Reset everything
Guys, with all the issues I had lately, I think I will factory default everything.
Plus, I had 2 more issues with 2 devices (program can turn on a scene with its devices, but IPhone can't) and I factory defaulted those device and it all worked right away!
Some background, I had the isnteon 2412n as controler, it died and got replaced with a hub. It died too, got replaced with another hub. Now replaced with isy.
I think devices might be confused with too many config or something. Can it be?
I plan to factory default all my switches and keypad.
Should I reset the isy and plm too?
Edited by gonzo__007
If you're factory resetting all the devices, then it probably wouldn't hurt to do a factory reset on the PLM.  No need to reset the ISY.
Then do a restore PLM - DO NOT do a delete PLM.
Were all your devices installed using ISY linking?
Edited by Techman
Going from the HUB to ISY you should either link devices using "remove existing links" or to factory reset each device.
I think the old links if not removed just cause more traffic that never gets anywhere and that may cause problems.
Jon...
Before devices were linked using local button for linking.
Weird. When I added devices in isy, I select remove link. But seems like like factory default is more effective.
I did reset all devices, reset isy, and restore plm.
Hopefully everything will start working as they should
I would say "so far so good" I reset all insteon device, my ISY and did "restore PLM" and everything works.
had 2 little issues where 2 swiches stoped responding to scenes. removed the device from ISY, factory defaulted it, and re-added and they work.
about 24 hours later, everything good so far...
hopefully that reset of everything will fix it
