodes/n001_gathrmsta/report/status/CLIHUM/39/51)
2016-03-19 22:25:49 - ISY:  (ns/1/nodes/n001_gathrmsta/report/status/GV2/-1/25)
2016-03-19 22:25:49 - ISY:  (ns/1/nodes/n001_gathrmsta/report/status/GV5/-5.0/14)
2016-03-19 22:25:50 - ISY:  (ns/1/nodes/n001_gathrmsta/report/status/GV6/0/25)
2016-03-19 22:25:51 - ISY:  (ns/1/nodes/n001_utilstat/report/status/CLIMD/1/67)
2016-03-19 22:25:51 - Web Request: /index.htm
Of there's no boxes in the node in the ISY there's nothing I can do.
Your log shows the bars being set. If they're not showing in the ISY then something is messed on that side
Edited by io_guy
I'm gonna guess 504 will be for fixing 503 issues. Doubt you'll see any node love.
My guess is I have saturated some file or setup in the ISY and it needs to be cleaned out then the installs will work again. I was hoping an ISY update may do this.
Another strange one and maybe a clue. It throws this one occasionally and then works fine again (comms only). All other apps have no trouble logging in.
2016-03-20 00:14:48 - ISY Error: Login failure (verify ISY password on the system config page)
2016-03-20 00:15:03 - Venstar Web Error: The request timed out [gathrmsta]
2016-03-20 00:15:18 - ISY Error: Login failure (verify ISY password on the system config page)
2016-03-20 00:15:49 - ISY Error: Login failure (verify ISY password on the system config page)
2016-03-20 00:16:19 - ISY Error: Login failure (verify ISY password on the system config page)
2016-03-20 00:16:50 - ISY Error: Login failure (verify ISY password on the system config page)
2016-03-20 00:17:20 - ISY Error: Login failure (verify ISY password on the system config page)
2016-03-20 00:17:51 - ISY Error: Login failure (verify ISY password on the system config page)
2016-03-20 00:18:21 - ISY Error: Login failure (verify ISY password on the system config page)
2016-03-20 00:18:52 - ISY Error: Login failure (verify ISY password on the system config page)
2016-03-20 00:19:22 - ISY Error: Login failure (verify ISY password on the system config page)
2016-03-20 00:19:53 - ISY Error: Login failure (verify ISY password on the system config page)
2016-03-20 00:20:24 - ISY Error: Login failure (verify ISY password on the system config page)
2016-03-20 00:20:54 - ISY Error: Login failure (verify ISY password on the system config page)
2016-03-20 00:21:25 - ISY Error: Login failure (verify ISY password on the system config page)
2016-03-20 00:21:56 - ISY Error: Login failure (verify ISY password on the system config page)
Does the isylink node in the very top left pulldown (above "configure")  look correct?
I don't remember this displaying like that with" isylink" showing at the top of the list but rather just in the "configure" menu.
Please confirm before I proceed. Thanks.
OK. success!
Factory reset ISY
Telnetted into ISY and ISY formatted the SD card
Admin Console - manually updated ISY to v5.0.2
Admin console - restored latest backup - didn't like some of the recovery things I attempted and two node servers etc.
Admin console - restored one backup older - looks good, all programs are showing and intact
NodeLink install T7900 stat device, Install to ISY with new name
Admin - console - changed password to original, replaced all program occurrences of old T7900 with new working T7900.
NodeLink 4.1 - installed second T7900 stat, installed to ISY and renamed in ISY.
Admin Console - updated the few changes I made since restored version and backed up!
Looks like a success! - I am back, with full thermostat tweaking control. Now to set my stat schedules back to the backup plan again. All programs are back up to the last valid backup. The few changes I made were minimal and I can recreate them from memory in half an hour.
Thanks io_guy and Paul!  Much sweating happened in the last two days!
ISY Nodes need some change in logic when a node device is missing. ahhhhh... beta.....and the bleeding edge. :)
Hi larryllix,
Did this also solve the missing programs issue?
Yes. All is well again .
My conclusion is that my bumbling with multiple install/delete attempts saturated some file or process in ISY and now it is clean again.
Another thing that should be mentioned and cautioned that my ISY was operating all kinds of lights at random while I had no Node Server setup in ISY and NodeLink had profiles running.
t first I thought I was beginning to experience PLM problems but my MiLight strips and bulbs were operating and they only operate via network resources, not the PLM. Once I removed the NodeLink device that couldn't connect to ISY the random flashing on and off stopped.
ISY Node software needs some handshakes to avoid this. NodeLink just unknowingly fires off data to ISY without any confirmations at a certain level. ISY didn't have anything to receive the data properly. This can happen with the rest interface, also, since no checks are in place.
NodeLink only sends a message every 30s on failures.
If the ISY can't handle network traffic that's not my problem. Not exactly DOS levels.
Edited by io_guy
  • 3 months later...
Don't know why, but the profile upload just would not take for me until I cleared out my Hue and Nest node servers, which I wasn't using anyway. After that and a few restarts, it works fine. One nit to pick, the NodeLink web page describes the Time of Use item correctly as "Off Peak"; however, on my ISY it shows as "Off Peek". Now off to play with the 1-wire stuff.  :-P
I found another little typo-style bug. Nothing that keeps it from working, just more of the spit-and-polish stuff.
Edited by builderb
Good catches - these are now fixed in the latest nodesetup.zip file.
Sweet, that's nice and easy to update via profile.
So... How tough would it be to add support for sending the data logger events to an external database instead of just the log file? Something like an *-SQL, or an .rrd file.
Easy, but likely won't happen. Each DB format requires it's own handler so in reality I should support the major four.
It's really only a few lines of code to handle each, my issue is I'd need to include the data adapter DLL for each with my program. Right now I'm pretty strict with not using external DLLs and this likely won't change. I like having a single simple exe to toss around without any install or 3rd parties issues.
