February 17, 201610 yr Hi, Does anyone have any experience with the Stelpro Zwave line level baseboard thermostat? http://www.stelpro.com/en-CA/4000-w-ki-thermostat-smart-home It seems interesting, but i think it's pretty new. And i don't know if it works with ISY Zwave module. Thanks, Francois
February 17, 201610 yr This would be fantastic...just what I've been looking for. Michel, is this ISY compatible? (I "assume" it uses standard ZWAVE protocol etc.)
February 18, 201610 yr Hi Ron, It should be at the least with common command classes. If they have new manufacturer specific features, then we will have to implement. With kind regards, Michel
February 22, 201610 yr I assume this will work with in-floor heating ?, don't see why not from the spec's unless I am missing something.
February 22, 201610 yr I assume this will work with in-floor heating ?, don't see why not from the spec's unless I am missing something. If this is a bathroom install you should check CE code to see if GFCI is required... probably best to consult with the manufacturer of the element. Jon...
February 22, 201610 yr I just called them and they said these are not compatible with in-floor heating systems
February 22, 201610 yr I just called them and they said these are not compatible with in-floor heating systems Did they tell you why? I've only seen one install and as it was explained to me it had a sensor in the floor. Jon...
February 22, 201610 yr Did they tell you why? I've only seen one install and as it was explained to me it had a sensor in the floor. Jon... No they did not, I guess I should have asked
March 10, 201610 yr So if anyone is looking at heated flooring and control, there are some manufactures that have WIFI thermostats (Oulette), I guess I will go this way and use the network module.
March 30, 20169 yr Has anyone tried this Tstat with the ISY yet? I'm looking at it for classic baseboard heating control..
April 14, 20169 yr Has anyone tried this Tstat with the ISY yet? I'm looking at it for classic baseboard heating control.. Well, decided to buy a couple and try them. They integrate just fine with the ISY and provide as much control with better reliability as the Insteon T-Stat (heat only of course). Price is right too!
September 30, 20178 yr Has anyone tried this Tstat with the ISY yet? I'm looking at it for classic baseboard heating control.. I just installed one and it connected to my ISY quickly and easily.
