One button on an 8 button switch doesn't work properly
Hi gang,
I have an 8 button controller where the E button is acting strangely. The LED turns on and off as expected with keypresses, however, the ISY only registers Dim or Bright (i.e., when I press and hold the button), and does not respond to On, Off, Fast On, or Fast Off. I confirmed this with the diagnostics Event Viewer on Level 2. Only a press and hold generates entries in the Event Viewer window. I have tried a factory reset.
Any ideas?
Cheers!
This is becoming an epidemic! I believe this is the 3rd post that I have seen in the last couple of days with this similar issue...
Wish I knew what the fix was...sorry I don't, but hopefully someone does.
Hi gang,
Any ideas?
Cheers!
Try a "Restore Device" on the problem KeypadLinc.
Thanks Mike,
I tried restore, factory reset, removed the device then reinstalled, restored the PLM, no dice.
Cheers!
to_lighter,
Are you sure you do not have it on toggle or mutex mode?
If you are still having problems, please post to this topic
http://forum.universal-devices.com/view ... 5364#15364 before getting a replacement.
Thanks Mike,
Cheers!
to_lighter,
Thanks Mike,
Cheers!
Hi Michel,
It is in toggle mode (toggle on only). It is also in mutually exclusive mode with 5 other buttons, but when I took it out of the mutually exclusive set, it still didn't work. Only Dim/Bright works, no On/Off/Fast On/Fast Off. The LED light does work properly (i.e. it behaves as it is supposed to as part of the mutually exclusive set, and turns on when pressed).
Cheers!
