Connected Home API + Thermostats
any news on when ISY will support thermostats via the connected home integration?
The Izzy skill can control Insteon thermostats. I don't have any others to test with.
I'm familiar with the Izzy Skill, but I was specifically referring to connected home, aka, not having to use the skill
ISY controls both my Insteon thermostats natively and my Venstar thermostats with an RPI and Nodelink.
I don't need to use anything else so whatever controls ISY can control those.
Not using anything else usually implies the ISY and Echo plus the required portal.
woohoo!
now here's another question, how would a Thermostat connected to an ELK system work with this new integration? Assuming the elk module is in place and the ISY can fully communicate with the ELK M1XEP?
Thanks for the clarification Michel, would zwave thermostats, linked to the ISY, work?
  • 5 weeks later...
Any update on the approval of the thermostat Smart Home skill?
  • 3 weeks later...
  • 3 weeks later...
Would it be possible to upload the new ISY Skill with the 2.0 SmartHome API as a new, separate product? I could just delete the old Skill and add the new one? Since they are free and easy to configure, this would avoid any support calls.
Hello kingwr,
We have been going back and forth on this with Amazon. In short, what's going to happen (once we are certified for V2), existing users can continue using V1 but new users can NOT find the V1 app. They will only find V2. V1 users MUST unlink V1, link V2, and the rediscover. Quite convoluted and not optimal but that's where it is right now.
