ISY Portal IFTTT Integration - Question
Setup Instructions - ISY Portal
  • On portal, IFTTT configuration is in Select Tool | Connectivity | IFTTT
    • ​When I do this it says ISY is not online, however on the main account screen after my UUID the status is Online since Monday, April 11th, 4;01:35 AM
    • Clicking OK to the error does not prevent me from going to the next step.
  • First, you will need to click on "Set Key" to create an IFTTT Key that will be used to authenticate your IFTTT requests
    • So I clicked the Set Key and created an inbound key.  I assume this gets pasted into IFTTT Maker Channel somewhere.  My IFTTT Maker channel also has a KEY, but I am not sure where it goes in ISY Portal.
​Can someone explain the keys and why I may be getting a not online error?
OK, I went on to the next section and figured out the Outbound Triggers and successfully created an outbound event.  I see this is where I use the IFTTT KEY.  The inbound is still a little unclear to me.
Hi epete
I'm not sure about the first problem.  Go into the ISY Admin Console and look under the Portals tab,does it show you online? after you press refresh. I would try rebooting your ISY.
The key does not get sent to IFTTT, you copy and paste it in the Maker channel in your recipes
https://my.isy.io/api/ifttt/Disarmed/key/xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx
Where it says Disarmed  above, use the event name you created under IFTTT Inbound Events in the ISY portal, using this format:
Use your ISY Portal IFTTT generated key at the end
  • You'll use the Action part of the maker channel, to cause the ISY to act from an IFTTT external trigger. No IFTTT generated key needed, just the ISY's.
  • You'll use an network resource in the network module to trigger events from the ISY to make IFTTT Maker Triggers to affect something else.
Paul
Edited by paulbates
My portal Integration box says Online, Registered so I will see if it works anyway using the info/URL you provided and see if I can get it to work anyway.  Thanks
yea, that was the problem.  Getting the first one written so I can understand what I am doing.
