Replacing PLM
pjt588
Good sequence, thanks.
For a Controller device that is not reporting status, do a Show Device Links Table and post result.
Also what is PLM Insteon address?
An ApplianceLinc cannot function as a Controller device.
Lee - you asked what type of device 1B.75.FF was and it's the ApplianceLinc that I mentioned above.  Of course it's not a controller - what are you suggesting with that statement?
FWIW, the system was working for about 18 months without any configuration changes before the PLM died.  All I did was replace the PLM.
From post #26 - "For a Controller device that is not reporting status, do a Show Device Links Table and post result."
The response was to provide information about an ApplianceLinc which is not a Controller.
Did you manually link the Mini Remote?
I programmed it through ISY.
I checked operations again with the UD interface and now all devices are responding and showing status correctly.  It appears that the scenes are not turning on or off as they should under program control.  However, the Mini Remote is controlling 3 scenes successfully.  Very confusing!
The programs appear to be running successfully, but in the end nothing is happening.  I can come in afterwards and toggle all devices with the UD interface that should have turned on or off under program control.
Perhaps a restore of the ISY is in order?
Just got my first dead PLM and after replacing with the new one (v2.0 - 1444)
Steps
1 .Backup prior to shutdown and replace everything
2. Turned on the PLM
3. After few seconds Turned on ISY
4. Replace PLM...
=> i got an error in the ISY that cannot update plm.
After starting all over again (having reinstalled it from backup)  i could update the PLM but nothing was working well, and when i did a show PLM links table i got an error ( Failed reading device link (PLM) [-200000/-5] ).
Here the log during this tentative to read the PLM links.
Qua 03/30/2016 21:04:44 : [iNST-TX-I1  ] 02 62 1B 47 71 0F 28 0F
Qua 03/30/2016 21:04:44 : [iNST-ACK    ] 02 62 1B.47.71 0F 28 0F 06          SET-MSB(0F)
Qua 03/30/2016 21:04:53 : [iNST-TX-I1  ] 02 62 1B 47 71 0F 28 0F
Qua 03/30/2016 21:04:53 : [iNST-ACK    ] 02 62 1B.47.71 0F 28 0F 06          SET-MSB(0F)
Qua 03/30/2016 21:05:02 : [iNST-TX-I1  ] 02 62 1B 47 71 0F 28 0F
Qua 03/30/2016 21:05:02 : [iNST-ACK    ] 02 62 1B.47.71 0F 28 0F 06          SET-MSB(0F)
Qua 03/30/2016 21:05:06 : [All         ] Writing 21 bytes to devices
Qua 03/30/2016 21:05:06 : [iNST-TX-I1  ] 02 62 36 FD 7A 0F 0D 00
Qua 03/30/2016 21:05:06 : [iNST-ACK    ] 02 62 36.FD.7A 0F 0D 00 06                 (00)
Qua 03/30/2016 21:05:15 : [iNST-TX-I1  ] 02 62 36 FD 7A 0F 0D 00
Qua 03/30/2016 21:05:15 : [iNST-ACK    ] 02 62 36.FD.7A 0F 0D 00 06                 (00)
Qua 03/30/2016 21:05:24 : [iNST-TX-I1  ] 02 62 36 FD 7A 0F 0D 00
Qua 03/30/2016 21:05:24 : [iNST-ACK    ] 02 62 36.FD.7A 0F 0D 00 06                 (00)
Qua 03/30/2016 21:05:28 : [iNST-TX-I1  ] 02 62 1B 47 71 0F 0D 00
Qua 03/30/2016 21:05:28 : [iNST-ACK    ] 02 62 1B.47.71 0F 0D 00 06                 (00)
Qua 03/30/2016 21:05:37 : [iNST-TX-I1  ] 02 62 1B 47 71 0F 0D 00
Qua 03/30/2016 21:05:37 : [iNST-ACK    ] 02 62 1B.47.71 0F 0D 00 06                 (00)
Qua 03/30/2016 21:05:46 : [iNST-TX-I1  ] 02 62 1B 47 71 0F 0D 00
Qua 03/30/2016 21:05:46 : [iNST-ACK    ] 02 62 1B.47.71 0F 0D 00 06                 (00)
When i count PLM "ISY" links it shows only 10, i have more than 25 devices, and nothing is working as usual.
I tried removing some devices and reinstalling and seems to be recovering those reinstalled. I'm sure this is not the right procedure, could someone point me to a better direction to fix ?
Hi MFBra,
Have you at any point in time done File | Delete Modem? If so, that explains everything you are seeing.
Also, did you ever do File | Restore Modem on a dead PLM? If so, please go to an older but good backup, restore it, and then do File | Restore Devices.
no, i haven't deleted the modem neither restore on the dead plm.
I tried first time without success, restored the backup, reset the new plm to factory default and did again the restore modem.
i'm still doing the delete -> reinsert the devices. Any advice on programs that refers to them ? Some programs still referencing to the same device after deleting and reinserting, but even though i'm double checking everything.   tedious....
MFBra,
For devices, programs have to point back to them automatically. For scenes, if you have not deleted the scene, then it should work automatically. If you have deleted the scene, then there's no guarantee that the next scene would have the same ID.
I still cannot understand why File | Restore Devices didn't work.
Still having issues... now I'm trying to restore/relink my battery powered devices.  The first four door open sensors (2845-222) worked fine by replacing the battery, putting the sensor in link mode, and then doing a "write updates" command.  The last two devices seemed to have cross matched addresses, so I deleted both items from the ISY completely.  I've tried re-linking them from scratch and the ISY finds the new device, but while trying to add it, I get a "Cannot determine the device link table address" message.  I've tried restarting both ISY and PLM, and doing a factory reset on the sensor itself.  Any other suggestions?
Make sure that only one battery powered device at a time is in the linking mode. If you put multiple devices in the linking mode it's possible they cross linked. If that's the case then factory reset them and then re-link.
